Question about Sewing Machines
How to stich embroidery - Sewing Machines
    New Friend:
You can download embroidery designs online from Applique embroidery designs section.
Posted on Feb 20, 2017
  • Sewing Machines Master
  • 1,564 Answers
That would depend on if you have a regular home sewing machine or a embroidery machine. I'm going to assume that you have a regular machine.
There is something called free hand embroidery. you lower or disengage the feed dogs, take off the presser foot. Some use a darning foot and others just leave the foot off. Hopefully your design is already marked on the fabric. Place fabric in a regular hand embroidery so they fabric is right side up but the hoop makes it sit down in the rings. (make sense) Fit your hoop on the bed of the sewing machine, under the presser foot/presser foot bar. Lower the presser foot lever. (important for tension) and select stitch style and length. you may need to adjust tensions too.
Begin stitching, take a couple stitches... then reverse a couple... then snip the loose ends. Continue to stitch, guiding the hoop so that the needle follows the design. Start slowly and as you discover how your hand movements effect the length of the stitches... you can speed up and slow down as you need to create your design.
https://www.youtube.com/watch?v=ylMy6QdsZr4
Posted on Nov 03, 2012
Hi. I've bought a singer xl-1 embroidery machine and can't get the embroidery stiches to work
Have you talked to the vendor of your machine? It could be defective.
Jun 26, 2017 | Singer Sewing Machines
My embroidery went gray?
if your saying the last layer of your embroidery caused your scene to gray out , this is a stich density adjustment you can make in your chosen stich program , less over lap will make colors stand out more , in this it is less is more
Mar 17, 2016 | Sewing Machines
Embroidery stich is on reverse of fabric?
turn the right side up before starting the work .
May 20, 2015 | Sewing Machines
I have a rose embroidery machine which I haven't used for a while and when I try to embroidery, it will only go as far as the 3rd design and only stitch the first color. What can I do
Hello
The machine is indicating that it "wants" you to move the hoop into position P2 or P3 according to what is blinking. This is normal.
Once that colour is completed stitching, the machine will communicate again for the nest Position.
Happy Stitching
Sewingirl/
Jan 08, 2014 | Husqvarna Rose
How to use stich types like quilting etc
what is the name and model number of the sewing machine?
Dec 10, 2012 | Sewing Machines
Singer 6268 won't work
since your having such problems with the machine, my suggestion would be to take it to a repair shop & let them look at it.
for a computerized part of a machine it depend on the name & model number. & if a generic part will fit on the machine.
the question is what would the cost of repairing the machine--viruses a new sewing machine, good luck with your decision
Jan 20, 2012 | Sewing Machines
After using the embroidery hoop you can not sew in regular mode, feed dogs does not come up and moved the cloth.
My Janome has a metal slide switch for lowering the feed dogs on the base of the machine in front.
Have you raised the feed downs again? Otherwise, turn off so that the current stich selected resets, and then turn on and select straight stich. Try again.
Feb 27, 2011 | Janome Sewing Machines
Husqvarna serger won't sew - everything moves, threaded correctly, no results
re-thread and turn the wheel for the first few stiches, also check out this site Husqvarna Viking Sewing Gallery/Ultimate SEWING PlaceWe will gladly answer any of your questions on the Husqvarna Viking or SINGER ® sewing machines, Embroidery, quilting or sergers that we carry, ...
http://www.vwsewgallery.com/
Aug 28, 2009 | Husqvarna Sewing Machines
Programing
program-controlled sewing or embroidery machine comprising a stitch-forming device (2), an integrated microcomputer (4), at least one memory (16, 17) and at least one data interface (5), as well as a keyboard (12) and a display (11) for entering and monitoring or checking values for program control. To retrieve sewing or embroidery pattern data from a remote computer (mailbox) in a simple manner, the data interface (5) of the sewing or embroidery machine (1) is able to be connected directly to the mailbox (10) of a central computer (9) via a data transmission connection (7) via a corresponding modem (6), and the structural units which are necessary for communication with the mailbox (10), such as display (11), keyboard (12) and memory (16, 17) are disposed in the sewing or embroidery machine (1) itself, with the functional processes necessary for communication with the mailbox (10) being able to be controlled and monitored by the microcomputer (4) necessary for controlling the program of the sewing or embroidery machine. The invention further relates to a method of operating program-controlled sewing or embroidery machines.
Mar 17, 2008 | Elna Quilter's Dream 6003Q
Will not embroidery
Presuming that you know how to correctly operate this machine, this does not sound good. Most often it is an electronic board that has failed. If so, it will be expensive to fix.
Oct 02, 2007 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
125 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
