Question about Sewing Machines
Homewell sewing machine, bobbin moved
Looks like the bobbin housen has moved.[timing out]
SOURCE: Brother XL-5130 Sewing Machine
Put the thread through one of the holes. Then put the bobbin on the spindle. Pull about 3 or 4 inches out of the hole and hold on to it. Start winding the bobbin. After about ten turns, or when the winding thread is secure, you can stop the machine and cut off this 3 or 4 inch tail. To insure that the thread winds up and down the bobbin and not off the top or bottom, there is probably a metal bobbin tension disk that the thread must pass around before it goes to the bobbin. It is probably on the left of the machine and may or may not be part of a thread guide. The thread must pass around this disk on its way to the bobbin in order to put tension on the thread so it will wind properly. If you can't find the disk, which is a small metal button or screw with some type of somewhat moveable spring cap, you can just get the thread to pass through your thumb and forefinger. Hold your hand 6 or 8 inches to the left of the bobbin and pass the thread between your thumb and forefinger so that it makes the thread go in a direct straight line to the bobbin. Pinch the thread only enough to keep it taught but not tight and let it flow through your finger to the bobbin. The thread should go up and down evenly on the bobbin. If not, move your hand up or down to position it so the thread will wind up and down smoothly. It will not be necessary to move your hand once you find the correct position needed for winding.
Posted on Jul 20, 2007
manski
  • 15 Answers
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
www.myrepairmaster.com.
Posted on Dec 10, 2007
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • 7 Answers
SOURCE: Bobbin problem: Huskystar by Husqvarna Viking E10 sewing machine
This has happened to me, even though I have been sewing for 30 yrs. When I take the bobbin holder out I realise what I have done wrong. When placing a bobbin into the bobbin holder the thread must be running around the bobbin CLOCKWISE. If incorrect take bobbin out of holder turn it over, so now the thread will run clockwise.If bobbin placed in holder and thread runs anti-clockwise, when you tried to turn wheel to bring bobbin thread up, it will either not do it at all or will make a huge tangle of the threads. Happy Sewing
Posted on Nov 17, 2008
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
Brand new, out of the box, winding a bobbin. It worked perfectly but now I can't get the bobbin OFF the winder.
there is a small lever like thing there move it away from the bobbin. it usually kicks back when the bobbin is full.
Aug 18, 2015 | Brother SE400 Computerized Embroidery and...
Needle thread timing
Bobbin is not moving, sounds like a broken gear, not a timing problem. Bring it in for service.
Apr 03, 2014 | White Sewing 2999 Mechanical Sewing...
Bobbin stopped turning. I rethreaded it and unplugged it and turned it back on. Now it does nothing but sound like it's trying to sew and there is a message in the little window that looks like a backwards...
have you taken out the bobbin case and all the parts around the bobbin? sometimes lint and threads can get stuck in there and throw off the timing of how everything works. There is not a lot of room for error with all of those moving parts. Possibly put ONE drop of sewing machine oil on the center spindle of the bobbin compartment. You might want to check to see if there is anything in the way of the gears moving also. Sounds like what my brother embroidery machine does if there is gunk in the gears. good luck
Sep 16, 2013 | Singer Sewing Co 7258.CL Stylist Sewing...
Needle will not pick up bobbin thread
Sounds like the timing isn't quite right. Your best bet is to go have it serviced and timed.
Jan 08, 2013 | Janome Memory Craft 3000
Homewell sewing machine,s bobbin housen moved.
Sounds like it got knocked out of time. Take it in for repair.
Nov 03, 2012 | Sewing Machines
Bobbin case wont stay in place
the bobbin case may need to be replaced. it wouldn't hurt to have the machine serviced to make sure the hook & hook race are ok
Apr 19, 2012 | Janome Sewing Machines
Using a Pfaff Hobbymatic 935. Needle will not move, mechanism around bobbin will not move. Everything is locked in place. Tried cleaning everything, removed the needle (to get the fabric out of the way),...
It is likely the the bobbin holder is jammed up with cloth or thread. Take the bobbin holder out and turn the machine by hand, if it does not move it could have a broken timing belt or slipping coupling.
Apr 13, 2011 | PfaFF Sewing Machines
Thread tangled in the bobine
I had this same problem yesterday. I took apart the needle tension casing and now it doesn't get tangled or stop. The only thing is the bobbin is not sewing...it looks fine on the top, but the bottom is just loose loops.
Jan 17, 2010 | Singer 3116 Simple
I am the one who had the problem of the bobbin case moving around and not letting the machine sew correctly. I lossened the screws to the right and slid the metal plate a little closer and the thread is...
Now you need to adjust the tensions, make sure you thread the machine with the presser foot up, top tension should be about 4 or 5, you should be able to pull the bobbin thread through with slight resistence, if it is too tight slacken the large screw on the bobbin case about a quarter of a turn at at a time anti clockwise and test sew until you get it right, do not use very thick threads.
May 13, 2009 | Singer 132QRFB Mechanical Sewing Machine
Doesn't draw up the bobbin thread
Sounds like a timing problem. Can only be fixed by a technician
Apr 11, 2007 | Singer Quantum 9910 Computerized Sewing...
Sewing Machines Logo
23 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
