Question about Ovens
Diplomat 600ga oven grill igniter continues to spark after lighting gas
5 Suggested Answers
gasman44
  • 83 Answers
SOURCE: My grill won't light
Hi
Forgive me for asking this, but you have read the instructions haven't you?
If you have, and it's still not working, then the likelihood is that there is a fault, this could be one of the following:
Faulty solenoid valve to grill (some grills had a safety button fitted to stop you from closing the door if the grill was being used)
Blocked pipe inside unit
Either way you need to get a qualified gas engineer to take a look at it, if it's under warrranty call the manufacturers first!
I hope this helps
Steve :)
Posted on Jul 14, 2009
  • 30 Answers
SOURCE: grill ignition is sparking when the oven is on
if the grill is constant sparking when the oven was on and turns off when the oven is not in use then u either have a defective pcb/ht lead or electrode if it is self lighting or if you have to push in a button then this button or control will have a problem
Posted on Aug 21, 2009
ianem
SOURCE: Top oven and grill of my Diplomat ADP4520 double
there is a problem in the wire connection that can cause a short circuit.
Posted on Nov 11, 2009
SOURCE: Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Posted on Dec 10, 2009
How can I stop the oven igniter continuing to spark after the oven has lit
This should not be a problem as the setup is it doesn't know which gas knob has been turned on, therefore the oven and grill spark to ignite either .
Hope this is helpful
Regards
John
PS if I had known the make and model number you can probably get a manual online.
Oct 31, 2014 | Ovens
The ignition continues after gas lights on new world elegance/cooker and grill
The igniter will glow orange while the oven is on. This is NORMAL. If it went out the burner would not come back on when the thermostat calls for heat .
Aug 18, 2014 | New World G90m Gas Double Oven
Diplomat adp 0511 grill has no gas or ignition
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system.
I offer free advice bcuz God is so good!
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Jan 18, 2013 | Belling XOU592 / XOU593 Electric Double...
Hi there, I have a belling gas oven cooker, which when you try to ignite the oven or grill it keeps ticking but wont spark up. The gas is fine as you can light them manually and the hobs light fine so...
why would they be trying to light an electric oven ( see which product do you think they mean ) You need to check that the spark being produced is close enough to the gas outlet
Oct 03, 2012 | Ovens
I have an electrolux EOG6330 gas oven and when I light the grill the igniter continues to spark,the only wayto stop it,is to turn the grill off.Any body know what causes it and how to sort it?
Hello dishboy,
There are 2 possibilites causing that
1) The electrode(spark plug) for the grill is is built up with a bunch of grime and not telling the spark module the burner is lit and turn off the spark. The electrode could be cleaned with the green srubby side if a kitchen sponge,or relpaced.
2) The electrode is telling the spark module to turn off but the spark module isn't responding, to turn off the spark. The spark module would need to be replaced
I hope this helps,
Gene
Aug 04, 2011 | Electrolux EOG6330 Gas Single Oven
My 900GRa Rotostar Gas Double Oven & Grill . When i switch on the Grill it continues to spark but the gas seems to cut off after few moments then the green light flashes on the turn on switch ? Please...
I had a problem with my gas double oven not lighting some time back !
The problem was solved when i took the oven out and cleaned out the Air Fan duct which was clogged up with fiber & Dust stopping the intake of Air !
Dec 22, 2010 | Ovens
I have had 3 engineers out to try and fix my stoves 720gra cooker and has changed all the printed circuit boards ,and all other parts but still the top oven and grill doesnt work and has now been classed...
check the voltage on the spark generator,should be 240dc or 110 ac.
or it could be the harness(wires fron spark generator to ignition) to check harness do a continuity test,an electricion will know,or get a electirc tester and do it with the instructions.
Oct 01, 2009 | Stoves Premier 720GRa Gas Double Oven
Grill ignition is sparking when the oven is on
Aug 21, 2009 | New World G70m Gas Double Oven
Diplomat softline oven with separate grill
grill will not light, door was shut when grill was on.
Nov 05, 2008 | Ovens
Hotpoint dy230gx
it is normal for the grill electrode to spark as well when lighting main oven - i assume you don't mean that the grill lights - just sparks
Jun 29, 2008 | Hotpoint SY21 Style Line Gas Single Oven
Ovens Logo
131 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
