Question about Rheem 40 Gallon FVR NATGAS Water Heater 6 YR 22V40F1
Hardie dux gas hot water system pilot light out
Just moved in and gas hot water system is off, followed directions but pilot light not lighting. what are the taps beside the hot water service for, do they need to be turned? gas is on as gas furnace heater is working.
4 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: pilot light won't stay lit after release of gas valve.tried few t
Most likely it's time to replace the thermocouple, the safety device that makes sure the pilot is lit. New thermocouples are cheap and you can find them at most hardware stores and the big-box places (Home Depot, etc.)
Here is a site with basic information to get you going.
Posted on Apr 08, 2009
alastair1959
  • 7 Answers
SOURCE: Its a 6 year old gas water heater. It was working
Replace the thermocoupler.
Easy fix.
Posted on Jun 23, 2009
  • 1015 Answers
SOURCE: we had to turn the gas off to connect the dryer,
I would suggest that you remove pilot assembly from gas valve and burner and clean pilot orifice and see if that helps. Be careful when cleaning hole in the orifice so you don't enlarge the hole. Good luck and thank you.
Posted on Jan 02, 2011
Wher is pilot light
Why will my pilot light on the gas water heater not stay lit for ...
diy.stackexchange.com/questions/.../why-will-my-pilot-light-on-the-gas-...
Jul 28, 2011 - The pilot light went out on my gas water heater. I followed the ... This could be from a valve not being all the way open. It could also be from a ...
How To Relight Your Pilot Light On Your Water Heater ...
? 7:54
https://www.youtube.com/watch?v=gqM7kMkkFAI
Apr 15, 2013 - Uploaded by TipsNNTricks
How To Relight Your Pilot Light On Your Water Heater. TipsNNTricks .... I answer the following questions in this video. How can I relight my pilot ...
How to Light a Water Heater (with Pictures) - wikiHow
www.wikihow.com/Light-a-Water-Heater
wikiHowJump to Questions and Answers - If the pilot light doesn't relight or goes out immediately after ... if you are unable to light the water heater after several attempts.
Jan 13, 2016 | Water Heaters
Self igniting hot water heater won't reset.
Today's water heaters have sealed combustion chamber and piezo igniter.
If igniter is bad, then water heater will not light... replace igniter.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pilot
http://waterheatertimer.org/How-to-light-gas-water-heater.html
Gene h
Mar 31, 2014 | Water Heaters
Finally found the reset button on my Whirlpool hot water tank, but it will not budge when I push it. Why? Pilot will not light.
Reset button on gas water heater??
Usually there is not a reset button on gas water heater, which might explain why is doesn't move:
Do you mean the igniter button for lighting pilot?? The piezo igniter can go bad.
Copy following links for troubleshoot resources:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add comment with description of water heater, and more detail or call plumber.
Gene
h
Aug 23, 2013 | Water Heaters
How to adjust thermostat on Dux hot water system
Add a comment and say which water heater you have: Gas, electric, solar, tankless, or heat pump. Otherwise expert is just guessing.
Or contact dux, and tell them which model and type heater you have.
http://www.dux.com.au/products/home
Aug 15, 2012 | Water Heaters
Water heater pilot light is out, cant restart intelli vent controller
Possibly the air intake located at bottom of heater needs to be cleaned with feather duster under water heater.
Read your product manual for steps.
Copy following link for general illustration.
http://waterheatertimer.org/images/State-select-air-intake-400.jpg
http://waterheatertimer.org/pdf/Flame-Arrestor-Screen-Cleaning.pdf
Other causes can be bad intellivent gas control valve, poor venting, hot attic, low gas pressure, dirty combustion parts, tripped FV system.
Copy following link for available intellivent troubleshoot resources:
The service manuals are large files and open slowly.
Jul 26, 2012 | Water Heaters
Pilot light keeps going out during hot days
Solution is probably better ventilation to gas water heater.
On hot days, heat and lack of ventilation can cause pilot outage.
Hot air causes oxygen molecules to move farther apart, and combustion is no longer supported so pilot goes out.
Open following links:
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Jul 04, 2011 | Rheem Water Heaters
We had to turn the gas off to connect the dryer, now we can't get the pilot light to turn on. we followed the directions on the water heater 5 or 6 times with no luck. It seems the pilot light will not...
Jan 02, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Natural gas hot water heater not stying lit
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
Dec 17, 2009 | General Electric GE SmartWater Household...
What's up with My Bosch Hot water heater??
it sounds like a thermocoupler
its located inside the unit next to the pilot flame and should be screwed in next to the pilot button at the other end
May 28, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Tankless water heater pilot light will not stay on
It is most likely the water valve stuck open, telling the controls to heat water, that it thinks is flowing through it, but without actual flow it overheats. Depending on how comfortable you are with taking it apart yourself, you could open the valve to see if it just needs cleaned out, or if you have a ruptured diaphragm or some other cause.
Jan 25, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Rheem 40 Gallon FVR NATGAS Water Heater 6 YR 22V40F1 Logo
168 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
