Question about Canon PIXMA MP610 InkJet Printer
Canon Pixma MP610 custom paper size problem
When printing 4x6 photos in borderless mode there is a huge amount of overspray (after 10-20 photos the printer starts smudging). The next day first 10-15 photos are OK, rest is with ink smudges. I believe it's because of a huge overspray caused by using 4x6in (101.6 x 152.4mm) driver setting with 100x150 paper. It's much more difficult to buy 4x6 paper than 100x150mm (I'm in Europe).
The question is - how do I use custom paper size in borderless mode? Soon as I tick the borderless tickbox in the driver, the paper sizes list becomes limited and 'custom' disapears.
I think it's a common problem not only for MP610 but for other Pixmas too. I read the manual - nothing, I tried googling - no solution.
Best Regards,
  • Jerry1111 Jan 28, 2009
    Thanks yooperbud. The driver is OK - in fact I've tried reinstalling, no change. The problem seems to be with overspray because of page size mismatch _and_ paper quality. Looks like some (not all) papers are a little bit curly (difficult to see with your eye, but you can see that with a ruler). Add both things together and you have my problem. Situation got much better when i've started printing from QImage with margins adjusted by hand (to give <0.5mm overspray). Also the paper is stored under weight (to keep it straight). So far so good!
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Not a problem,but I own the canon pixma 310 and I'm not sure how setting it up to print photos is different than regular document printing?
Hi! here is your solution. 1. Select your image. 2. Click your mouse i.e. right click. 3. Select Print. 4. There are many size for example 4x6 5x7. Chose your size you want to print. 5. Select Photo plus Glossy paper. 6. Press print. thanks
Sep 05, 2011 | Canon PIXMA MX310 All-In-One Printer
My 4x6 prints are not centered on paper
That printer can't print borderless on 4x6 photo paper, you should use A4 size paper, print and cut the pictures.
Nov 04, 2009 | HP DeskJet 940c InkJet Printer
Canon MP600, Borderless print issues
There is probably a "gutter" setting that is trying to give you a border of sorts. Check the advanced print settings and look for something like gutter and turn it off.
Jul 11, 2009 | Canon Pixma MP600 Printer
Settings for printing a borderless 8x10 on a canon i9900
Downloaded following program for Vista and was able to print borderless pictures on Canoni9900
Easy-PhotoPrint EX Ver.2.0.3 (Windows Vista/Vista64/XP/2000)
Mar 02, 2009 | Canon i9900 InkJet Photo Printer
Konica Minolta Bizhub C350. Precut 4x6 full bleed postcards.
Yes, there is no 4x6 choice, you have to input costume size.
For the bord-less part, i first would recommend to use a little bigger costume size so if paper with is 20 mm and there is a boarder about 1-3 mm then input costume size 23 mm. Caution, this can cause a paper jam, because there is a solenoids, what read paper. or you can use a bigger paper and later cut off the boards. Because this printer is not capable printing board-less photos
Jan 21, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
MP600 with Mac OS X - no borderless printing option?
I had the same question. I found the answer at Canon's site but I can't link directly to the page so here's how I found the solution...
1. Go to the Canon Support site. 2. In the "Please enter your question field" type: How do I Print edge to edge? 3. Hit the "Search" button. 4. Click the #1 (top) search result "How do I Print edge to edge?" 5. Click the #1 (top) solution: "Use Borderless Printing (Mac OS X) MP600 6. Follow the directions.
It seems the main thing you need to do is go to the "Page Setup" dialog. Then make sure you've chosen the MP600 in the "Format for:" popup menu. Finally, in the "Paper Size:" popup, select "A4" then "A4 (borderless). It's a hierarchical menu.
FWIW I still haven't gotten a "perfect" borderless print. Seems you gotta get the paper in there exactly straight...
Jan 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printing steps for 4x6 size photo paper
Try this :
1) Within your application click on FILE and PRINT
2) Depending on the application in use, you may see either "Printer" or "Format for". Ensure your printer name is selected here instead of "Any Printer".
3) Click the up/down arrows next to COPIES and PAGES to see all the available setting options:
Allows you to select how many copies you want and if you want to print all pages, selected pages or a specific page.
Adjust the way the image is displayed on the media for multiple page printing.
Allows options for when to print a job, such as specific time or to hold the jobs, and the priority of the job to be printed for networked machines.
More page options, such as even or odd pages only, and reverse print order.
Connects to color options managed by the ColorSync Utility.
Provides the option of including a cover page or not with your prints.
Select your MEDIA TYPE and INK. You can also create and save CUSTOM SETTINGS through this area.
Adjusts BRIGHTNESS, CONTRAST, SATURATION, and INK balance. Also gives ability to allow COLORSYNC to control all printer colors.
Provides the option for printing on thick paper and envelopes * This option may not be present with all models.
Details settings chosen in other options.
After making the changes appropriate to your set up and print job, click on PRINT.
Aug 19, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Page printing
If the dimensions of the picture your trying to print are not in a 2:3 ratio (same ratio as 4 x 6), it cannot fill the entire 4 x 6 area without distorting the image, i.e., you would have to "stretch" the dimension which has white margins right now to fill the paper. To print an undistorted borderless image, you will have to "crop" the picture so that the remaining dimensions are in a 2:3 ratio.
May 27, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
Printing from iphoto - photos are not 4x6 and not borderless
wat pc do u have? are u using mac? if ur using microsoft try these:
go to ur printer and faxes - right click on ur hp printer icon - select preferences - select printer shortcut tab - select the appropriate size - the click ok. that should solve ur problem
Mar 27, 2008 | HP Photosmart C6180 All-In-One InkJet...
Reprinting photos
try using a ruler to check if you have the correct paper size.
open up HP Solution Center verify the printer settings..
use borderless printing, paper size 4 x 6.
Dec 27, 2007 | HP Photosmart C6180 All-In-One InkJet...
Canon PIXMA MP610 InkJet Printer Logo
334 people viewed this question
old marine
old marine
