Question about Gemini SA-600 Turntable
My SA-600 doesn't work... Dj Rolmixxxx
I got a problem with my gemini SA-600
it works normally when i play a record on it, but doesn't when I play a timecoded vinyl that comes from virtual dj.. The thing is, it was normally playin' for a long time, but from now, it stops play...
i'm not a turntablist, but a computer Dj that uses timecoded vinyls to scratch
please help me
Dj Rolmixxx
    Problem Solver:
  • 17 Answers
You do have a soundcard between your setup and the computer?
if not, thats the issue, you need a souncard to decode and recode the timecode for vdj - maya 44 is cheap and does the trick.
Posted on Feb 12, 2009
How i can connect a Gemini cdm-3610 to a laptopand which cabes i can use
It depends on what connections the laptop has. Most have an audio in socket. So you can use that. All you need is to find a audio out on the deck. I looked at an illustration and it has an headphone socket. So you could use that. Just keep the volume control low.
Sep 20, 2016 | Gemini Audio Players & Recorders
CANT SKIP TRACKS AND THE SCREEN SHOWS A 100, I HAVE NEVER SEEN THE NUMBER 100 ON SCREEN, HELP!!!!!
I own one of these and its the same. Even more, functions works weird, it passes on usb while searching files on cd.... and more. Bad connections inside and firmware probably. Dont loose time and money to fix it. Doesn't worth.
May 25, 2016 | Gemini DJ Gemini CDJ-600
What inputs do I use to connect my laptop to the gemini cdm 3700g?
if it's to record the Audio you need some kind of interface analog(RCA ) to usb like the behringer UCA 202 Now if it's to watch or to try to record Audio and Video you need to look at a video capture type of interface composite audio video to interface like the SIIG USB 2.0 Video Capture Device just make sure its compatible with your OS. Now if you try to use it as a Midi controller with program like Serato , Virtual dj ... you are out of luck this system is not compatible .
Good luck.
Jul 05, 2014 | Gemini DJ Gemini CDM-3700G Dual CD Karaoke...
Need help with a sound problem im experiencing with my Gemini CNTRL-7 controller
Hey, try changing your default playback device. Your controller may be trying to tell your PC that it has a speaker, changing the playback device to your speakers may fix this. (if using windows, right click on your speaker icon - lower right hand corner, select 'playback devices' and then choose your usual device - if you don't know which one is, then just select different ones and see what works)
Later,
Beau.
Jun 20, 2014 | Gemini DJ Gemini CNTRL-7 USB MIDI DJ...
I need a power lead
The power cord looks like this is a standard PC/Kettle power cord. Otherwise the connecting cables should be just standard phone cables. have a look at the image here..
http://medias.audiofanzine.com/images/normal/gemini-dj-pt-2000-185179.jpg
May 21, 2014 | Gemini DJ Gemini Pt2000 Turntables
I cant get my headphone to work on my gemini cntrl-7.
If you are using virtual dj , adjust your settings under configuration - sound setup , change the output settings to headphones.
Jun 08, 2012 | Gemini DJ Gemini CNTRL-7 USB MIDI DJ...
Help with set up
connect your gemini phono out to -------- pioneer phono in.
Jul 12, 2008 | Pioneer DJM-600 Silver Professional DJ...
Gemini SA-600 Turntable Logo
359 people viewed this question
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Don Hart
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
