My Magnavox T.V won't allow me to watch actaul Tv
Hello, I have been having problems with my magnavox tv. I was trying to watch my Direct tv and it began saying "Please program channel memory" I had no idea what that meant so I did the auto program, Switched it over to Antena, Again it did not work so i programmed it again and switched it over to Aux...whatever that is. and still nothing, Please help. I'm not sure what to do. ~Thank You, -Kerry Waddingham.
    Genius:
  • Televison & ... Master
  • 2,432 Answers
You will need to tuned every channel then save it to the memory. you can use the user manual of your tv for instructions. if you don't have user manual i'll try find from you, just give me the model of your tv.
Posted on Nov 04, 2012
  • Kerry Elisabeth
    Kerry Elisabeth Nov 04, 2012
    I am sorry, I am completly clueless when it comes to stuff like this, What is a model of the tv and how do I find it? Thank you, Again.
  • francoise cleofas
    francoise cleofas Nov 05, 2012
    ok, the model no. is located at the back of the cover of the tv.
2 Suggested Answers
  • 10 Answers
SOURCE: Philips Magnavox 2783 c101 - will not auto program tv channels
Ya what you got to do is Grab your tv, and throw it out your window. Garbage tv with built in problems made to be fixed. I had the same tv and i had many problems with it before. Just buy a new one boss.
Posted on Feb 17, 2010
Philips magnavox tv model 9p5511c101
if it was working ok before then ring up and complain and get him back as he did not do the installation properly.
Jun 09, 2013 | Sony KDS-R60XBR1 60" Projection HDTV
Direct TV remote control won't work with my new TV
These are 4-digit codes : 0054, 0030, 1454, 0020. Here are 3-digit codes : 006, 007, 010, 011, 013, 016, 027, 033, 035, 043, 066, 087, 089. Try these.
Dec 06, 2007 | Philips Magnavox 27MS343S 27" TV
Magnavox tv won't turn on or off
The typical cause of power up problems in a failure of the power supply filter capacitors. The board can be repaired by replacing the bad components. Below is a picture of the power supply board with the bad capacitors circled and below that is a link to a it that is available with the correct parts to rebuild that board.
http://www.ccl-la.com/catalog/product_info.php?products_id=216
I hope this helps you out,
BuddyMc
Sep 25, 2012 | Toymax Magnavox 37MF331D 37 in. LCD TV
What is the purpose or function of the FUN-LINK(HDMI CEC)?
The fun-Link option means that the Magnavox TV remote would control other Magnavox (and possibly other Funai manufactured) products (DVD or Blu-ray player) that also have the fun-Link protocol and are connected to the TV on the HDMI port. You can set the function to always turn on or off the accessory when you turn on or off the TV. Alternatively, turning on the accessory will turn on the TV.
Usually the model number is on the back of the TV. Many Magnavox manuals are available from the manufacturer's support page: http://www.magnavox.com/support/download_list.php .
One Magnavox TV with the fun-Link option is the 40ME313V. The manual describes enabling the feature on page 29. The direct link to the manual is http://www.funaiport.com/upload/MAGNAVOX/Manual/40ME313V_EN_OM.pdf .
I hope this helps.
Sep 17, 2012 | Magnavox 40" 1080p LCD HDTV - TV...
My 1996 Magnavox 25" TV won't work
It sounds that the tuner to your TV is faulty. A detail check is necessary to confirm. Seek expert tech support.
Jun 20, 2012 | Philips Magnavox 13MT143S 13" TV
I need programing codes for magnavox tv
Hello
Three digit universal remote codes for Magnavox TV are:
004/ 008/ 009/ 062/ 068/ 069/ 074/ 075/ 076/ 077/ 089/ 133/ 163/ 165
For Philips Magnavox are:
183/ 184/ 208/ 213
Four digit universal remote codes for Magnavox are:
0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Jul 23, 2011 | Televison & Video
I have dish network and its programmed to work on channel 60 of the TV set, but lately the TV has began changing to a random channel from the "Favorite Channels" list and its making watching...
Hi my nameis Mike Houston of DISH Network and I see you have the TV setup to watch yourprograms on channel 60 and the TV is skipping off that channel. You want tomake sure the TV is on channel 60, make sure the remote is in SAT mode and tryto go to different channels and make sure it stays on the satellite channels.If you have any questions please e-mail me at michael.houston@dishnetwork.com.
Dec 08, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
Electro Med Services...
