Question about Maytag PAV2300 Top Load Washer
Agitator not working on Maytag PAV2300
My Maytag PAV2300 is about 7 years old. A few weeks ago we noticed some grinding noise while the machine was agitating. It sounded like a bad bearing but not quite that intense. I am fairly certain that it came from the top part (softener unit) of the agitator because I still can hear that directional bearing making noise when turned manually. The machine was fully functional. Today the agitating movement quit. However, the machine drains and spins as it should. Further observations: The belt is ok and can be moved by hand. All pullies (motor, pump and main shaft) move quietly. I removed the agitator from inside the tub. The engagement between shaft and the large plastic cap is secure and shows no sign of wear. So the shaft of the agitator is not spinning. (I am hesitant to directly confirm that with water in the tub since the grease on the shaft may cause is mess - proofing the obvious.) I removed all the bolts on the outside of the machine but I have trouble removing the cover unit (does it have to be pulled up?) How does the machine with one pulley on the center shaft activate at times the drum (tub) and at other times the agitator shaft ? I hope someone can give me a few hints Frank
  • Frank Gransee May 19, 2007
    Update > I managed to open the machine .. the top has to be unscrewed in the back and the front of the top cover has to be popped up with a wedge. Then the front can be unbolted with two screws and removed.
    For now I can see how I could access all the parts. I found a partlist with explosion views here:http://www.partselect.com/MultiModels.as...
    My shaft does not seem to be broken ... I am still not certain how this whole thing works. I could imagine some cam that engages the shaft when required ?
    What could stop the agitator shaft from turning ?
    Frank
  • Frank Gransee May 21, 2007
    Thank you ...it may be that the transmission is *about* to go (?) because the machine runs like normal again after I took the agitator top pieces (plastic) off, removed the cover (front), checked for debris under the machine and watched the mechanical action without the front cover (while filling the tub and starting the agitating cycle).
    I cannot claim that I fixed something besides some cleaning. (the agitator plastic pieces were -to my surprise- quite dirty from the inside. There was also more dust and stuff under the machine than I would have thought). But I don't think the cleaning actually fixed something.
    After what you wrote I kind of expect the machine to go sometime soon ...
    By the way the odd bearing noise I mentioned comes from the one-way clutch bearing in the upper agitator piece. Not a functional problem.
    Thank you for your advice !
    Frank
    Problem Solver:
  • 11 Answers
Sorry to be the bearer of bad news, but the transmission in your unit is bad,it has internal gears and the ones involved in the agitation are broke or bad, to replace the transmision is a lengthy process, your best bet is to just scrap it and get a new washer. I don't know if you know this but maytag company is no longer in business. They were purchased by Whirlpool back in November of 2006. One of the reasons is all the poor quality of their appliances. I am a technician that has been doing this for 15 years. The best unit I have seen to date is the Whirlpool Duet. I hardly ever have to work on them. Sorry for the bad news. Hope this helps.
Posted on May 20, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Maytag agitator will not turn
Sounds of a loose motor or need brushes replacement.
Jan 13, 2018 | Maytag MAV6457 Top Load Washer
Maytag Performa top loader is making grinding noises
The agitators are a pop-on fit. Make sure that the agitator is firmly seated on the shaft. Lift it up and if it moves easily adjust it to the splines on the shaft and press it back into place.
Jul 29, 2009 | Maytag Performa PAV3200
Spin cycle not working properly
On the transmission there are two shift arms. One shift arm controls the agitator and the other shifts to spin the cloths. If the washer has been making a "clicking" sound when it trys to spin, the solenoid that shifts the spin shift arm is not catching and the drum will not spin. The other possibility is the spin clutch is slipping and make a "grinding/ratcheting" sound. Neither, unfortunately are inexpensive to fix.
If you can describe the sound and when it occurs, I might be able to get closer.
Let me know.
Regards,
May 15, 2009 | Maytag Ensignia MAV4757AWW Top Load Washer
Grinding noise while agitating.
possible foreign substance under agitator
Feb 26, 2009 | Admiral AAV7000A
During agitation it sounds like it is slipping and grinding
It could be a number of issues really.  Smaller issues could be something under the agitator, etc, to moderate problems, like a motor coupler, loose basket, etc.  Could also be a major problem like a motor or transmission.  A lot of times its the motor coupler or pump making the noise.  Both are pretty easy to replace.  Maybe some more information.  Do you happen to know where the noise is coming from?  Is it coming from the front of the cabinet or in the basket area?  Any small water leaks?  Does the spin cycle work ok?  Let me know some other information and maybe we can narrow down the problem to one particuliar area.   Jim
Oct 17, 2007 | Kenmore 24032\24036 Top Load Washer
Maytag MAV6000Aww washer-loud noise when spinning
Chances are it is not the tub. It is probably the transmission. It has been my experience that the transmission bearing starts to make noise. Look under the unit to see if you can spot any transmission oil. If there is oil, it's time to start shopping for a new unit.
Sep 26, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag won't spin or agitate
I have had the same problem and found that the teeth on the under side of the agitator had been worn down to nothing... I assume this is from years of over loading (not from me) and so the agitator could not spin any more... i would tighten the bolt that holds th agitator on and it would come loose after a few loads. So my solution was to get a little bit longer bolt and newer plastic washer and tighten it as tight as i could and it seemed to work. Versus buying a new agitator base that would cost about $20-$30 and would have to wait for the part to be ordered. hope this helps
May 26, 2007 | Maytag PAV2300 Top Load Washer
Grinding niose from agitator.
If the fill and drain functions correctly, AND the spin cycle works correctly, AND the cycle itself starts and completes correctly, the problem being that the back and forth motion of the agitator starts the loud grinding noise, it will likley be broken gears in the transmission. The single most expensive part in the washing machine.
Feb 04, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
621 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
