Legend tv in rv won't scan channels
The tv is hooked up to the RV park cable hook-up but it isn't identifying any of the scanned channels
4 Suggested Answers
  • 81 Answers
SOURCE: Skyworth hd tv I can
If your TV is connected to the cable pole via Coaxial cable (screw on cable), you need to make sure your TV is set to either channel 3 or 4. If you aren't hooked up via Coax cable then you need to cycle through your inputs with your TV remote. Further info on how the TV is connected would help diagnose the issue.
Posted on Jul 18, 2011
motor1258
  • 6674 Answers
SOURCE: I installed a coby tv
If you've tried all positions with antennae, booster switch is on, and are sure you have all settings on TV correct, try running an alternate cable directly from antennae head to back of current plate where your co-ax from antennae is attached. That will tell you if you have a bad cable or connection from antennae to plate inside. Just get a piece long enough to go through door or window to current spot where connected. If that doesn't cure it, then it's a head or booster switch problem. You can even by-pass the booster and go direct to TV to see if any better.
Posted on Oct 16, 2011
SOURCE: Have a 42 inch Legend
make sure cable is hooked to the right outside connection . had same problem two connections one for cable one for satellite.
Posted on Dec 06, 2011
Getting no cable channels.
Check and replace its tuner. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Feb 04, 2017 | Sanyo Televison & Video
I have a sanyo tv that worked fine on sat at home now in my rv. changed to air antenna and channel scan only shows rv channels the returns to need to scan screen
Check and replace the main system control memory IC. It is faulty. If you wish to get some details; check the site linked here. Pull up older posts.
Jun 24, 2016 | Sanyo Televison & Video
How do I get back my local channels on my Vizio by rabbit ears
Make sure that you have the TV tuner set up to receive ATSC (digital) signals via "Off Air" or "Antenna". Having it set to the "Cable Ready" mode will only get you Ch 2 - 13. These settings are usually available in set up and may even allow the TV to scan for available channels, etc.
Jul 24, 2015 | Winegard RV-5095 Sensar II RV TV Antenna...
32in Vizio getting no channels
You have to go to your menu screen and change the settings from antenna to cable that should take care of it, and should be able to do a auto scan to load channel memory
Mar 26, 2013 | Vizio VX37L Television
My Vizio LCD HDTV isn't pickup up all of the cable channels, but my other older TVs are?
Did you retry a working TV again on the same input, as it looks like a case of loose contacts in the RC Jack, cable or connectors or some strands of the cable touching the ground. Then check whether your Vizio TV supports the system/format of the cable. If your cable is licensed to be used only with the other TVs, like sensing the identity of the PC used, it could also be a problem
Aug 22, 2012 | Televison & Video
I installed a coby tv in my RV. Auto scan worked great for a year. Today it picks up no channels at all. Everyone else in RV park has 20+ channels. The scan performs everytime, but picks up nothing
Sep 03, 2011 | Coby TFTV3227 32 in. LCD TV
Skyworth hd tv I can only get the DVD part to work. I have no manual to refer to. I'm in an RV park and the tv is hooked up to Cable at the pole and my RV. I am sad. What to do?
Jul 18, 2011 | Televison & Video
I just bought a sanyo dp42841. I used to have the same tv in a smaller size. The first tv was hooked up to the cable and worked fine. When I attached the same cable to the new tv it's not able to find...
Be sure your cable is hooked up good and if you did not auto scan you must do this (auto scan) Found in the menu setup. Use the remote and press menu and it is usually found easily. Highlight the auto scan and start the scan usually by pressing volume +
May 20, 2011 | Sanyo 42 in. LCD TV
Legend LCD LC1916L TV Picture
If you unplug the unit from wall plug for ten minutes, it should reset the picture. I would unplug the a/v cables also in case of a ground loop
Feb 29, 2008 | Televison & Video
Televison & Video Logo
214 people viewed this question
Top Televison & Video Experts
