Question about OKI C5800dn Laser Printer
OkI C5800 error 923 - OKI C5800dn Laser Printer
Patrillica
  • 141 Answers
SOURCE: Oki c5800 laser printer
http://www.c5800.co.uk/index.asp?printername=C5800&menumode=0&content=C5800downloads
At the bottom you will see the file C58uEN1.pdf
Go to page 89
Posted on Mar 26, 2008
ronaldsuboc
  • 449 Answers
SOURCE: OKI C5800 ERROR MESSAGE- DRUM
hi!!!
try to check the drum first!!!
clean it with the dry tissue?
there a lifespan of the drum
i have the same problem with that.
my drum capacity is only 30,000 copies
so then i replaced it! and works fine now
so try to replaced the drum it might on it capacity
or clean it
try to email me ronaldsuboc@gmail.com
Posted on Sep 19, 2008
Joed911
  • 4338 Answers
SOURCE: OKI C5800 SHOWS: ORDER K TONER
If you have replaced the K cartridge, and it still gives you this message, it is due to the sensor bieng blocked or bad. Take out your K cartridge, clean out any loose toner. Do not blow it back into the unit. Use a cotton pad or cloth to clean it out. Then you have to clen the sensor itself. it is recessed on the right wall of the unit ,across where the K cartridge sits. Here is where you have to purchase a can of compressed air and shoot it into the opening with the plastic straw that comes with the can air.. (Again, do not blow air all over the inside of the unit!!) Just shoot it in the opening  to clean the sensor LED. This is a common problem caused by toner spills.
If I could be of further assistance let me know, Otherwise please rate this solution. Thanks,Joe
Posted on Apr 24, 2009
LizBux820
SOURCE: Have an OKI Printing Solution
Found this at Fixyourownprinter.com
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
Posted on May 26, 2009
  • 97 Answers
SOURCE: fatal error 231 on oki c5800 after changing toner,
From the service manual, doesn't look good.
A technicain will have to look at the printer.
RFID Reader I/F Error
An interface error was detected with the RFID reader device.
01 : communication error between the RFID reader and the engine PCB.
02 : the transceiver circuit error of the RFID reader.
03 : communication error between the RFID reader and the Tag chip.
04 : the RFID Tag detection error (more than 4 chips).
If rebooting the machine does not improve the symptom, you need to
check the device.
Posted on Mar 29, 2010
Error 980 on OKI C5900 fatal error
First, there is no model C5900. There is a model C5800. On the assumption that you are having this issue with a C5800 then the problem is media wrapped around the fuser. After cooling you can try to unravel or unwind the wrapped media but you may need to replace the fuser.
Jan 20, 2014 | Oki Electric Industry C5900N Led Printer
Oki c5800 belt life reset
It may require a complete service kit, you should check with Okidata to see if there is a kit available or what steps you should take to reset the life counter.
Jan 29, 2013 | Oki Electric Industry Okidata C5500, C5800...
Oki c5800 printer with a sensor malfunction, where do I find this sensor? How do I eliminate this problem? Toner sensor error
The toner sensor (43131601) is located on the right side of the sub-chassis that holds the Drum/ Image units. It may be defective.
Whit
Item, Inc.
Aug 17, 2010 | OKI C5800dn Laser Printer
Fatal error 231 on oki c5800 after changing toner, tried power off/on still doesn't work
check the device.
Mar 08, 2010 | OKI C5800Ldn Led Printer
FATAL ERROR 923
923 - black image drum lock error
make sure the black drum is in correctly
make sure black toner is locked
reboot machine
Feb 16, 2010 | OKI C5550N Multifunction Printer - Color...
Have a oki c9800 ...gives error 923. have replaced the motor unit for black image drum but it prints some pages and gives the error again
923: Error - Black Image Drum Lock Error
The K ID unit is not operating
properly.
Check to confirm that Image Drum is seated properly.
Check to confirm that the K ID
unit is in position.
Replace the K ID unit.
Replace the K ID motor.
Dec 10, 2009 | OKI C9600hdn Laser Printer
Oki C5800 constant 172 fatal error
This error code means that the fuser temperature is low. You need to replace either the fuser or the thermistor inside the fuser.
Apr 15, 2008 | OKI C5100n Laser Printer
OKI C5800dn Laser Printer Logo
333 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
