I'm working on a kenmore 11046472501   Washer
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Did you get an error code? Also, take a wet-dry vac and **** the drain line. Sometimes there will be a blockage there as well. Have you checked the door switch for continuity?
Posted on Nov 03, 2012
  • 1 more comment
  • Cole babb
    Cole babb Nov 05, 2012
    Switch is good, hose is clean not much of a code just the lights I described . Thanks for following the question
  • Richard Roth
    Richard Roth Nov 05, 2012
    OK, the problem is going to be with the CCU. First, check ALL the wire connections running to and from the CCU. If this doesn't work you will need to replace the CCU. Here is a link to the part to order. http://click.linksynergy.com/fs-bin/clic... The part comes with a 365 day, any part, any reason return. So if you find you should need to return it you won't have any problems. That's why I only use them to get parts. Any local repair shop will not take any returns on eletronic parts. Keep me posted!
  • Cole babb
    Cole babb Nov 07, 2012
    Thanks ill check into it thanks for the direction
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: We have a Whirlpool WFW8300SW
Aha! F25 Motor Tach error Bad MCU (motor control unit) or broken wire.
Do we do the swap parts thang or try to trace down the broken wire? Before ordering expensive parts go along the rail where the wiring harness is most susceptible to vibration and look close for signs of distress.
Posted on Mar 31, 2011
Washer making a clicking sound, the tub isnt draining, and the add a garment stays on
Door switch isn't making. .if door isn't closed the washer won't run and will have the add garment light will stay on.
Oct 04, 2014 | Kenmore HE2 Plus Front Load Washer
Washer will not turn on.
If the Add A Garment light is on, try this: the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point.
May 21, 2013 | Washing Machines
Kenmore HE Washer Model 11046472501 - add a garment light stays on with the door lock light on at the same time. We have unplugged the machine and ran the drain and spin mode, but he washer won't
Not sure if these will help or not:
http://www.youtube.com/results?search_query=Kenmore+HE+Washer+diagnostics&oq=Kenmore+HE+Washer+diagnostics&gs_l=youtube.12...4054.11443.0.13769.12.12.0.0.0.0.236.2449.1j0j11.12.0...0.0...1ac.1.93rgz26enSw
Jan 26, 2013 | Kenmore Ap4327152 Motor Control Board for...
Lights blink on settings around the knob won't run from there
Your door switch is not working, the machine thinks that the door is still open.
Mar 11, 2012 | Kenmore HE2 Plus Front Load Washer
Whirlpool washer duet is flashing after adding garmet. Will not return to washing
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 29, 2010 | Whirlpool GHW9300 Duet Washer
The ultra Handwash & Delicate cycle leave the clothes soaking wet, how can I fix
You gonna think this is weird but I believe you might not have enough items in the washer. ebfcdfa.jpgYou might have to use a mesh bag or add a garment to get the machine to act right.897ed48.jpg If F-21 you gotta remove the bottom panel screws and panel and get the junk out the sump19223ec.jpg
Apr 19, 2010 | Kenmore 44072 Front Load Washer
Kenmore h2 error code
Jan 11, 2010 | Kenmore 46462 Front Load Washer
I have a whirlpool ghw9100lw the light is flashing but it will not start
Aug 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Pushed pause. Added garment. Washer will not start again.
possible you have not held "start" button down for the required 5 sedonds to restart cycle??
May 16, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
