Question about Garden
I need to change my water pump on my 1997 buick le sabre
How to loosen the belt
  • 44 Answers
There is a pulley that keeps the belt tight and it is spring loaded. you will notice that there is a nut on the front of the pulley. attach a box end wrench on it and pull it away from the belt. be very careful, there is allot of tension on it and it can be a real knuckle buster. once you pull it away from the belt, you should be able to remove it. If you don't have a diagram of the way the belt goes back on, you should probably take a few pictures before you start. good luck...and watch your fingers.
Posted on Nov 03, 2012
1997 Buick le sabre
It appears to be right above crankshaft pulley. Your lower radiator hose should go to the pump.
Jun 14, 2017 | Buick Cars & Trucks
1998 Buick Le Sabre - Water pump needs to be replaced, Serpentine Belt constantly slips off and its overheating
The dealer cost is about 475 and a shop cost is 385 and do it yourself is 106,since your getting other work done means it sounds fair,3 hours to do water pump.Here's a link on doing the water pump. Repair Guides Engine Mechanical Water Pump AutoZone com here's the water pump. Water Pump 1998 Buick Lesabre 6 Cylinders 3 8L SFI OHV AutoZone com plus a gallon of extended life antifreeze full strength.And a tube of sealant and gasket.
Feb 01, 2014 | Buick Cars & Trucks
How do you remove the pulley off of the tensioner on a Buick Le Sabre
That is the right way, spray the bolt with some wd40 or liquid wrench.
Oct 13, 2017 | 1997 Buick LeSabre
Is there an oil screen on the oil pan on a 1997 buick le sabre
Call your dealer, Bev. They will know the answer.
Jan 11, 2012 | 1997 Buick LeSabre
How do i bypass the heater core on a 97 buick le sabre
Ok to eliminate having heat in your vehicle and/or replacing a damaged heater core unhook both the 5/8" id hoses going to your heater core then remove them and connect a hose between both outlets to loop them. Newer replacment water pumps have interchangeable outlet fittings which can be removed and plugged with a pipe or drain plug if applicable the same as with your water neck fitting. Connecting the 2 together is a much easier fix
Dec 10, 2010 | 1997 Buick LeSabre
How to replace drive/serpentine belt for '97 buick le sabre 3.8? do u have to remove engine mount/bracket or just engine mount?
You don't have to remove the mount. Go thru the wheel well on the passenger side and remove the motor mount bolt just right of the crank pulley. Then remove the stud that the nut was on. Then remove the sleeve that the stud goes thru. Then you can change the belt.
Sep 18, 2010 | 1997 Buick LeSabre
HOW DO I TIGHTEN THE LOOSE BELT AFTER INSTALLATION ON 97 BUICK LE SABRE? REALLY NEED A DIAGRAM TO MAKE SURE I INSTALLED THE SERPENTINE BELT CORRECTLY.
There may be a diagram imprinted on fan shroud. There is a belt tensioner that tightens the belt. Also when installing belt be sure you have grooved part of belt riding on grooved pulleys. And flat side of belt riding on flat sided pulleys.
Sep 13, 2010 | 1997 Buick LeSabre
Serpentine belt diagram for 2003 buick le sabre
Since there is NO sticker under the hood of this 2003 Buick LeSabre and it is not in the owner's manual, a Google search revealed that it is the same as at http://www.fixya.com/cars/t3438653-change_serpentine_belt_1998_buick
Jul 11, 2010 | 2003 Buick LeSabre
How to change a water pump on a 1999 Buick Century 3100?
the water pump on the 3.1 isnt to hard to change ...
  1. Disconnect the negative battery cable.
  2. Partially drain the cooling system into a suitable container.
  3. Remove the drive belt guard.
  4. Loosen the water pump pulley bolts before removing the drive belt. This should help keep the pulley from turning as the bolts are loosened.
  5. Remove the drive belt. Remove the water pump pulley bolts and remove the pulley.
  6. Remove the water pump bolts and separate the pump from the engine front cover.
Dec 09, 2008 | 1998 Buick Century
1997 buick le sabre
its the electrical connection at he fuel pump,if this is ok ask if they replaced the strainer on your fuel pump,your fuel pump is inside your gas tank ,you have to drop the tank to service,most fuel pumps are not warrantied if you dont change the strainer,when your car shuts off the sediment on the strainer falls back into the tank,but when you run your car and it sucks up the gas thru the strainer to the pump it clogs the strainer and the fuel pump cant pump,you shoiuld find out if they changed this because your forcing your fuel pump to work harder,was it a new fuel tank or used one that they put in
Jul 09, 2008 | 1997 Buick LeSabre
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
