What causes the po41 code - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,462 Answers
The problem post to yours' is not clear. What do you want to know? Provide more details please.
Posted on Nov 03, 2012
Service engine soon light code po41
you missed a digit.
P041x? what is x/?
P0 codes are federal codes.
scan the PCM. and get all DTCs stored.
then post them all.
or read the FSM
the SUZ FSM covers all that.
or read alldata.com
when you get errors, that means the mech, will do tests based on that error, guessing will be $$$$$$$$
Feb 24, 2014 | 2003 Suzuki XL-7
Engine code po41
P0xxx
your code is too short. did you get this at autozoned?
my guess, is P0401, EGR failure.
the #1 all time , common failure.
P0 means USA standard power train codes,
My jukebox is showing error PO41
if its nsm error =wrong price setting
Jan 01, 2014 | Audio Players & Recorders
Will not start p2045 p2197 p0190 p2247 p2245 p2248 p2249 p2518 comes up
code p2045 refers to reductant temperature sensor--high input==causes --wiring faulty sensor
code p2197 refers to heated oxygen sensor(HO2S)1 bank 2-- signal stuck lean===causes HO2S---fuel pressure---injectors---intake leak
also refers to oxygen sensor (O2s)1 bank 2 -signal stuck lean===causes--O2S--fuel pressure---injectors---intake leak
also refers to heated oxygen sensor (HO2S) 1 bank 2--implausible signal===causes wiring---short to ground--short to positive--HO2S---ECM
code po190 refers to fuel rail pressure (FRP) sensor-circuit malfunction===causes --wiring ---fuel rail pressure sensor---ECM
code p2247 refers to heated oxygen sensor (HO2s) 1 bank 1 reference voltage--open circuit===causes--wiring ---ho2s
also refers to o2s 1 bank 2 reference voltage ---open circuit===causes wiring---o2s
also refers to HO2S 1 bank 2 ---no signal===causes wiring--ho2s---ECM
code p2245 refers to HO2S 1 bank 1 --reference voltage --circuit low===causes--wiring short to ground--ho2s also refers to o2s 1 bank 1 circuit low===causes wiring short to ground--o2s
code p2248 refers to the ho2s I bank --performance problem===causes --wiring--ho2s
code p2249 has the same causes short to ground---ho2s and o2s
code p2518 refers to a/c refrigerant pressure sensor B ---circuit high===causes wiring short to positive--a/c refrigerant pressure sensor.
so after all that replace all the ho2s and o2s sensors using the correct tools so that the wiring is not damaged and check the wiring back to the ECM for burns and rub marks.
Dec 30, 2013 | Cars & Trucks
What does a flashing yellow light mean on the joystick? the light looks like the shape of a wrench.
Hi Judy,
According to Pride's troubleshooting documents the service indicator (wrench icon) will flash when a fault is detected by the dynamic controller.
The number of flashes, followed by a 2 second pause, indicates the issue. You will need to count the flashes to determine the cause and a possible solution.
I have typed the flash codes below, but you can also see them on a larger table here: http://www.fixya.com/support/p3641679-pride_jazzy_614_hd_jazzy_614hd/usermanual-6B42026-pdf
FLASH CODES
Code #1
  • Flash Code: One, pause, one
  • Cause: Possible Stall Timeout
  • Possible Solution: Turn joystick off, then on.
Code #2
  • Flash Code: Two, pause, two
  • Cause: Battery Fault
  • Possible Solution: Charge batteries, check battery connections and fuses.
Code #3
  • Flash Code:Three, pause, three
  • Cause: Left Motor Fault
  • Possible Solution: Make sure the left motor is plugged in.
Code #4
  • Flash Code: Four, pause, four
  • Cause: Right Motor Fault
  • Possible Solution: Make sure the right motor is plugged in.
Code #5
  • Flash Code: Five, pause, five
  • Cause: Left Park Brake Fault
  • Possible Solution: Make sure the left brake is not in freewheel mode.
