Question about Diesel Audio NS-600 Car Audio Amplifier
Diesel audio NS-600
Can i bridge two 10's with my diesel audio NS-600 to 2 ohms or does it have to stay at 4 ohms
  • 113 Answers
It can be done providing it isn't driven too hard.
Posted on Aug 08, 2007
How can I connect it to get the most power out of it?
What load is the amplifier designed to drive? It will only deliver maximum power into the optimum load. The loudspeakers are probably 4 Ohms, but the amplifier may well be able to drive 2 Ohms per channel. This means that you need to fit two more loudspeakers This is probably not possible. Alternatively, if the amplifier can be bridged AND can safely drive 2 Ohms bridged or 1 Ohm per channel, you should connect the two loudspeakers together (+ to + and - to -) and connect them to the amplifier output terminals indicated for bridge (often Left + and Right + but sometimes Left + and Right -). If the amplifier can't drive 2 Ohms bridged, do not connect the loudspeakers together, buy another amplifier and connect one loudspeaker to each, with both amps in bridge mode.
Remember that loudspeaker and amplifier power ratings are always massively inflated in the manufacturers' data, often by a factor of 4 and sometimes by 10 or more. You speakers may not be able to cope with a whole amplifier each, so proceed with caution.
Jun 07, 2015 | Pyle 2 Channel 4000 Watt High Power MOSFET...
How many watts does a audiobahn a1502dp have
  • RMS Power Rating:
    • 150 watts x 2 chan. @ 4 ohms
    • 300 watts x 2 chan. @ 2 ohms
    • 450 watts x 2 chan. @ 1 ohm
    • Bridged, 300 watts x 1 chan. @ 4 ohms
    • Bridged, 600 watts x 1 chan. @ 2 ohms
  • http://www.sonicelectronix.com/item_2304_Audiobahn-A1502DP.html
    Feb 23, 2011 | AudioBahn A1502DP Car Audio Amplifier
    ON MY Pioneer PRS-X720 Car Audio Amplifier WHEN I TRY TO HOOK UP THE BRIDGE LITTLE SOUNDS COMES OUT THE SPEAKERS I HAVE TWO 12S MTX THUNDER IN THEY ARE IN A 2OHMS BOX BUT WHEN I HOOK UP JUST ONE CHANNEL...
    From the specs this amp can only handle 4ohms when bridged but can handle 2ohms when it's not bridged
    Specifications
    • Continuous Power (20Hz-20kHz, 0.04% THD)
      • 2 ch: (4 Ohm) 100Wx2
      • 2 ch: (2 Ohm) 200Wx2
      • 1 ch: (4 Ohm) 400Wx1
    • Maximum Power (EIAJ)
      • 2 ch: (4 Ohm) 250Wx2
      • 1 ch: (4 Ohm) 750Wx1
    • Frequency Response: 10Hz - 50kHz (0,-1dB)
    • Total Harmonic Distortion: <0.01% (1kHz, 4 Ohm)
    • Signal-to-Noise Ratio: >105dB (IHF-A Weighted, at 1kHz)
    • Dimensions: 10-3/8" x 2-1/2" x 13-5/8"
    Hope that helps.
    Nov 08, 2010 | Pioneer PRS-X720 Car Audio Amplifier
    I have a 250 watt / 4 ohm subwoofer i have a diesel 700w amp / 2 channel / hpf or lpf with bass boost. i dont have speaker wires and want to utilize my to speakers in the back of my 2008 mustang to...
    if you are trying to use it with the stock headunit you would need to buy a line output converter to use your amp and sub. after you buy the converter you will then need to splice into one of your rear speaker wires so you can run the rca's to the amp and continue with normal install
    Aug 10, 2010 | Diesel Audio NS-700 Car Audio Amplifier
    A3200e wattage
    Here are some specs:
  • 4800W Max, High-Current 2-Channel Car Amplifier
  • RMS Power Rating:
    • 300 watts x 2 chan. @ 4 ohms
    • 600 watts x 2 chan. @ 2 ohms
    • 1200 watts x 2 chan. @ 1 ohm
    • Bridged:
      • 600 watts x 1 chan. @ 4 ohms
      • 1200 watts x 1 chan. @ 2 ohms
      • 2400 watts x 1 chan. @ 1 ohm
  • Max Power Output: 4800 watts @ 1 ohm
  • this is the web site I got the specs from
  • http://www.sonicelectronix.com/item_61_Audiobahn+A2300HCT.html
  • Hope this Helps...
