Question about Compaq FP 7317 17" LCD Monitor
Light the light of the screen falls uot after a while. I can see what I was doing, but I've a black screen and I can see a little bit of of what I suppossed to see. i don't know that this is enmough information greetz, kevin
    Problem Solver:
  • 17 Answers
Make sure you unplug the power the monitor and let it set for 5-10 Minutes to drain off any residual voltage. I just repaired a FP7317 with the same problem. I cleaned up bad soldering and there are 2 small transistors that are marked 2N7000. on the end of the circuit board where the lamps plug in. The are N Channel Field Effect Transistors that are for high speed, high voltage switching. One of these went open on the monitor,I replaced the pair of Transistors and it's now working fine. There's a monitoring circuit on the power supply for backlights, whether it be on a Monitor or LCD TV. If one output to a lamp goes out, the comparator senses it and shuts all the outputs down. This is known as "Protection Mode" Had the same thing happen on a 32" Funai LCD TV. It was given to me and I replaced a $5 transformer and now it's working well. I also changed out the Electrolytic caps in the power supply while I had the board out just in case one of those let go later on. The monitor worked with just the transistor replacement though. Good luck, I hope this helps.
Posted on Oct 29, 2009
Emachines e528 load to blank black screen after windows loading
Sounds like you lost your Operating system, Probably going to require a reformat to repair
Apr 12, 2013 | MSI Emachines E528 Original Laptop Genuine...
Black screen- fixable?
probably a faulty internal PSU, changing the capacitors on the on-board PCB should fix it but hard to tell without opening it up and testing.
Apr 26, 2012 | Hannspree XV32 32 in. LCD Television
My phone has a blank screen but still works how do i fix it ?
There might be a Hardware issue with the display you need to walk into the service center to get it repaired.
Thank you fro using Fixya.
Nov 16, 2009 | Sony Ericsson w580i Cellular Phone
The rotating arm at the bottom of my LG intello dishwasher keeps falling off. It is the stainless bit that sits ontop of the rotating bit at the bottom of the machine. A bit like a boomerang shape and is...
If it is the type with push -fit prongs, these can wear to the point that they do come off completely.
If you can identify which part is worn, you only need order that as a replacement.
You should be able to replace this yourself without a service tech.
If you cannot find a replacement online - try LG directly.
Aug 05, 2009 | Dishwashers
Bernina 640 screen goes black
either an s print or l print problem, take to dealer
Aug 04, 2009 | Bernina Artista 180
I have a Sony KP-57WS500 and there are arched, thin, and horizontal lines that appear.  Where could I find agreen picture tube or can I adjust the voltage myself?
Remove the front speaker grill and you will find an access panel (2 screws are hidden behind 2 little plastic caps at very bottom of speaker grill,just pop uot to access screws) .Remove the panel and you will see the picture tubes.In the middle you will see a little black control pack with 6 little knobs.The 2 in the middle are the green controls.They will be labled screen and focus.You will have to look hard for which is which.There may be glue over the controls if so just remove it.Slightly rock the screen control back and forth to adjust retrace lines out.If the unit shuts down during this process back it off a little and turn the set back on and proceed.
Jan 15, 2009 | Sony KP-57WS500 57" Rear Projection...
Motorola w755 front screen
describe "a little bit at a time". do you mean for a few seconds, then goes black? Or do you mean for a fraction of a second?
Dec 25, 2008 | Motorola Mobility MOTO W755 Cellular Phone
NO PICTURE
it is you senser that when you take the back end of your cover off there is a little chip there just tape it lol
Apr 18, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Compaq FP 7317 17" LCD Monitor Logo
122 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