Code #6
  • Flash Code: Six, pause, six
  • Cause: Right Park Brake Fault
  • Possible Solution: Make sure the right brake is not in freewheel mode.
Code #7
  • Flash Code: Seven, pause, seven
  • Cause: Joystick Fault
  • Possible Solution: Check the joystick connection.
Code #8
  • Flash Code: Eight, pause, eight
  • Cause: Power Module Fault
  • Possible Solution: Check connections to the power module and batteries.
Code #9
  • Flash Code: Nine, pause, nine 9
  • Cause: Controller Communication Fault
  • Possible Solution: Check bus connections from the joystick to the power module.
Code #10
  • Flash Code: Ten, pause, ten
  • Cause: Controller Fault
  • Possible Solution: Contact Technical Service for assistance.
Code #11
  • Flash Code: Eleven, pause, eleven
  • Cause: Incompatible Device Fault
Sep 05, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Code 41 for a 1999 chrysler sebring jx convertable 6 cyl 2.5
No vehicle after 1995 has a code like that
PO40 & PO41
Google OBD2 Codes P0 40
Mar 03, 2013 | 1999 Chrysler Sebring
I have codes 0122 0123 2104 2110 2111 2112 would it be the throttle body
Trouble Code: P0122
Throttle/Pedal Position Sensor A Circuit Low
Possible Causes:
Open ETC TP sensor harness.Short to ground in the ETC TP sensor harness.Damaged TP sensor.SIG RTN circuit open to the TP sensorPCM has failed
Trouble Code: P0123
Throttle/Pedal Position Sensor A Circuit High
Possible Causes:
TP sensor not seated correctly.TP sensor harness is short to voltage.TP sensor harness short to VREF.SIG RTN circuit open to the TP sensor.Damaged TP sensor.PCM has failed.Trouble Code: P2104
Throttle Actuator Control (TAC) System (Forced Idle)
Possible Causes:
Air cleaner and air inlet are not correctly seated.Check for self-test DTCs in all of the vehicle modules.Accelerator Pedal Position (APP) sensor.Throttle Position (TP) sensor.Manifold Absolute Pressure (MAP) sensor.PCM has failed.
Mustang 2006-2008
4.0L V6 VIN N Auto 12
Print
Trouble Code: P2008
Intake Manifold Runner Control (IMRC) Circuit Open (Bank 1)
Possible Causes:
IMRC monitor circuit open
Trouble Code: P2014
Intake Manifold Runner Position Sensor/Switch Circuit (Bank 1)
Possible Causes:
IMRC monitor circuit openMechanical concern - bind, seize, damage or obstruction of IMRC hardware
Trouble Code: P2015
Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance (Bank 1)
Possible Causes:
Mechanical concern - bind, seize, damage, or obstruction of IMRC hardware
Trouble Code: P2019
Intake Manifold Runner Position Sensor/Switch Circuit (Bank 2)
Possible Causes:
IMRC monitor circuit openMechanical concern - bind, seize, damage, or obstruction of IMRC hardware
Trouble Code: P2020
Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance (Bank 2)
Possible Causes:
Trouble Code: P2065
Fuel Level Sensor B Circuit
Possible Causes:
Communication link concernDamaged Instrument Panel Cluster (IPC) (MKS)Damaged Instrument Cluster (IC)Damaged PCM
Trouble Code: P2066
Fuel Level Sensor B Circuit Range/Performance
Possible Causes:
Trouble Code: P2067
Fuel Level Sensor B Circuit Low
Possible Causes:
Trouble Code: P2068
Fuel Level Sensor B Circuit High
Possible Causes:
Trouble Code: P2070
Intake Manifold Tuning Valve (IMTV) Stuck Open (Bank 1)
Possible Causes:
IMTV signal circuit shorted to PWR GND or SIG RTNDamaged IMRC actuatorPCM has failed
Trouble Code: P2071
Intake Manifold Tuning Valve (IMTV) Stuck Closed Bank 1
Possible Causes:
IMTV signal circuit shorted to PWR GND or SIG RTNDamaged IMRC actuatorIMTV circuit openPCM has failed
Trouble Code: P2072
