Question about Refrigerators
Icing in Freezer Compartment
Hotpoint refrigerator with freezer on top. No ice maker. Ice builds up on the bottom of the freezer and has to be chipped away weekly. Water also drains in the refrigerator under the fruit/vegetable bins and drips out when you open the refrigerator door. I've adjusted the temperature several times but it doesn't solve the problem.
  • 163 Answers
Hi!! your drain line is plugged its inside your freezer compartment. look at the back wall on your freezer and fins you see is called evaporator try to remove the cover and get a hair dryer and melt all the ice that you see in the bottom portion of the should see a small hole at the bottom of the evaporator that your drain line unplugg it..Or you can do it the old fashion way just turn it of complete for 2 days and all is fine..Good luck..
Posted on Jan 04, 2009
Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Jun 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Hidden Ice build-up inside plastic bottom cover of freezer
Generally, icing is the result of too much water vapor inside the unit, blockage of the circulation channels and too much packing in of the box.  The water vapor is generally caused by: uncapped items in the fridge, opening the door too often, humid conditions, bad door seals.  There is of course, there is a possibility that the defrost cycle on the unit is not working.  About once a day, depending on the brand, you should notice that the fans and compressor don't run and you should hear a bit of creaking, sloshing or other strange noises as the ice melts.  If this is not happening, your defrost timer or the coil it heats could be bad.
Nov 12, 2008 | Refrigerators
Ice build-up in freezer - Kenmore Model C978-66795-2
don't know this appliance but for guidence:
some appliances have the evaporator in a compartment at the top of the freezer and the drain comes out of the back and runs externally to the drip tray. there should be a grill in the compartment so just peer into it and see if there is ice build up.
wherabouts is the freezer ice forming?
Sep 04, 2008 | Refrigerators
Ice in freezer compartment
Check to see if your drain tube is clear. Sometimes it freezes up at the base of the rear cover in these bottom freezers. Causing an ice dam.
Jun 30, 2008 | LG LFD22860 Stainless Steel Bottom Freezer...
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Bottom of Maytag Freezer Ices Up
You have a plugged defrost drain. easiest way to fix it is unload freezer compartment defrost all of the ice, then remove the 2 screws that hold the rear cover in place about half way down the back wall. once this is removed use hot water to flush out the aluminum evap pan at the bottom of the coil. once it is cleared i will usually pur a little bleach in to kill any algae build up.\
be sure to unplug the refrig and use caution not to cut your self on the evap coil as the fins are very sharp..
Dec 16, 2007 | Refrigerators
Hotpoint Side by Side leak and cooling issue
fault is poss that drain for defrost water is blocked and this can cause both faults. remove back cover of freezer and check if ice build up. if so melt of with hairdryer and make sure drain is also free of ice
Feb 15, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
119 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