  • Jul 22, 2009 | AudioBahn A2300HCT Car Audio Amplifier
    Installing two amps
    No, thats what you don't what to do. Even if you have 2 matching amps you don't do that. Every amp puts out different, and for 2 subs, you want to play at the the same time. If your only running 2 10's, I personal would just run the alpine (it's a mono amp made especially for subs) thats plenty for what you have. make sure you bridge them to get the full response. And your other amp i would use for your highs or mids, but run it @ stereo , which is 300 w @ 4 ohms. (Note: 600w @ 2ohms would be bridged and would play in Mono)
    Building Competition stereo's is a big hobby of mine.
    May 04, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
    I'm having problems getting full power to my sub.
    when bridgeing an amplifier it always sees half of whatever load you have on it, so if you have a 4ohm speaker when it is bridged the amp will see 2ohms, so yes you can bridge the 4 ohm speaker
    Mar 05, 2009 | Bazooka ELA500.1 Car Audio Amplifier
    What are the correct spaekers for the gm 5100t ?
      CEA-2006 Compliant Amplifier Power Standard:
    • 125 Watts x 2 @ 4 ohms <= 1% THD+N
    • 380 Watts x 1 @ 4 ohms BRIDGE <=1% THD+N
    • 75 dBA Signal-to-Noise Ratio
    • Peak Music Power: 250W x 2 (4 ohm) / 760W x 1 (Bridge)
    • 2 Channels
    • Continuous Power @ 4 Ohm: 125W x 2
    • Continuous Power @ 2 Ohm: 190W x 2
    • Continuous Power Bridged @ 4 Ohm: 380W x 1
    • Frequency Response: 10Hz-50kHz
    • THD (1kHz, 4 Ohm): <0.015%
    • Signal to Noise Ratio: >95dB
    • Dimensions: 11 13/16” x 2 3/8” x 12 7/8”
    • PWM Regulated MOSFET Power Supply
    • Balanced Isolator Input Circuit
    • Oversized Screw-Type Power/Ground Terminals
    • 2 Channel RCA Inputs
    • Speaker Level Input
    • Screw-Type Speaker Terminals
    • Hi-Volt Input Level Control (200mV-6.5V)
    • Bass Boost (50Hz, 0/6/12dB)
    • Selectable LPF (80Hz, -12dB/Oct.)
    • Pioneer 1-Year Warranty
    I'm assuming the subwoofers were bridged and couldn't handle the power. Make sure you have atleast 300 watts peak power wattage.
    Feb 05, 2009 | Pioneer GM-5100T Car Audio Amplifier
    Speakers
    400 watts delivered to 300 watt speakers the only way to do this would be to wire two subwoofers in series so that the power needed to drive them will be 600 watts to max, however this will increase your impedance on the speaker (8 ohms) load so what you can do to compensate is get an 8 ohm 600 watt resistor and put it in parallel with the speakers you will then have 4 ohms of impedance at a total capacity of 600 watts of power In other words the amplifier won't blow these out now.
    Oct 08, 2007 | Pioneer GM-X722 Car Audio Amplifier
    Speakers
    Hi Trim God,
    I do not reccommend that you push the Pioneer speakers over 100 watts.  The jenson will already drown the car with bass through your pioneers so much you will want to turn off the bass boost when playing some low bass hip hop songs. It changes from one venue of song to another, so I just keep the jenson bass boost off and use my head unit to adjsut the sound to fit my listening prefences. I am telling you man, you will be blown away .  Hook up the pioneers straight to the Channels,. do not bridge.  I put Subs in my truck though.  I used the Pass output to send the audio to me Jenson 2 Channel 600W amp. I drive one 10 inch enclosed JBL Class A/B Sub. I bridged the output of the 600 W amp to the 10 inch sub  in my Z28.  The pioneers never get drowned out.  I did smoke my 2 channel Amp one time. and also took out a MTD 10inch sub. I am talk shooting flames and smoked the whole car up. I think if you bride the XA4150 to the pioneers, you will have the flaming smoke problem in no time.
    Oct 02, 2007 | Jensen XA4150 Car Audio Amplifier
    Car Audio & Video Logo
    119 people viewed this question
    Top Diesel Audio Car Audio & Video Experts
    chad zink
    Tom Chichester
    Are you a Diesel Audio Car Audio and Video Expert? Answer questions, earn points and help others