Throttle Actuator Control (TAC) System (Ice Breakage)
Possible Causes:
Ice or oil in the intake air system could be the result of a Positive Crankcase Ventilation (PCV) system concern
Trouble Code: P2096
Post Catalyst Fuel Trim System Too Lean (Bank 1)
Possible Causes:
Loose connection, and damaged or corroded terminalsExhaust leaksContaminated HO2S
Trouble Code: P2097
Post Catalyst Fuel Trim System Too Rich (Bank 1)
Possible Causes:
Trouble Code: P2098
Post Catalyst Fuel Trim System Too Lean (Bank 2)
Possible Causes:
Trouble Code: P2099
Post Catalyst Fuel Trim System Too Rich (Bank 2)
Possible Causes:
Trouble Code: P2100
Throttle Actuator Control (TAC) Motor Circuit/Open
Possible Causes:
TAC motor has an open windingTAC motor is damagedTAC motor harness is openTAC motor harness is short to PWRTAC motor harness circuits are short togetherTAC motor harness connector is unplugged
Trouble Code: P2101
Throttle Actuator Control (TAC) Motor Range/Performance
Possible Causes:
TAC motor circuits are cross-wired
Trouble Code: P2104
Possible Causes:
Air cleaner and air inlet are not correctly seatedCheck for self-test DTCs in all of the vehicle modules.Accelerator Pedal Position (APP) sensorThrottle Position (TP) sensorManifold Absolute Pressure (MAP) sensorPCM has failed
Trouble Code: P2105
Throttle Actuator Control (TAC) System (Forced Engine Shutdown)
Possible Causes:
Trouble Code: P2107
Throttle Actuator Control (TAC) Module Processor
Possible Causes:
TAC motor harness circuit short to ground.TAC motor harness circuit short to voltage.Damaged Electronic Throttle Body (ETB).PCM has failed.
Trouble Code: P2110
Throttle Actuator Control (TAC) System (Forced Limited RPM)
Possible Causes:
Trouble Code: P2111
Throttle Actuator Control (TAC) System (Stuck Open)
Possible Causes:
Binding throttle body, stuck open.TAC motor circuit open.TAC motor circuits are cross-wired.TAC motor harness circuits are shorted together.PCM has failed.
Trouble Code: P2112
Throttle Actuator Control (TAC) System - Stuck Closed
Possible Causes:
Oct 26, 2012 | 2006 Ford Mustang
Codes171 174
Do you mean codes P0171 and P0174? The 4.6L and 5.4L engines have problems with the rubber boot that connects the PCV tube to the back of the air plenum assembly. The rubber boot deteriorates and gets hols in it which causes lean O2 Sensor codes on both banks. The PCV Valves themselves also fail, causing the same codes. (These are the most common causes) The second most common cause is a malfunctioning MassAirflow Sensor (MAF). Severalother things can cause these two codes including any vacuum leak that is on the engine side of the mass airflow sensor, including holes in the intake "snorkel", intake manifold leaks, or any vacuum suply hoses leaking, including the brake booster hose or even a leaking brake booster. Low fuel pressure, caused by any one of several reasons, can also cause these 2 codes. Clogged injectors can also cause these codes, but are not likely to set both of these codes at once. (although it is possible) The least likely cause (although possible) is that both upstream O2 sensors have failed.
Jan 16, 2011 | 2004 Ford F150
Code p041 diagnostic
Cam Sensor Signal problem.
CAM SENSOR is located in the distributor. It is also called a HALL EFFECT SENSOR.
Once you replace the cam sensor you MUST clear (erase) the code from the computer.
Aug 26, 2010 | 1993 Cadillac Seville
The gauge in my yamaha fz6 2006 is blinking, the manual says there is a electrical circuit problem. I check all the ligths nad fuses and they seem in order, what else could it be?
