Question about Fujitsu Fi 60F Flatbed Scanner 8/24bit 600dpi USB PA03420B-005
I wish to know if Fujitsu fi-60f scanner will work with USB connection to Mac computer using Mac OSX 10.7.5 - 10.8.2
Will this scanner work with a Mac via USB running Mac OSX 10.7.5 - 10.8.2
    Problem Solver:
  • 6 Answers
Yes it will work just fine. Mac OS supports basically 99% of USB printers.
Posted on Dec 17, 2012
SOURCE: looking for a win 7 driver for a Fujitsu fi-4220c
pls give me the software & dirver for scaner fi4220c2.merci!
Posted on Feb 28, 2011
admin734
  • 268 Answers
SOURCE: DOWNLOAD DRIVERS
Here are the drivers for that scanner , but from a diffrent website:
http://www.driversdownload.org/download-driver,9484,Fujitsu_fi-4120C_Scanner_ISIS_Driver_1_dot_5_dot_10307_dot_3002_Windows.html
Just load that page and wait about 15 seconds and the download should start....let me know if it works for you.
Posted on Oct 02, 2008
dragon_sun25
  • 107 Answers
SOURCE: Will the Fujitsu ScanSnap FI-4110EOX2 scanner work with Vista
Vista is not listed as a supported os.
Posted on Dec 10, 2008
TechSatya
  • 104 Answers
SOURCE: fi-4120c2 error Code
The scanner does self-diagnostic when receiving Read Command (to start scanning) and displays the result if any error or alarm is detected.
Error code-E3 in Fi-4120c2 scanner means "Light intensity check" . When this error is displayed on the scanner panel, TWAIN displays the following error-
" Irregular status is detected in scanner. If this status recurs after power cycling, please give following Sense key and ASC code to your service provider.
If ASC code is the following, please confirm following status before power cycling’
- When ASC=0x580, confirm if the shipping lock (if any) is set at “Release” position.
- When ASC=0x680, clean the sheet guide (white part) in ADF.
(Error Code DS42001)
E3 explains Optical alarm (back). This alarm occurs if the gain adjustment of the CCD amplifier does not succeed at a READ command for the first document, or during scanning.
Probable causes:
- The lamp, the optical system or white sheet guide is dirty.
- Defective lamp or CCD.
- Connector disconnected
To check and resolve the issue, lease follow the steps provided below:
1. Is sheet guide (white part) in the reading position dirty?
#Open the ADF and clean the sheet guide (white part) and the glass.
2. Is the lamp ON?
3. Are the cables damaged?
4. Are the connectors connected correctly?
#Disconnect SCSI cable and turn the scanner ON. Open the ADF and press Cover open sensor to see if the lamp lights. If not, the error is caused by the defective lamp.
5. Is the optical unit dirty?
6. Are the cables damaged?
7. Are the connectors connected correctly?
# Check and Clean (ADF back):
# Check if inside of the grass for Upper unit ASSY is dirty. Clean inside of the glass of the dust cover.
9. If the issue still persists, then you may have to replace Optical unit.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Posted on Jul 27, 2010
TechSatya
  • 104 Answers
SOURCE: I hope someone knows of an fi-4530c driver capable
Please be informed currently Windows-7 64-bit supported version of TWAIN & ISIS drivers for your Fi-4530C model is not yet released by Fujitsu. For more information, please visit the following link:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/index.html#twain
You may also contact Fujitsu Support for further assistance.
Hope the above information is helpful.
Thank you for contacting FixYa.
Regards,
TechSatya
Posted on Aug 01, 2010
Testimonial: "Thanks TechSatya, :-) I hoped there may have been a 3rd party driver around. Perhaps scanner systems are a bit too proprietary for that."
Error 2148285
What driver are you using no twain suggests that the driver is not twain compliant. You may need to update the driver with the correct operating system like windows (whatever it is) or is it MAC OS .
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/fi-series.html
Apr 21, 2014 | Fujitsu Fi-4120c2
Regards,
TechSatya
Aug 01, 2010 | Fujitsu fi-4530C Pass-Through Scanner
Trying to instal fujitsu fi 5120c scanner on new computer wont work
did you use the software for it? if still it doesn't work, it could be the usb wire problem or the computer's usb port that doesn't recognise the scanner.
Jun 11, 2010 | Fujitsu fi-5120C
Fujitsu fi-5750c Flatbed Scanner need to
The back panel of the scanner should have a USB connection to the right of the SCSI ID selection switch (the farthest right on the back). Just get from any source a standard male/male A/B USB cable.
Then get the correct drivers here: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/twain/v921720c.html . Additional software may be found here: http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/drivers-downloads_index.html
I hope this helps.
Apr 30, 2010 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu fi-4120c scanner on Windows 7
Hi ocdaveymac
Fujitsu fi-4120c scanner drivers can be found at
driverupdate us .
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Mar 09, 2010 | Fujitsu fi-4120C Path-Through Scanner
Is there a firmware update for this scanner, the
Thank you for contacting Fixya.
Firmware update for your Fujitsu Fi-5750C scanner is available. However, this may not be available to download.Hence, you need to contact Fujitsu Technical Support for the same.
Regards,
TechSatya
Jan 27, 2010 | Fujitsu fi-5750C Flatbed Scanner
Fi=5120c conflict with another scanner
Kindly reply back immediately once you get my email.
Nov 04, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
USB Device
updated drivers.
Hot and fresh. straight from the web!
http://static.agfa.com/digicam_scanner_drivers/scanner/snapscan_e52/index.html
osX is included on the page.
Jan 26, 2008 | Agfa SnapScan E52 Flatbed Scanner
Fujitsu Fi 60F Flatbed Scanner 8/24bit 600dpi USB PA03420B-005 Logo
396 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
