Question about Bosch 24 in. SHX46A05UC Built-In Dishwasher
Bosch dishwasher Model shx46a05Uc/14 not running
The motor is activated but no cycle begins. We just secured and leveled the unit as it was always unlevel. Could we have done something to the unit in the leveling securing process. Perhaps there is some kind of activator switch that was compromised.
SOURCE: Bosch dishwasher cleans but will not drain.
Remove the drain hose where it attaches to the disposal. This area often clogs and will prevent any d/w from draining.
Posted on Feb 15, 2009
  • 39 Answers
SOURCE: I need to replace my Bosch dishwasher motor and
whats wrong with it? check out this link:
http://www.squidoo.com/Bosch_Dishwasher_Drainage_Problem_Fixes
Posted on Nov 02, 2009
Macmarkus
  • 2605 Answers
SOURCE: Water in Dishwasher Bottom
Hello Richard, Welcome to Fixya ! You've come to the right place. The problem you're experiencing unfortunately is a common one. The water inlet valve has been an issue with B/S/H built ( this includes bosch, thermador, seimens & gaggenau ) dishwasher's going back to the mid 90's. The part to repair it is available at most brick & mortar appliance part centers or you can check out on-line vendors such as repairclinic, apwagner etc. Do a search for part # 1105846 at repairclinic, you'll see what I'm talikng about. By the way it's about $35. Hope that helps move you forward. Let me know if I can assist you further, or need help on how to change it etc. It's relatively easy with Bosch. Thanks for coming to "fixya" for your inquiries and please take a second to rate this answer according to my helpfulness. Goof luck. Macmarkus :)
Posted on May 04, 2010
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Posted on May 25, 2010
  • 3247 Answers
SOURCE: My bosch shx46a05UC/14 will not shut off. I can
Are you please able to confirm what exactly is happening when you mention "dishwasher just keeps going".
Is it in a wash cycle and throwing the water around through the wash arms or do you just hear a pump running with water sitting in the base. Most likely there is a leak into the base and the auto stop circuit is trying to empty the dishwasher by running the drain pump. I would suggest you check the base of dishwasher for leaks.
Posted on Jan 28, 2011
My bosch shx46a05UC/14 will not shut off. I can open the door and the dishwasher just keeps going?
Jan 28, 2011 | Bosch 24 in. SHX46A05UC Built-In...
Wash cycle stopped with water in the bottom. Seems like there is no power. Can't get lights on cycles buttons to turn on. Power button does nothing. Checked circuit breakers. All are on. Lights and outlets...
Check the wiring in the units junction box. Its located at the bottom right corner. You will likely find melted connectors. If so, you need to cut the wires back and replace these connectors. Make sure you turn the power off before doing any of this work of course. Good Luck.
Jan 14, 2011 | Bosch 24 in. SHX46A05UC Built-In...
Our dishwasher takes about 3-4 hours to run a cycle. My brother has the same model and it takes about an hour. Is there an adjustment that we can make to correct this? Thanks, Karla
make sure that your filter in the bottom is clean and if you are using the automatic wash cycle, it will wash until the water is clean. Sometimes it will take an hour, sometimes it will take close to 2 depending upon the level of dirty dishes in the dishwasher. And don't rinse! They work better on dirty dishes.
Jan 05, 2011 | Bosch 24 in. SHX46A05UC Built-In...
Bosch Dishwasher SHX46A05UC/23 - No Water
Sounds like your recirculating pump is clogged If it is water can't get up enough pressure to turn the sprayers.
You'll need to start pulling parts out of the bottom inside to get to that pump. I don't work on a lot of Bosch, but that sure sounds like it to me. I see this a lot. Hope this helps...
Nov 28, 2009 | Dishwashers
Dishes do not clean same detergent and rinse no change to amount
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Jul 06, 2009 | Bosch 24 in. SHX46A05UC Built-In...
Bosch Model shx46a05Uc/14 not running
Unlikely to be a level problem. Remove the filter and two screws holding the cover over the wash motor impeller from inside the wash tank - check for something jamming the impeller, like bits of broken glass or fragments of bone, fruit pips etc.
If not that, check basics - water supply, drain hose, filters clear, not syphoning empty, etc.
Feb 02, 2018 | Bosch 24 in. SHX46A05UC Built-In...
Dishwasher motor runs (even with door open), but no Water
I believe the problem is in the electronic board. It is getting a different signal thus not allowing it to run properly. You can have a local service technician for the company look at it but this is probably the cause.
Dec 25, 2008 | Bosch 24 in. SHX46A05UC Built-In...
Dishwashers Logo
350 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
