Need replacement for Carousel
My carousel cracked one time. Then later it broke into. It was not being used abnormally. It just happened.
    President:
  • 412 Answers
I'm assuming you need a replacement Slide Tray. If so, contact: www.vinevalleyimaging.com to purchase a slide tray!
Posted on Nov 05, 2012
SOURCE: Kodak Carousel 760H wont advance or reverse
Yeah. I like the $15 fix better. Go to Ebay and search for "Kodak Carousel Projector Advance Repair Kit". Before you purchase you can diagnose, and it comes with detailed instructions. The same guy also has a kits for other common problems, as well as the "tune up kit". Or you can buy the Solenoid Link, directly and try it without detailed instructions.
Posted on May 22, 2009
SOURCE: replacement bulb for Kodak Carousel 4400 Projector
Search for FHS lamp on Amazon or ebay.
Posted on Feb 03, 2010
  • 412 Answers
SOURCE: problems with using a 140 carousel on a Kodak 4600
There is nothing wrong with your slide trays. Your projector needs an adjustment to the cycle contact assembly. The constant cycle mode is a dead-giveaway. You need to take the projector to an Authorized Repair Dealer for this adjustment. Should be relatively quick - - it takes longer to get the case apart than to make the repair!
Posted on Nov 04, 2010
  • 412 Answers
SOURCE: I just purchased an older Kodak slide projector
By the sounds of your description, your projector needs an adjustment to the slide change mechanism. This is best done by a factory-trained dealer, who has the service manual. Sorry I can't be of more help. Happy New Year!
Posted on Dec 30, 2010
  • 412 Answers
SOURCE: Carousel 4600. Dropping resistor is crumbling.
The dropping resistor is a 3 ohm, 30 watt resistor. It is available from: www.micro-tools.com
Posted on Jan 03, 2011
Door won't open, carousel won't spin, buttons light up but nothing happens. If the carousel is out of alignment, how can I fix it?
U have separate motors for the door opening and closing as well as the carousel spinning. Chances of both motors going fubar at same time is nil. .What do they both have in common? Yep, power supply!!!
Feb 03, 2016 | Audio Players & Recorders
How to remove a carousel stuck on a Kodak Carousel projector
No problem! FIRST, make sure the locking ring is in place and tight on the top of the tray. Next, locate the center hub (the hole in the center of the tray fits over it). In the center of the hub you will see either a "coin slot" or a small metal lever. Push the lever in the direction it will move and at the same time lift the tray off the projector. If you have a "coin slot), use a quarter to turn the coin slot until the tray is released. Turn the tray upside down, replace any slides that may have left the tray when it became stuck, and rotate the bottom metal plate until it locks in the locating slot. Turn on the projector and cycle it a few times IN REVERSE without a tray on it. this unlocks the jam in the projector. You should be good to go now!! Good Luck !! Jim
May 05, 2012 | Kodak Carousel 4600 Slide Projector
Hi, my husband bought me your KAMENSTEIN WORLD OF MOTION SERIES ANIMATED HORSE CAROUSEL many years ago. I did not keep the box or manual and now I want to ask can you e-Mail me a download or one I can...
I cannot loacte an actual manual but....The Kamenstein Carousel teapot was part of the MKI versions of teapots Kamenstein released in the mid-2000s. The teapots came in a range of colors, from blue to red, and they had a small carousel on the top. As the water boils the carousel spins around, bringing an element of whimsy to your tea time. The teapots are all metal and can be used on any type of stove top.
Instructions
    • 1 Fill the Kamenstein Carousel teapot with water just below the sprout.
    • 2 Place the Kamenstein Carousel teapot on the stove and set the heat to "Medium."
    • 3 Allow the water to come to a boil and remove the Kamenstein Carousel teapot from the stove.
    • 4 Pour the hot water into a cup over a tea bag.
Read more: How to Use a Kamenstein Carousel Teapot ' eHow.com http://www.ehow.com/how_7718254_use-kamenstein-carousel-teapot.html#ixzz1JAQxUJn2
Thanks
Apr 10, 2011 | Vacuums
The lever that drops the slides gets stuck in the 'up' position when the carousel is on the projector but it works fine when there is no carousel attached. When it gets stuck you have to take the carousel...
If you are using a 140 tray with older slides, that's very logical! Over time, slides develop a "side-to-side curve". Because the Carousel 140 tray stretches the design limits of the projector to be able to accurately return the slide to the tray, the slightest bend or "dog-ear"(the fraying of the corner of the slide) will cause exactly the problem you're having. If you have a Kodak 80-Slide tray, try it. Chances are that it will work fine. If it does work fine, then you have 2 options: 1. Move all your slides into Carousel 80 Trays.
2. Have your slides re-mounted (that is, have the paper mounts replaced).
I hope this helps !!
Feb 14, 2011 | Kodak Carousel 4600 Slide Projector
We have a Gemmy airblown carousel with four figures inside. It will only partially inflate. We have unzipped everything and untwisted everything. The bottom inflates and part of the top but nothing in...
mine is doing the same it gets twisted cutting off the air supply. I unwind it and lubed it but it continues to happen. there seems to be some sort of spring on the inside at the based. i'm thinking of cutting the tie straps and seeing whats inside...
Nov 29, 2010 | Carousel Airblown Inflatable Christmas...
Broken carouself? Can't properly open, close, rotate, etc.
Broken gears. The current replacement 5 disc is a CD/DVD player and sells for $129.00 at Sony or any other Sony retailer. The cost to have a service center even estimate the repair would be more than 50% of the replacement cost. Hope this helps
Nov 19, 2009 | Sony CDP-C265 CD Player
Kodak Carousel Projector 760 H, Carousel will not move
Given the age of your Carousel 760H, the most likely cause is a broken "Link". The "Link" connects the cycle solenoid plunger and the slide change mechanism. The "Link" is made of plastic and gets brittle & cracks over time, rendering slide change non-functional. Parts are still available (www.micro-tools.com), but this is an involved repair is best left to a factory trained technician with a service manual.
Apr 05, 2009 | Office Equipment & Supplies
Carousel will not turn
You can order a new carousel from Capresso. It's $90, though:
http://www.capresso.com/pdf/order-ultima.pdf
Make sure the lever is up when turning the carousel, and keep the button at the back of the machine depressed while screwing the carousel onto the unit (and while taking it off the unit). I think the positioning of the button point at the beginning of the carousel replacement process is also important:
http://capresso.com/pdf/inst_esp_ultima.pdf
Mar 28, 2009 | Jura Capresso Ultima 121 Espresso Machine
Replaced toner but keeps saying replace supply using black only
This happens occasionally with after-market (refurbished) cartridges. Sometimes the people rebuilding the cartridges forget to replace the microchip on the cartridge that resets the copy counter. Most reputable re-manufacturers will send you a replacement cartridge if this happens.
It could also be a carousel alignment or sensor issue inside the printer - if this is the case you will have to call HP for service.
Whatever you do, make sure you do not try to manually rotate the carousel to change out the different cartridges - each time you want to change a specific color, close up the printer first and then press the carousel rotate button that's directly under the ready light, keep pressing until the display says that it's rotating to the color you want, then open and change that color, repeat for each additional color.
Oct 13, 2008 | HP LaserJet 2840 Printer
26 people viewed this question
k24674
jasbo
jasbo
