Question about Samsung HL50A650 50 in. TV
Mitsubishi wd-65738 ballast
I have replaced the bulb three times. it works ok for about an hour and then the picture starts to flicker and then eventually shuts off. i have heard that it may be the lamp ballast or ballast board. it that the same thing or two separate entities? can i install a new board myself or do i need a repair person to do it?
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Ballast and ballast board are same thing but something to consider:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Posted on Nov 03, 2012
2 Suggested Answers
ekcnoel
  • 998 Answers
SOURCE: Bought this TV used and was told it needed a
Sir when replacing the bulb you should reset the lamp hour meter. 1. while on the standby mode press "mute" then the numbers 1,8 and 2 in succession, and press the power button.
2. wait until "loading factory" appears on your screen and the service menu is displayed with the lamp life hours. You will see a list of service options.
3. Scroll down to "option" and press "enter". next you will see "reset lamp" where you will press again the "enter" button. good day and best regards.
  • 2 Wait until "Loading Factory" appears on your screen and the service menu is displayed with the Lamp Life Hours. You will see a list of service options.
  • 3 Scroll down to "Option" and press "Enter." Next you will see "Reset Lamp" where you will press again with the "Enter" button.
  • Read more: How to Reset the Lamp Hours on the TV ' eHow.com http://www.ehow.com/how_5535314_reset-lamp-hours-tv.html#ixzz1VIGJC5k7
    Posted on Aug 17, 2011
    I have a mitsubishi tv model wd 60638 I changed the lamp. Tv works fine for about 20 minutes then I start to smell like something is burning then picture starts to flicker, what could could cause this
    You have a bad connector in the lamp. Stop running the TV immediately and contact the company you purchased the lamp from. this is common in older DLP tvs but not in one 5 years old unless you have a lot of hours on it. the connector can crack and arc inside the plug and then melt and smell terrible. It usually very repairable if you can get a ballast for it. the plug is part of the ballast.
    Aug 28, 2015 | Mitsubishi WD-60638 DLP TV
    Replaced lamp on my Mitsubishi 82 in dlp. after 15 minutes pic started to flicker losing color. was advised to also change lamp ballast, did that but still flickers with new lamp. put old lamp back in tv...
    When you put the old lamp back in did the picture look OK? If so why did you replace to begin with? Yes, there are some poorly manufactured lamps out there, where did you obtain the replacement? Was it true OEM?
    Dec 04, 2014 | Mitsubishi Wd-82837 82" Inch 3d Full Hd...
    65738 colors flickering after bulb replacement
    check the colour wheel in the light engine most likely bearings are worn needs replacement and the colors will stabilize need to open the light engine and replace with a new one
    Mar 08, 2013 | Mitsubishi WD-65738 DLP TV
    Mitsubishi wd-65738 flickering
    The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
    May 25, 2017 | Mitsubishi WD-57833 57" HDTV
    Wd65738 flickering
    I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
    Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
    I have a mitsubishi wd 65738. My picture suddenly went dim. I can still see a picture but the room has to be very dark and its still hard to see. Do I just need to replace a bulb?
    Hello
    Its bulb has got traoubled or its control circuit has some faut with it. it is not a user serviceable item. Replacing bulb can be done by the user according to the instructions in its user manual. But trouble shooting its control section must be done be any experienced service technician. OK.
    May 27, 2011 | Mitsubishi WD-65738 DLP TV
    I have a Mitsubishi WD-57734 and the picture when out on it. It's 3 years old and seems logical that the bulb burnt out. We still here the sound. I started looking at replacement bulbs and found other...
    U used this tv 3 years?The tv been on and watches like 4 or 5 hours every day?Yes,than the tv projection lamp life is over.Require a new tv projection lamp.U also hear alot of cliking sounds,when tv first turn on?Yes,than the Ballast board is also dead.The Ballast board job is to help to ignite the tv projection lamp.
    Nov 16, 2010 | Mitsubishi WD-57734 57" HDTV
    Mitsubishi wd-52525 no picture or sound
    http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
    http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
    http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
    http://hdtvoice.com/voice/showthread.php?t=32186
    replace DM
    Jan 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
    Samsung HL50A650 50 in. TV Logo
    178 people viewed this question
    Henry  Thomas
    Henry Thomas
    Jerry Greenberg
    Jerry Greenberg
