Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
Lense won't retract on Canon Powershot SD630
I have not been able to remove the front cover on the camera. There appears to be a screw next to the power on button and I do not know how to get to it or remove it so the front cover can be removed. I have tried various methods to free up the lense but I now believe I must access the lense which requires removing the front cover.
Thanks,
Trent
  • 2 more comments
  • cmijares Jan 24, 2009
    have you figured out how to take the front cover?
  • Anonymous May 25, 2009
    having trouble getting the front cover off as well.. did you ever figure it out. All screws are off, back & side pieces as well just the front is stuck ;(
  • elchinito May 25, 2009
    Did you ever figure this out, have the same issue. Have back and sides ofj just cant get the front ;(
  • Anonymous Mar 22, 2014
    hOW DO I REMOVE THE BACK COVER OF MY CANNON IXUS951S
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try. You're also more likely to be successful trying these than going inside the camera:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Finally, if you absolutely must open the camera, here's a couple guides to replacing the camera's LCD that may help:
http://cannonlcdrepair.blogspot.com/
http://digitalcamerarepair.googlepages.com/sd600
Posted on Jan 04, 2009
Lost my cannon powershot sd360 cd
I hope you mean the Canon SD630.
You can download Canon software from
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd630#DriversAndSoftware
(If the formatting's screwed up, it's
You might want to consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
Mar 05, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
I cannot turn off camera. Lense error appears.
you must have dropped or banged the camera,same thing just happened to me. i'v done some looking on the internet and it seems we have to bring the camera to a repair shop,but get a quote for the repair because one site advised just to buy a new one as its very expensive to fix. i'm going to get a quote and 1st for the work,just incase.
Mar 18, 2010 | Canon PowerShot SD1000 Digital Camera
Canon Powershot S2 Is
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Jan 11, 2010 | Canon PowerShot S2 IS Digital Camera
PowerShot SD630 lens stuck out, says lens error, restart camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
I've had similar problems with various versions of this camera. Here's the fix, if all else fails. These are step-by-step instructions to take apart and fix the camera's lens error. http://johnsmouth.wordpress.com/2010/12/01/lens-error/
Mar 24, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Beeps repeatedly, lense won't retract...won't take pictures?
Hi Jeanice21, I just posted the same problem a few minutes ago with my SD400. I followed a few steps of the suggested solutions and here's what worked for me.
1) take apart the front and back by unscrewing the six screws holding the camera together
2) on the left of the flash, there are two little retangular holes with grooved dials in them
3) using a little flat head screwdriver, push up or down to turn the grooves while power up in the movie or capture mode
4) the lens retracted at this point and my camera started working again. Good luck!
Dec 28, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon sd630 dead
Lens is defective, change the lens
Nov 01, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens won't retract
Mine has done this twice, both times requiring it to be sent off for repair, both covered under warranty though luckily. Both came back saying they replaced the shutter assembly. Camera is fixing to go back out for a third time (not shutter related). I've lost all confidence in canon with this one.
Oct 25, 2008 | Canon PowerShot SD870 IS Digital Camera
Hi
We have exactly what you need listed in our store as a repair package or we can sell you the parts and you can repair it yourself.
We are a digital camera repair business, Google Darntoothysam and you will find us. If you search 'sd600' in the store you will see the repair listing for the problem you have, and I can add a listing for just the parts as well. The repair is only $35 plus about $7 return shipping. This includes any parts you need, the labor and a 45 day guarantee.
If we can help please let us know. Good luck from Darntoothysam com
Thomas
Oct 22, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
290 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
