Question about Vtech V.Smile TV Learning System
Turns on then imeditely turns off
I have the V-tech Vsmile(orange) hooked to a TV through a game adapter. All color coded cables hooked properly. Channel on TV is correct for adapter. When learning system is turned on the screen shows V-tech Title screen. After a second or two, It goes right back the regular TV channel.
Please help
This has happened to us many times. For us it was because the back cord that connects to the console, had a short in it. We wiggle the back cord a little and it works. It is a pain to do, but we do that instead of getting a new one, since we no longer have the box or receipt for it.
Posted on Jan 05, 2009
When i plug in and turn on without a game in it, the v tech display comes on so system is working. but as soon as i put a game in it(3 different games) the game doesn't come on. i've tried putting game...
you have to do this in the right order or it doesn't work. Start with the TV and Vsmile OFF
step 1) put the cartridge in and make sure it is all the way in
step 2) turn the TV on
step 3) turn the Vsmile on
if it still doesn't work, unplug the adapter or take the batteries out and let the system clear and then do the steps over. Good luck!
Nov 27, 2010 | Vtech V.Smile TV Learning System
V tech tv learning system will not turn on
this system is frustrating because if you don't do the steps in the right order it won't work. Start with the TV and Vsmile OFF.
step1) put the cartridge in and make sure it's all the way in
If it still doesn't work you may have to take the batteries out, or unplug the adapter, whichever power source you are using, to clear it and then start the steps over. Good luck!
Nov 15, 2010 | Vtech V.Smile TV Learning System
I can't turn on the v tech
you have to do the steps in the correct order or the system won't work. Start with the TV and Vsmile OFF
if it still doesn't work you can try taking the batteries out or unplug the adapter to let the system clear. Then try the steps again. Good luck!
Nov 09, 2010 | Vtech V.Smile TV Learning System
My tech v smile system does not start
you have to do the steps in the correct order or this system won't work. Start with the TV and Vsmile OFF
if it still doesn't work you can try taking the batteries out, or unplug the adapter and let the system clear, and then try the steps again. Good luck!
Nov 01, 2010 | Vtech V.Smile TV Learning System
V tech new item..motion console..worked..turned it off turned it on..wont work
make surt you did the steps in the right order. Start with the TV and Vsmile OFF.
step 1) put the cartridge in and make sure it's all the way in
if it still doesn't work, try taking the batteries out or unplug the adapter to let it clear and then try the steps again.
Nov 23, 2009 | Vtech V.Smile TV Learning System
I can not get my daughter v tech to come on
Make sure you followed the correct steps. Start with the TV and Vsmile OFF
if it still doesn't work, try taking the batteries out or unplug the adapter to let the system clear and try the steps again.
Oct 16, 2009 | V.Smile V Smile Console
Hook it up to the tv
If your hooking it directly to the tv depending on how old the tv is use one of the inputs. Hook the two red and white to red and white and the yellow to the video in input. If it's an older tv you will need whats called an rhf adapter. Hook your color codes together and use a cable cord to go from the antenna out to the tv's uhf input. I hope this information was helpful........... : )
May 10, 2009 | Televison & Video
Sound
Have you checked the game settings themsleves? My son accidentally turned the sound off within the game while he was playing. Frustrated me for DAYS!!!
Apr 25, 2009 | Vtech V.Smile TV Learning System
Our Vsmile won't play
Make sure the system is off before inserting any cartrdiges. Things you can try to get the V.Smile TV Learning System to work:
1) Press the Reset – Press and hold the ON button for about 10 seconds
2) Make sure the game is inserted far enough into the system, and that it is pointing in the right direction. You may occasionally need to clean the contacts.
3) Also, make sure you are using the supplied power cord/adapter, not batteries. Batteries cause more problems than they’re worth.
-Tha Mp3 Doctor
Dec 31, 2008 | Vtech V.Smile TV Learning System
Having issues when the games are in the console
Make sure the system is turned off before inserting the cartridges. Things you can try to get the V.Smile TV Learning System to work:
-Tha Mp3 Doctor
Nov 28, 2008 | Vtech V.Smile TV Learning System
Vtech V.Smile TV Learning System Logo
316 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
Are you a Vtech Toy Expert? Answer questions, earn points and help others
