Question about Husky Portable generator
Husky generator cuts off after running 3-5 min start on first pull
2 Suggested Answers
codi_medford
  • 8 Answers
SOURCE: husky generator 1850 watt wont stay running
does ithave fresh gas theres a chance there is water in the gas if thats not the case is the choke could be stuck on or the carb. is gummed up
Posted on Oct 29, 2012
Generator
I suggest that the rings are now soft or broken and not sealing or the valves are stuck open unless it is a 2 stroke. Gen sets have a low oil cut out switch that stops the motor immediately there is insufficient oil in the sump. I wonder why it allowed you to run the engine for 10 minutes as it will not even allow you to start with no oil.
Jun 07, 2013 | Electrical Supplies
Husky generator 1850 watt wont stay running
Oct 28, 2012 | Husky Electrical Supplies
Husky generator won't start
did you try cleaning the conductor that goes to the spark plug if not try to clean it with a real fine sand paper it should do the job.
Oct 27, 2012 | Husky Portable generator
Generator won't start
model# 1971 starts on first pull runs about 3 minutes and cuts off
Jun 30, 2011 | Briggs Stratton H7159 & StrattonĀ® 5500,...
I have a Husky 435 model that is less than 2 years old and as cut only about a cord and a half of lumber . The saw runs fine when it is running the problem is getting it started in the first place . I...
It should start easily, start with fresh fuel/oil, pump the primer as many times as it takes to 3/4 fill the bulb, pull the choke fully out, crank the engine until it fires once, push the choke fully in and crank again until it fires up, after re fueling a warm engine, pump the primer again until it 3/4 fills the bulb,before cranking the engine pull the choke fully out and in again( this will engage the part throttle ) then crank the engine until it fires up.
May 15, 2011 | Garden
Hi there, I got the Husky 240e, with only ~4h of running. my problem is that the chainsaw starts smoothly but when pressing the throttle it is suffocates and turned off. When gently squeezing the...
The symptoms indicate lean running, so check the fuel filter for plugging and the fuel lines for decay or other damage. Husky seems be having troubles with our ethanol treated fuel and may require some warranty attention. We have a year old 435 Husky that would not start after about 3 days of excellent running--warranty replaced the carburetor which seems to have us working well now. Good luck!
Aug 09, 2010 | Husky Husqvarna Chain Saw 240E w 16in bar
My honda gx160 generator keeps cutting out after 2 mins
Sounds like fuel flow is restricted.
Is the vent cap on the gas tank clear?
Pull the fuel hose off at the carb and let run into a container from the tank......is fuel flow good while filling a cup or two worth of fuel?
If not check filter at fuel switch or at hose connection at tank for restriction.
It takes about 2 minutes to use up fuel in the carb with engine running.
Sure sounds like a fuel problem.
Sep 06, 2009 | Master Heaters MASTER HONDA POWERED...
Husky 445, runs for 10 min. then cuts out. I open
It sounds as it the fuel tank is getting vacuum locked, in the same way as if you were to dip a drinking straw in to a liquid then tightly placing your finger over the the top of the straw then lifting it up, the liquid remains in the straw, its only until air is allowed to enter the top of the straw that the vacuum is released allowing liquid to escape.
This condition is caused by a faulty fuel cap vent, whereas in the fuel tank, air needs to replace the fuel that is consumed while running.
Hope this helps ...Good luck
Aduz
Mar 27, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husky Portable generator Logo
18 people viewed this question
Top Husky Electrical Supplies Experts
JOHN LAPIER
L Pfaff
L Pfaff
Are you a Husky Electrical Supply Expert? Answer questions, earn points and help others
