Question about Jensen Q2049J 20" TV
Horizontal white lines
I am working on a Jensen Q2049J 20" TV.The problem : horizontal white lines across the screen when i turn the tv on with no image.I can't adjust the Hv.what could be the solutions?
    Problem Solver:
  • 10 Answers
If you cant adjust the A1s then it sounds like the F.B.T. is up the swanny (faulty).
Posted on Jun 02, 2007
My jensen tv all of sudden has a blu screen with a lock symbol on the corner, it does not want to change channels or anything
To remove the lock on the Jensen simpy press and hold the Display Button on the remote for at least 3 seconds whilst pointing it at the TV.
The lock will be removed and the TV will resume normal operation..
Please do leave a vote for the solution. Thanks for using FixYa
Sep 29, 2010 | Jensen Q2049J 20" TV
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
The picture is smashed down to a narrow horizontal line
Check solder on the vertical output or change it. Dont know # but look for IC screew on heat sink with about 7 to 14 pins.
Apr 28, 2010 | Jensen TS2050J 20" TV
Dropped tv 5 inch on its face while moving. Tv
It is highly probable that the main board is cracked due to the drop. An experienced TV repair person can run jumper wires across the cracked board. You can verify this by opening the back of the tv up and pulling out the main board and search for cracks on the bottom of the board.
Dec 28, 2009 | Jensen Q2049J 20" TV
2 Problems - Small white horizontal line. Black Lower part of screen
Try changing the TV's display format from widescreen to fullscreen.
Sep 21, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
Toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Sep 05, 2006 | Toshiba 27A30 27" TV
Jensen Q2049J 20" TV Logo
279 people viewed this question
Top Jensen Televison & Video Experts
Jaime Hernandez
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
