My problem is when i goto auto cal my sony ht-ddw8600 it gets to the surround right speaker the screen says "protect" then turns itself off after a few seconds. I saw a post that said maybe a bit of stray wire could be shorting the termnals of the speaker. Ive sussed it out as much as i can without taking the back off the speakerbox and i cant find a short anywhere. Anyone know how to open these speaker boxes.
SOURCE: HT-DB120 - PROTECTION due to shorted output stage
i have the same problem. was playing a cd for my son for about 20 mins. CD started skipping then froze up and shut off. When trying to power on the word "PROTECTION" comes on then shuts right off. Is there any solution for this problem? My husband bought this when it first came out over 6 years ago at $400. I bearly even use it. It's a waste to throw away. Please someone help. Thanks.
Posted on Apr 29, 2008
Benimur
  • 6966 Answers
SOURCE: I have a Kenwood KR-V7030
Since it was just recently installed, would it be safe to assume that it is fairly new? If yes, perhaps your best bet would be to return to dealer/manufacturer for repairs/replacement. It is highly probable that the unit has sustained major hardware fault at least on the right channel. Even if it were just a fuse, it would still be to your advantage going that route.
Should for some reason you would venture a DIY, diagnosis and repairs of course would require fair familiarity with electronic components and circuitry, use of a VM and a soldering iron and preferable access to a service manual or at the very least a schematic diagram with voltage readings.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 29, 2008
SOURCE: Denon AVR-1508 Receiver problems - cuts off and goes into protect mode
i have the same problem . denon had changed knob and circuits ?! one day later ... same issue !
i have 5.1 evo tangent 4-8ohms and 2 technics 8ohmsand i use frquently A+B configuration
Posted on Nov 08, 2008
SOURCE: Prima HT 8104 home theatre
in the 3D processing turn on the Pro Logic and the for the mode as well set it to pro logic.
it simulates 5.1 surround.
this is what I did and it's decent. Other way would be to run the system through a amp/receiver that supports 5.1 surround.
Posted on Apr 27, 2009
  • 4 Answers
SOURCE: Blue screen after 5 seconds took the back off and saw Green Lamp turn off
Just fixed mine with the same problem you all described:
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on May 19, 2009
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
My HT-Z310 surround sound says protect
The amplifier has a bad channel, the power supply is bad, or the amplifier is drawing too much power.The speakers could also be wrong, if they are not the speakers that came ith th unit, they will need to be replaced. (Any speakers within the specs of the amplifier will work, so to that end the system is customizable. You can go to Samsung.com to find the amplifier's wattage per channel, but the speakers you get MUST be 3 ohms impedance.) I have an article/tip/how-to as to wiring multiple speakers to one channel.
Jun 17, 2010 | Samsung HT-Z310T Theater System
Sony HT 6500 receiver...center speaker jack crackles as soon as speaker wire is connected to it. Tried new wire, new speakers...same thing. Tried to reset to factory settings...ONly L and R front speakers...
try to spray contact cleaner into the speaker port itself.. Powered off of course.. let it dry and try again.. this will clean any connectivity issues due to bad contacts.. as far as replacing jacks.. try the suspected "bad" speaker and wiring in another port.. if it works then the speaker and wiring is good and you have to check actual jack in which you were asking and back to auto amplifier circuit or transistors.
Dec 16, 2009 | Sony Audio Players & Recorders
SONY HT-DWW1600. WHEN GETS NICE AND LOUD TURNS ITSELF OFF AND SAYS PROTECT ON THE DISPLAY. HELP!!!!!!!!!!!!!!!!
It is getting too warm and shutting down to protect itself. This could be caused by insufficient ventilation or by shorted speaker wires.
Feb 26, 2009 | Sony STR-DE625
ERROR 12 - but all the speakers work. why?
The manual lists no error code 12. Check that all speakers are in the correct place in the room and that they are not out of phase (that on each speaker positive is connected to positive on the receiver and negative is to negative). Make sure that the mic is laying flat, and that the room is quiet. If using a sub woofer switch the speakers to small.
Jan 29, 2009 | Sony STR-DG500 System
Problem "protect"
Hey guys, just had the same problem and found out it was because I had disconnected the central speaker. This it was creating a back impedance or something and reonnecting did the trick! i.e. check your speaker connections and check that they work... duff speakers could cause the problem too!
Sep 20, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Onkyo HT-SR800 the surround speakers are not blasting
I had the same problem and fixed it by manually setting the surround speakers changing the Level Cal to +12dB. You will immediately notice a significant increase in volume and may need to back down on the dB's. What a diffence it makes!
Sep 14, 2008 | Onkyo HT-SR800 System
Surround sound keeps shuting off
the system go to protect mode in case of trouble in output stage(power output component and cords and speakers.
try to connect each speaker one by one until you find the bad one change cord first for the bad one and check if not working you must change speaker itself.if all above does not solve the problem you must pass your sony to service center
Mar 23, 2008 | Sony HT-DDW700 System
Sony HT-7000DH
Go to pg. 48 of Sony HT-7000Dh manual. Also I sogest to connect Coaxial Digital Audio Output from Toshiba TV to Sony receiver.
Mar 15, 2007 | Sony HT-7000DH System
16 people viewed this question
 Grubhead
Grubhead
