Question about Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Furnace blower motor turns on with no flame burning
Sometimes my furnace motor will turn on when there is no flame burning. It is a johnson air ease sx 90 high eff furnace. It will run for a couple of minutes and shut off, then sit idle for 30 sec and then the power vent and flame will kick on and the unit will work fine. It doesnt really hurt anything just wanting to know how to fix it. Thanks
  • lweaver597 Jan 05, 2009
    Thanks. I will try it and post the results!
  • 163 Answers
Hi!!! You might have a bad flame sensor its a single rod located in the burners its white..If the unit runs and then shuts off and on and off.change your flame sensor..Good luckk..
Posted on Jan 04, 2009
How do I wire up a Honeywell HE120 so it gets power only when the blower is on?
You didn't say what kind of furnace you have, but here is a link to what is known as an "air flow" switch that will allow the humidifier to operate only when it senses air flow through the furnace:
http://www.alpinehomeair.com/viewproduct.cfm?productID=453057513
Jan 26, 2015 | Honeywell HE120 Humidifier
Is Aprilaire 500M suppose to turn on when furnace motor turns on?
The humidifier should turn on and off with the blower motor of the Furnace. This can be done by wiring the the humidifier to the HUM terminal on the furnace control board and then stepping down the power with a transformer. If the humidifier has it's own tarnsformer then a current sensing relay can be used by attaching it to the blower motors common wire.
Jan 13, 2013 | Aprilaire Humidifiers
Is the humidifier supposed to turn on when the furnace does. Does it turn on more often when the temperature outside is higher.
Hello, Yes the humidifier should turn on when the blower motor on your furnace kicks on, this way you are only using water and power when the furnace is on instead of wasting it when when the furnace is off. Regardless of outside temperature the humidifier will only turn on and off with your furnace.
Jan 21, 2011 | Aprilaire 700 Humidifier
Will the water only come on going thru the water solenoid only when it calls for water? Or is it suppose to come on at all times when furnace comes on?
The water should come thru the solenoid valve when the furnace's blower motor turns on, and turn off when the blower motor turns off.
Jan 04, 2011 | Aprilaire 600 Humidifier
The water runs constantly, not just when the furnace turns on.
Do you have a sail switch or current sensing relay with this humidifier? In order for the humidifer to turn on and off u need either a sail switch that senses airfllow in the return air duct and will turn off the humidifier when the blower motor stop or a current sensing relay that senses current on the blower motors common wire. I will post of pic of each one
Jan 03, 2011 | Aprilaire 700 Humidifier
Instructions on how to install the current sensing relay i had my furnace serviced and the tech told me this is what i need but if i can do it myself id rather the part is $60
You take the current sensing relay and put the blower motors common lead thru it, usually will be the white wire going from motor to control board. Then you take one of the wires from the current sensing relay and attach to humidistat and then take the other wire from current sensing relay and connect to transformer. This way everytime the furnaces blower motor turns on the humidifier will turn on and when the blower turns off so will the humidifier.
Dec 17, 2010 | Aprilaire 50 Current Sensing Relay...
Dry house, albeit have two april aire humidifiers
The reason you can not run your humidifier while the blower is off, is because all the humidity would condense almost immediately and rot out your duct work. If you find that the humidity provided during the cycle of your furnace is inadequate, I would suggest purchasing a table top unit, and keep it in the room where you spend the most time. So, the answer to your question is no, you can not run a humidifier while your blower motor is off. Hope this helps.
Dec 13, 2009 | Aprilaire 700 Humidifier
Furnace blower blows cold air
It is possible that you did not set the new blower on the proper speed. Black wire is high. Blue is medium. Red is low. If the fan is operating to slow it can run to hot and trip the high limit control. Make sure the filters are clean. When the old motor went bad, the problem might not have been discovered rite away your high limit control might need to be changed.
Also anytime you work on a furnace you can kick up some dust. Always clean the flame sensor.
Good Luck
HVAC Teacher
Mar 08, 2009 | Honeywell Power Humidifier: Furnace...
Furnace pilot problem
check the pilot gas pressure, might be too weak and blowing out when the blower starts, the clicking noise is the gas valve shutting down when it detecks no pilot flame, that park is normal.
Jan 10, 2009 | Honeywell Power Humidifier: Furnace...
Humidifiers Logo
334 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
