Williams furnace model # B60D-1
BURNERS WONT LITE
5 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: on my williams wall furnace Model # 1403622 the
The problem is with the thermocouple.... this is the metal thing that the pilot flame hits when it is burning....if the flame is not hitting it then it does not get hot enough...
make sure the flame is hitting it....if not then adjust the hood over the flame to get it on the thermocouple...
If it is hitting it then replace the thermocouple....for that heater though the thermo is probably and OEM part and may have to be bought from the manufacturer...
heatman101
Posted on Nov 07, 2010
  • 4736 Answers
SOURCE: I have a Williams Gas Space Heater Model#3501912.
I would suspect not. It's very, very rare for a control valve to go bad, unless someone tried to force it to urn with a pair of pliers or something similar.
If you have provided annual service to the heater, it's probably just residual gas remaining in the burners. To test this theory, turn the flames down to low and then turn the burner OFF. Do the burners and the pilot light go out? If it doesn't, you'll be that rare consumer that needs the Control Valve replaced.
Just to help you out a little bit more. I have provided a link to the Owners Manual for your heater. It's in a downloadable, printable, pdf format.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0408171.pdf
Hope this helps. Please let me know.
Rich
Posted on Feb 07, 2011
  • 4736 Answers
SOURCE: hello i have a williams
What you have is a Direct Vent, Gas WALL Heater. It is normally mounted about 6" off the floor on an exterior wall (since it has to be direct vented out). Not sure what the red and white wires are for, but suspect it's for the optional thermostatically controlled blower connection.
In any event, to help you install this heater properly, I have included a link to the Owner/Installation Manual, which should provide all the information you need to complete the installation correctly.
http://shopfnc.com/pdffiles/williams2man.pdf
You can download and print the manual for future reference.
Posted on Feb 26, 2011
  • 1033 Answers
SOURCE: goodman furnace gmh95090cxac wont stay lit keeps clicking will lite then clicks back off what would be the problem
Hello, if the burners light but do not stay on for more than 10 seconds, I would clean the flame sensor. The flame sensor is a metal rod that is on the opposite side of the Igniter, sometimes it gets coated by oxidation and does not sense the burner flame and shuts the Furnace down. To clean to kill power to tje furnace, remove flame sensor and clean with a steel wool, then reinstall and start Furnce back up. If this does not work then most likely the Igniter is too weak to ignite the gas and will have ro be replaced.
Posted on Oct 30, 2012
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
Williams wall furnace model 5009622A pilot light will not light
make sure the thermocouple is sitting 3/8 to 1/2 inside the pilot flame when lighted. if it isn't, it wont generate enough dc current to keep pilot on
Dec 30, 2014 | Williams Heating & Cooling
Goodman furnace gmh95090cxac wont stay lit keeps clicking will lite then clicks back off what would be the problem
Oct 29, 2012 | Heating & Cooling
I have a Williams Gas Space Heater Model#3501912. I purchased this furnace about 10 yrs ago. I have noticed that the space heater will not shut itself off. The gas burners are on, but will not shut itself...
Rich
Feb 07, 2011 | Williams 3501922 (NG) Gas Compact Heater
I have a Model CGN250TE.The pilot light stays lit but when you turn control valve on it stays lit for 5 seconds and then shuts right down,even the pilot light goes out.I have tried venting the room and...
I would first check the gas pressure to your furnace. Then make sure that burners are clean and watch flames when burner first ignites. I have seen burners that were dirty cause delayed ignition that would create a suction when they came on and extingush pilot and burners.
The next thing I would do is change gas valve. Thank you
Dec 19, 2010 | Williams 2509612 Ceramic Mid-Size Heater
I have a williams wall furnace model 5009622,and the pilot will not stay lit ,i cleaned the thermacouple,still no luck,i also then replaced thermal couple still wont stay lit,any other ideas thanx ,i was...
Assuming the pilot is clean and sharp. Before replacing the valve, clean any spade connections, those going up to the spill switch in particular. Clean and tighten all 4 connections. Good luck.
Jan 11, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Williams Heater console floor unit
Is this a floor furnace? If so sounds like the switch for the blower, which is mounted on the side of the fire box is bad. There should be 2 of them, 1 for the blower to start 1 for the blower to stop when the fire box is cooled down. It wouldn't hurt to just replace both of them.
Oct 07, 2009 | Williams Heating & Cooling
Gas furnace wont stay lite
I'm a little confused by your terminology. You are saying you have a pilot lite and electric heat strips? Are you possibly meaning burners? Is the heater running for 2 hours straight without shutting off? how cold is it there? Lastly what temperature do you have the thermostat set at and how close does it get to the temp. before it shuts off?
Dec 16, 2007 | Heating & Cooling
Williams gravity vented wall furnance - where is the pilot?
Its in the bottom of the heater behind the vent cover . I don't know where you are but your local gas utility will come out and lite this for free.
Dec 10, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
