Question about Frigidaire Refrigerators
Fridgidaire side by side no water to ice maker water dispenser okay
It simply stopped making ice one day. The water comes out fine. It was bought in May of 2010.
  • Sharene Pomnitz Nov 03, 2012
    There is ONE filter in the INSIDE of the fridge then thevwaterbgoesbto ice maker and door from ther. Sorry forgot to mention that.
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 03, 2012
  • 2 more comments
    FRS3HR3HR35KSO That is what it says on the door.
  • Sharene Pomnitz Nov 05, 2012
    Well, it just started working again yesterday, just as quickly as it stopped. I don't understand, but am thankful.
  • Richard Roth
    Richard Roth Nov 05, 2012
    I am glad it is working again!
    Thank you.
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Posted on Mar 23, 2009
heatman101
  • 43501 Answers
SOURCE: Ice maker will not make ice, water dispenser is working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
oypyiooiyp
Posted on Sep 30, 2010
  • 23 Answers
SOURCE: Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Posted on Dec 08, 2007
SOURCE: ice maker broken
Our is broken as well. Water dispenser works.....
Posted on Feb 24, 2008
I have a Whirlpool Gold GD22DFXFW02 side by side fridge/freexer with ice maker and water dispenser. Besides the fact that the water dispenses very slowly, the ice maker has stopped making ice. It appears...
Sorry to read about your problem, I hope this helps you out.
yes no water to the unit
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Whirlpool Refrigerators
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer not making ice in Fridgidaire model PLH269ZDB2
There is a lever in the ice bin that detects when it is full. if that lever is locked in the"up" position, the maker stops making ice. Many times a previous owner or a shipper will turn off the icemaker this way. especially if the water to the home or freezer is turned off, so it won't keep trying to make ice.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
I have water in the dispenser but the ice maker doesn't fill
replace the solelnoid for the water dispenser in the back of the fridge
Oct 18, 2008 | Frigidaire FRS3R5EMB Side by Side...
It may be that the filter (if you have one) may be plugged up. Some have in-line filters that need replaced occasionally, especially if you have hard water. Trace the water line and look for something that looks like this:
d931a8c.jpg There is a small connection on both ends.
Some fridges have a filter that is similiar to an oil filter and just twist in.
If the problem is not the filter, you need to check the connection that you line comes from to make sure you have water available at the source. The supply line itself may be plugged.
Oct 09, 2008 | Frigidaire GLRS264ZA Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
ICE MAKER
See the following fixya thread:
http://www.fixya.com/support/t127529-water_ice_dispenser_not_working
Dec 14, 2007 | GE GSS25JEMWW Side by Side
Ice Maker
I would be happy to help. When you say it stop dispensing, do you mean it didn't drop the ice into the bucket or it didn't dispense thru the door? Also, make sure the arm on the icemaker is completely down. Fridgidaire has had some problem with the arm not coming down all the way and leaving it in the off position. Let me know so I can help.
Nov 11, 2007 | Refrigerators
Water dispenser and ice-maker do not work
open ice maker cover buy pass T_H will move if still water not come in ice maker change fill valve
Sep 03, 2017 | Refrigerators
Refrigerators Logo
106 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
