Question about Samsung Televison & Video
My rear projection 1080i..will not work..all of a sudden..the red power light in front flashes..like its going to work..but the remains a steady red light..with no lights in back and no pic whatsoever..if its convergence..unable to afford the fix..but if a bulb would consider..I just can't afford to waste on not the problem..question is, how's do I know?
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Sets that have convergence circuits do not have a lamp or bulb--for more help I need to know the brand and the MODEL number of this set.
Posted on Nov 03, 2012
  • denisefitz61
    denisefitz61 Nov 10, 2012
    It is a Samsung HDTV monitor 1080i model number HC-P4241W...the UL number is77HNE215927 if this makes any difference let me know..only had the tv for a short time..bought it used..I just can't afford to invest if not worth it..or wrong problem..Thank You so much for your help thus far..greatly appreciate you responding..
Slinteriors
  • 8617 Answers
SOURCE: sony bravia 50" rear projection hd 3lcd tv
3 blinks in sony sets means B+ over current protection shutdown. Problem in power supply Check Transistor T603 And Resistor R672. Hope this helps let me know if you need any further assistance.
Posted on Jan 08, 2008
scott201201
  • 170 Answers
SOURCE: Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
Posted on Apr 10, 2008
  • 213 Answers
SOURCE: My Samsung LCD LA32R7 won't
you have a bad power supply.
Posted on Jun 11, 2008
SOURCE: Toshiba 57H81 Flashing Red Power Light, Blown Fused F850+F852
Solved by resoldering some solder joints!!!!!!!
Toshiba Model 57H81 Rear Projection TV - Purchased 11-09-2001
Problem: Toshiba 57H81 Flashing Red Power Light, No Picture/Sound, Blown Fuses F850 + F852
Symptoms January, 2009:
  • Upon turning on set I got flashing red power light and nothing else.
  • Removing plug for one minute and plugging in results in:
    • Audible click, steady red power light for 2 seconds then slow flashing red light
    • Pushing power button results in steady red for about 2 seconds then slow flashing red light, no other set activity
  • Removing power cord for several hours and plugging back in made no change
    • Audible click, steady red for about 2 seconds then slow flashing red light
  • Possible related note: Over past several months occasionally the entire screen would flicker momentarily and at other times be problem free for weeks.
  • Fuses F850 and F852 found blown
Repairs Made:
  • PD0074 DEF/CON Power Board
    • There are two main power supply capacitors in this set. They are C-809 and C-810. One their negative lead on the printed circuit board re-soldered leads and nearby contacts. I’m told that because the factory left out a printed circuit board eyelet, the connection will come loose over time. When I called Toshiba customer service they said there was a known solder joint problem causing blinking red light.
    • Replaced blown fuses F850 and F852.
      • I actually installed a fuse panel on the inside of the cabinet and routed the fuse connections here instead of ordering the special fuses and replacing them on the circuit board.
      • Had to use a 5 Amp SLO-BLOW for F850. Fast blow does not survive power up. Get the red blinking light.
      • Used a fast blow 2 Amp for F852.
  • PD0073 SIGNAL Board
    • Re-soldered Q751 + Q752 STK392-110 Convergence Amps
    • Re-soldered adjacent pads that looks suspicious
Total Cost to Repair about $10
  • Twelve hours of my time over three days to research issue, disassemble set, make repairs, add fuse panel.
  • Already owned Service Manual and Circuit diagrams from a different 2004 repair.
  • Less than ten dollars at Radio Shack for fuses and fuse panel. Already had wires, etc.
  • Some solder. Already owned de-soldering tools, etc.
  • Visited both local authorized Toshiba factory service repair facilities. One said repair would have to include replacing Q751 + Q752 STK392-110 Convergence Amps with ST392-180, and realigning set for a total of $500+ and it would be more if they had to order a power board. NO THANK YOU! Other shop said $65 for site visit and $30 to make an estimate that could be applied to repair.
Posted on Jan 05, 2009
Muzzi_123
  • 749 Answers
SOURCE: I try to power on
you need to test the lamp with a ohm meter, to see if its working correctly
Posted on May 14, 2009
Screan shuts off after 30 seconds and 3 lights flash on botton near power button.
Contact Samsung tech support, Tell them this info, they should be able to tell you the type of problem you have
Feb 12, 2014 | Samsung HLP5085W 50" Rear Projection...
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
No picture
These sets have had, unfortunately, bad picture tubes. The gun welds tend to break loose over time.
Mar 02, 2008 | Sony KP-43T70 43" Rear Projection...
Will not power up, light flashing
you are probably experiencing a bad flyback transformer
Feb 12, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony kp4t70 no picture
Can you tell me the number of flashes? This will help in diagnostics.
Oct 14, 2007 | Sony KP-43T70 43" Rear Projection...
Televison & Video Logo
22 people viewed this question
Jerry Greenberg
Jerry Greenberg
