Question about Garmin GPS 72 GPS Receiver
On My garmin gps 72H none of the buttons will work. EG I cannot change pages or turn off. Was working fine then changed batteries and this occured. Any suggestions??
No buttons are working. For example push page and nothing happens. Same with memu, etc. Was working fine and batteries went flat. Put new batteries and problem occurs. Gets satelitte signal ok.
    Top Expert:
  • 14,553 Answers
I would read the owner manual first and then remove the batteries for a while and put back. This does not use recharge able batteries?
Posted on Nov 03, 2012
SOURCE: garmin gpsmap 60csx won't acquire satellites
Go to the Garmin Web site's home page, avoid staring to long at the hot chick and click on "On The Trail" .. "Mapping Handhelds" .. scroll down to the second row far right and click on the 60CSx. You will then see the 60CSx page, look to the right and click on "Updates & Dowdloads", on doing so you will now see four downloads to choose from. The one you will need is "GPS Chipset Type G Ver. 2.90 as of Nov 27, 2006" if you follow this you shouldn't have any problems. If however you do i'll keep an eye on this page and try to help, this is my first GPS and also had the same issue.
Posted on Sep 24, 2007
SOURCE: GArmin 2620
Same problem and tried all reset software same problem. Any other ideas?? Heard there is a reset button but unable to find this.. Any help out there?? Thanks
Posted on Dec 08, 2007
  • 4 Answers
SOURCE: GPS 60 unit shows "Searching the Sky" status message all the time
The "New Location" fix above brought my GPS 60 back to full operation. I did reload the GPS software from Garmin but the recovery depended on well charged batteries and as above: turn the unit on
press MENU button
scroll to "New Location"
wait 10 minutes for the GPS to recover.
Posted on Apr 02, 2008
marcelbakker
  • 174 Answers
SOURCE: Garmin c550 GPS-Won't turn on at all.
push and Hold the power button down while you push reset, keep power button pressed til it boots again. If it does not, and it's in warranty ship it to garmin. If it's out of warranty, have someone open it up and remove the battery for a couple of minutes.
Posted on Jul 23, 2008
SOURCE: Garmin c330 gps will not turn on
try this just worked for mine
1.Under the face plate by the Garmin Logo.Use your thumbnail to remove the plate.
2.Press the reset button.
Information located on page 28 of the owners manual if you need a diagram.
Posted on Jan 28, 2009
My garmin nuvi 2495lm wont turn on at all
try leaving it plugged into wall power overnight to make sure it's not a low battery. Otherwise, if nothing changes when you plug it into the computer it sounds dead. Hope it is in warranty, otherwise I think Garmin will give you a trade in value towards a working unit or repair it at reduced cost. Call them at 1800-800-1020
Aug 03, 2014 | Garmin nuvi 2495LMT 4.3" GPS Navigator...
How do I change the cmos battery
Please if you want a technical advice, at least tell a bit more about the thing the battery is in. What you tries yourself and why you think the battery has to be changed.
Jul 18, 2014 | Garmin GPS 72H GPS Receiver
GPS 72H troble seeing position
Hi Martin
We have a GPS 72H as well and (as with any GPS) the unit MUST be held (or mounted) with a clear view of the sky to acquire satellites.
In case you or anyone else requires it, the link below will allow you to view/download the owner's manual for it.
Hope this is helpful.
-Steve
http://static.garmincdn.com/pumac/GPS72H_OwnersManual.pdf
Mar 09, 2014 | Garmin GPS 72H HANDHELD
Not get satelite
My Garmin 298 could not pick up the satelites and the repair shop said the internal battery must be changed which was quite expansive. Tried to press the red button and page and hold it for half minute or so. Thereafter I left the GPS connected for some hours and now it works. Thanks for the advice
Aug 04, 2013 | Garmin GPSMAP 298 GPS Receiver
How do i set the time on my garmin 72h
Hi qt_joes,
I assuming you don't have the manual handy for unit. It's a little lengthy, but not hard with the manual in front of you. Go to page 43 and get into the "Setup Menu - Time Tab". It will allow you to input/change Time Format , Time Zone , and Daylight Savings Time. The Current Date and Current Time will be determined by the Time input you just entered, and the unit itself. That should address these concerns. Here is the link to the manual:
http://www8.garmin.com/manuals/GPS72_OwnersManual.pdf
This should give you all the info you need for the time and date, as well as all other operations of your GPS Receiver. Let me know if this takes care of the problem. Thanks.
Regards, Bill
Sep 17, 2010 | Garmin GPS
Unit shut down
I have run into the same problem and it may be related to the WAAS (Wide Area Augmentation System) feature. Try disabling this feature (under MAIN MENU / Setup). I used this receiver overseas (Asia and Europe) last year for 35 days straight with no problems. During this time WAAS was disabled as none of these satellites are visible overseas. The problem occurred intermittently prior to the overseas trip, and has reoccurred after returning. I was running into the same problem this past weekend and noticed the screen blanking out (with the vertical line) shortly after differential corrections were applied to the GPS signals. I disabled the WAAS and let the receiver run for over an hour. The problem did not return. Hope this helps.
Sep 25, 2008 | Garmin GPSMAP 76 GPS Receiver
Garmin C330
It sounds like the battery is either dead (will no longer take a charge) or has become disconnected. My bet would be dead battery.
Aug 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Jun 29, 2008 | Garmin nuvi 350 GPS Receiver
Garmin gpsmap 60csx won't acquire satellites
Sep 17, 2007 | Garmin GPSMAP 60CS GPS Receiver
Garmin GPS 72 GPS Receiver Logo
185 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
