Question about HP Officejet 7210 All-In-One InkJet Printer
HP7210 all-in-one scanner problem
The scanner was working fine, but now it only gets as far as saying "warming up" with the power light flashing and then freezes. The lamp comes on but doesn't move. The only way out is to turn the printer off and wait for it to shut down. Printer still working fine I've tried: Changing usb vcable and port, reinstalling software, restarting computer and printer, restoring factory defaults and various diagnostic software. Still no luck. I've also noticed that recently the backlight for the main LCD isn't coming on. Any thoughts are welcome, Thank You, M.B
  • oddjazz May 02, 2009
    I'm having the problem where the the 7210 will print from the computer, but the fax and copier will not work. It gets stuck in the "warming up" mode and will stop only if turned off.  I tried the power restart with # and 6 as suggested, but no luck. The screen said it was initializing, but the problem did not go away.
    Any help is appreciated,
    oddjazz
    Scholar:
  • 97 Answers
Please follow the follwoing steps,
1) unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to
printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and
then release both buttons, if your printer goes off then turn ON the printer and it will reset itself and will print a allignment sheet, this should resolve the issue.
Regards,  raj_p5983
Posted on Jan 29, 2009
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Epson v500 flashing green light
I have the exact same problem, sometimes it works and it starts warming up, but most of the time it just shows a green light and no response.
May 17, 2012 | Epson Perfection V500 Flatbed Scanner
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
Motorola MC9090 G oes not cold boot.
I've found this method works best especially on Window Mobile versions, windows CE does not seem to have the problem.
  1. Have the battery inserted,
  2. Remove the battery so its at the first stage of removal,
  3. Hold down the On/Off button and trigger,
  4. Insert the battery, still with On/Off button and trigger held,
  5. As soon as the amber light flashes release the On/Off button and trigger.
  6. Unit will attempt to cold boot and then warm boot,
  7. If it works then it will boot through to the Windows Splash screen or desktop.
  8. If it fails and continuously warm boots, remove the battery fully as soon as it cycles a warm boot.
  9. The terminal will not switch off at this stage and will completely drain the backup battery and RAM, giving you a complete clean cold boot
  10. Leave the battery out fro 20 minutes.
  11. Power on and see how far you get.
If it still fails after this I would suggest a complete re-flash of the system. Please post a follow up question on how to do this.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Jun 06, 2010 | Zebra Symbol Technologies MC909X-G Series...
99 jeep cherokee after sitting 6or10 hours or more.starts fine,i here the fuelpump working.within the first few miles it just dies i have to crank it a bit but it starts back up and so far keeps running...
If its warmed up it runs OK? The coolant temperture senser may be lying and saying the motor is warm when it's not. If the check engine light is on it may be indicating that or some other equally damaging problem. Most auto parts stores will connect to your Jeep and tell you what the codes are for no charge. Some stores may even reset the light for you. The coolant senser can lye and not turn the light on. A true scanner( not a code reader. can tell the values of the sensers as the Jeep runs. f the car is cold and the scanner says it's 180 degrees coolant you have found the problem. A wrong senser that has turned the cheak engine light on can have the computer sub a good value for a warmed up car so the car will still run, but not nessaryly the best till the check engine light is investagated and repairs are made
May 13, 2010 | 1999 Jeep Cherokee
Hp fax model 3330 is broken . At first it was very slow to warm up bulb and finally it stopped working all together and the screen says scanner error power on - off. The cancel light is blinking and...
You are correct with your diagnostics, he problem is caused by dirty optics. The mirrors in the scanner have dust, lint or smoke on them. When the scanner powers up it tries to calibrate itself and waits for the bulb to warm up so the light output gets to a certain level. With the dirty optics the scanner never gets enough light so it thinks the scanner is still warming up and so it waits for the light to get brighter. After a few minutes of waiting and not getting the correct level of light it gives the power off message. We have a dis-assembly and cleaning guide with step by step instructions posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ This procedure takes about 30 minutes to complete but it should et you back going again.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 15, 2010 | HP LaserJet 3330 All-In-One Printer
RED LIGHT FLASHING after local power cut in East London
I switched off the power, then I disconnected the lid from the base, put the power back on, the green light came on & then I reconnected the lid to the base & it has been working fine ever since
Aug 27, 2009 | Epson Perfection 4990 Flatbed Scanner
UMAX 2100XL IS CONNECTED, 2 G LIGHTS FLASHING WITH NO PRINTS
OUR SCANNER IS CONNECTED BUT DOES NOT WORKING. DOES NOT POWER ON THE "SCANNING LAMB" NOW THE TWO GREEN LIGHTS ARE FLASHING ( POWER AND READY ) BUT THE SCANNER DOES NOT WORK OR SCAN.
Dec 09, 2008 | Umax PowerLook 2100XL Flatbed Scanner
Fax and cancel lights are flashing
I found this solution at HP website. It worked for me. Good luck!
A Scanner Bulb Error message is received as a result of the HP LaserJet 3300mfp series product scanner’s inability to find the home reference point.
SOLUTION:
Perform the following steps to walk the scan assembly from the home base and resolve the issue.
1. Remove and replace the power cord from the unit.
2. Wait approximately 35 seconds for the scanning assembly to “walk out" and then quickly remove the plug again.
3. Repeat steps 1 and 2, three to four times until the head moves approximately 1 inch away from its normal resting place.
4. Replace the plug and let the product fully finish the boot cycle.
Oct 08, 2008 | HP LaserJet 3330 All-In-One Printer
Not working properly
I'm having a similar problem. So far my solution has been to disconnect the 3330 from power for a longer period (> 30min.) and then switch it back on again. After the self-test everything appears to be ok again. I've got no idea why, but this seems to work (for now)
May 07, 2008 | HP LaserJet 3330 All-In-One Printer
HP Officejet 7210 All-In-One InkJet Printer Logo
313 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