I believe you count the amount of blinks to read the codes. First blinks are first number, and second set of blinks are second number. Chaz Moto DC
Fault Code: 12
Symptom: No normal signals are received from the crankshaft position sensor.
Fault Code: 13
Symptom: Intake air pressure sensor-open or short circuit detected.
Fault Code: 14
Diagnostic Code: 03
Symptom: Faulty intake air pressure sensor pipe system
Fault Code: 15
Diagnostic Code: 01
Symptom: Throttle position sensor-open or short circuit detected.
Fault Code: 16
Diagnostic Code: 01
Symptom: A stuck throttle position sensor is detected.
Fault Code: 19
Diagnostic Code: 20
Symptom: Open circuit in the input line of ECU No4 terminal is detected when the start switch is pressed.
Fault Code: 21
Diagnostic Code: 06
Symptom: Coolant temperature sensor-open or short circuit detected.
Probable cause of malfunction: Open or short circuit in wiring harness.
Defective coolant temperature sensor.
Malfunction in ECU.
Improperly installed sensor.
Fault Code: 22
Diagnostic Code: 05
Symptom: Intake air temperature sensor-open or short circuit detected.
Defective intake temperature sensor.
Malfunction in ECU.
Fault Code: 30
Diagnostic Code: 08
Symptom: The motorcycle has overturned. Probable cause of malfunction:
Overturned.
Malfunction in ECU.
Fault Code: 33
Diagnostic Code: 30
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 1, #4).
Probable cause of malfunction: Open circuit in wiring harness.
Malfunction in ignition coil.
Malfunction in ECU.
Malfunction in a component of ignition cut-off circuit system.
Fault Code: 34
Diagnostic Code: 31
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 2, #3).
Malfunction in ECU.
Fault Code: 41
Diagnostic Code: 08
Symptom: Lean angle cut-off switch-open or short circuit detected.
Defective lean angle cut-off switch.
Malfunction in ECU.
Fault Code: 42
Diagnostic Code: 07, 21
Symptom: No normal signals are received from the speed sensor; or, an open or
short circuit is detected in the neutral switch.
Defective speed sensor.
Malfunction in vehicle speed sensor detected unit.
Defective neutral switch.
Malfunction in the engine side of the neutral switch.
Malfunction in ECU.
Fault Code: 43
Diagnostic Code: 09
Symptom: Supply power to the injector and fuel pump is not normal
Probable cause of malfunction: Open circuit in wiring harness. (red/blue line or blue/yellow line)
Malfunction in ECU.
Fault Code: 44
Diagnostic Code: 60
Symptom: An error is detected while reading or writing on EEPROM.
Probable cause of malfunction: Malfunction in ECU. (The CO adjustment value is not properly written on or read from the internal memory).
Fault Code: 46
Diagnostic Code: --
Symptom: Power supply to the FI system is not normal. Probable cause of malfunction:
Malfunction in "CHARGING SYSTEM".
Fault code: 50
Diagnostic Code: --
Symptom: Faulty ECU memory. When this malfunction is detected, the code
number might not appear on the meter.
Probable cause of malfunction: Malfunction in ECU. (The program and data are not
properly written on or read from the internal memory.)
Fault code: Er-1
Diagnostic Code: --
Symptom: No signals are received from the ECU.
Probable cause of malfunction: Open or short circuit in wiring sub lead.
Malfunction in meter.
Malfunction in ECU.
Fault code: Er-2
Diagnostic Code: --
Symptom: No signals are received from the ECU within the specified duration.
Probable cause of malfunction: Improper connection in wiring sub lead.
Malfunction in ECU.
Fault code: Er-3
Diagnostic Code: --
Symptom: Data from the ECU cannot be received correctly.
Malfunction in ECU.
Fault code: Er-4
Diagnostic Code: --
Symptom: Non-registered data has been received from the meter.
Malfunction in ECU.
Feb 23, 2010 | 2005 Yamaha FZ6
Televison & Video Logo
Top Televison & Video Experts
