Question about Samsung UN55B8000 55 in. LCD HDTV
Turn on Keeps blowing the upper fuse. Samsung sure has a bad history of power supplies for their TVs. Anyone know how to fix?
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Three thoughts---check for short to ground with fuse removed and power off (unplugged) on both sides of fuse.
Use a original type fuse---generic ones often blow for no reason.
Consider replacing the board if you can confirm issue is on it.
Posted on Nov 03, 2012
3 Suggested Answers
brownline45
  • 310 Answers
SOURCE: Samsung LN40A530P1F LCD TV keeps blowing main
good day. your power supply is defective. maybe the regulator is shorted. you need a qualified technician to fix your problem.
Posted on Jun 22, 2010
  • 3 Answers
SOURCE: samsung LE23R87BDX LCD TV turns off after a minute
clicking sound is coming from the relays in the power supply. definitely the problem is coming from the power supply, better change it
Posted on Jun 26, 2008
Tv will not power up
First if you are able is to examine the power board---look for any signs of damage or puffed up filter caps..........
Aug 31, 2012 | Samsung UN55B8000 55 in. LCD HDTV
Samsung LN40A530P1F LCD TV keeps blowing main power fuse when i turn set on it blows right away i have replaced fuse many times. Also when back was off i noticed a arcing as fuse blows at a component just...
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=LN40A530P1F
If a fuse blows like that there is a major problem, inside. I suspect that what your are seeing is the inrush thermistor, and they exhibit this under great load. I would explect that this fault maybe in the actual PSU. Due to the lack of service manual support, i would get a quote for repair from an authorised service center.
Jun 22, 2010 | Samsung LN40A530 40 in. LCD TV
My tv keeps blowing a fuse when I turn on set.
DO NOT keep feeding it fuses more damage can accur-check rectifiers in power supply-then check regulator-chech H.O.transistor.if you need more help im gonna need a model number to go furthor
Sep 04, 2009 | Televison & Video
My samsung 40 inch lcd tv is not swiching on it just keeps making a clicking noise
HELLO, I AM ALMOST SURE THAT YOU HAVE BAD CAPACITORS ON THE POWER SUPPLY BOARD, IF YOU OPEN THE SET LOOK FOR THE SWOLLEN CAPS THAT IS A COMMON PROBLEM WITH THIS SAMSUNG LCD TVS
GOOD LUCK
CAYPIANAN@YAHOO.COM
May 10, 2009 | Sanyo DP42746 42 in. Plasma Television
Sanyo 25" TV struck by lightning - where do I begin?
Not to different from arcade, If the fuse is blowing right away check the bridge rectifiers next for shorts and anything on the primary ac to dc side first, Caps,may have a surge suppressor on the ac side. If it was lightning sure you will find it in this area. Secondary supply shorts usualy do not blow fuses, Just cause the supply to shutdown.
Jul 10, 2008 | Sanyo DS32224 TV
Fuse keep blowing off
If the fuse keeps blowing, that is an indication that something has failed and is drawing too much current. Most likely it could be a problem with the power supply, such as a shorted rectifier diode or voltage regulator. Another possibility could be a shorted audio output module. Unfortunately, you'll have to take it to a repair center to be serviced.
Please let me know if I can help you further.
- Jim
Feb 01, 2008 | Sony STR-DE345 Receiver
Samsung Flat Screen Won't turn On
yea take your tv to a tech tv has a problem in the power supply there is 10mf cap in the power supply that likes to go bad replace it if that model does not have it check regulator and the microchip.however your problem lies in the powerand related circuit.good luck
Apr 02, 2007 | Samsung TXN3275HF 32" TV
Samsung UN55B8000 55 in. LCD HDTV Logo
180 people viewed this question
Jerry Greenberg
Jerry Greenberg
