Question about Bunn BTX-B ThermoFresh 10-Cup Home Thermal Carafe Coffee Brewer, Black
Unit leaks water from the rear
There seems to be a hole at the back of the maker. Would that be a overflow as it was leaking water out of it?
    New Friend:
  • 5 Answers
There is a recall on certain makes of pots for the gaskets. They have a pot repair program that costs money, or you can request the parts from the company they will send you the parts and instructions on how to replace defective part if your pot is part of the recall.
Posted on Apr 28, 2016
SOURCE: Water leaking
The silicon seal inside the coffee maker tends to disintergrate. Bunn Inc. does not sell parts for the inside of the coffee makers, but a seal kit can be purchased through a small appliance repair center or repaired for a small cost. Kit is about $8.00 at most places.
Posted on Apr 13, 2009
SOURCE: My Bunn coffee maker is leaking water
  1. Remove nut and gaskets
  2. Mix small batch of JB Quick (a version of JB Weld)
  3. Spread JB Quick with putty knofe or wide screw driver on bottom and top of degraded plastic around hole
  4. Let dry foe four or five hours (speed us slightly with hair dryer)
  5. Smoothe hard but uneven surface with fine sandpaper
  6. Reassemble
Posted on Oct 28, 2008
danforddan1
  • 192 Answers
SOURCE: water leaks out from underneath coffee maker
Well they don;t give these away for sure. Lets see if we can help you out. ? are you over filling it.This happened to me because I was reading the fill line wrong. {got new glasses} . If not may be you could try makeing less. But if only 1/2 cup comes out and no more, that wouldent indacate a leak in the tank, if there was it would all leak. Try backing off on the coffie and water, and see if it still leaks. if it does get back to me. DFD
SOURCE: Water is leaking from the unit.
Bunn makes a repair kit for this problem, Call them at 1-800-352-2866
They send the repair kit free,
Posted on Apr 21, 2009
  • 34 Answers
SOURCE: my bunn coffee maker is leaking from the top where
you need a new one.
try this link. hope it will help you with your problem.
http://www.coffeemakerwizard.com/4-cup-coffee-makers.html
Posted on Feb 01, 2010
Leaks water from bottom
Is it really from the BOTTOM, or is it spilling out the overflow holes in the back, then running down to the counter? If it's just spilling out the overflow holes, don't put quite so much water into it.
If it's really leaking from the bottom, and it happens even if you put only one or two cups of water into it, then the little hose running from the heating element inside up to the top filter has cracked or come off. You can fix that by opening the bottom of the coffeemaker (UNPLUGGED FROM THE WALL). You'll see where the rubber hose connects to the heating element and runs up along the rear tank. Check the connection where it attaches to the heating element.
Jul 31, 2014 | Gevalia CM-500 12 Cup Coffee Maker
Leaking water out of back of unit
if the hole is near the top it is an overflow hole- so you can not put in to much water. unplug coffeemaker ,and take to sink- turn over and drain completely. set it back up and try again filling coffee put to just the top cup line and no more..
Dec 22, 2013 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Water dispenser leaking
Ck level sensor. the trouff holds pre cooled ice maker water,seems likely overflowing from than leaking!
Sep 01, 2012 | Maytag Refrigerators
The freezer has an obvious leak. When we wait a few days, we can see that water leaked into the freezer and it turned into a large brick of ice? What does that mean?
Hi Monica,
This seems to be a problem with overflow of water into the ice maker, or a leak in the feeder to the ice maker. My suggestion is to turn off the ice maker by raising the lever on the unit, and see if the ice re-accumulates. This would mean that the water is leaking from the inlet, and the ice maker has no obvious fault. If you find this, you can remove the ice maker from the freezer by removing the screws holding it to the inside, unplug the unit from the back of the freezer, and pull straight out. Look at the inlet of the water at the rear of the freezer and see if there is a break in the line or a crack somewhere along it. You can replace it from the back of the refrigerator itself, going from the bottom where the water is hooked up to the top by removing the panel that guards it.
I hope this isn't too confusing.
Joe
Sep 13, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Leaks out the back hole...am I missing a plug?
Nearly all coffee makers have an overflow to avoid having water leak into the electronics. If well-designed, they will overflow into the basket area first and only later run out of the back if overfilled greatly.
Nov 23, 2010 | Cuisinart DCC-1200 Coffee Maker
I have an U-line combo 75A and the ice maker(part number 400) has started overfilling. When water enters the ice maker, it runs out the overflow hole. Any suggestions?
few thing can happen, bad thermostat it caused the ice maker stuck in harvest cycle, short in ice maker defrost heater, bad water valve switch or the overflow hole drilled to low, it should be 1/4 inch below the top, I seen some of them drilled 1/2 inch below and it caused water leak.
Feb 24, 2010 | U-Line Uline Origins Series...
Rear water leak
Hi
Water coming from the back of the refrigerator usually comes from either the ice maker water valve or line (if there is an ice maker), or from the defrost drain pan.
Here's what to do:
  • If the water is coming from the ice maker water valve, check to make sure the water tubes are attached properly and are fastened tightly.
  • If the water seems to be coming from any part of the valve itself, replace the valve.
  • If the water appears to be coming from the defrost drain pan, inspect for holes or cracks, and replace the pan if necessary.
Please revert for further assistance and Do accept the solution if found useful.
Thanks
Rylee
Mar 18, 2009 | Refrigerators
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Dehumidifier m7dh65b2a
Mine leaks. Had leaked at other times but i took the vacuum cleaner to the front drain spout, that leaks into the removable basin. That worked in the past, but i't's not working now . The water is overflowing at the back of the catch tray and leaking out through the bottom underneath. The holes are clear, so it shouldn't be doing this. I am stumped.
Jul 04, 2008 | Maytag M7DH45B2A Dehumidifier
Leaking water
test: first, turn off water supply to frig. then dry up all water. then ensure frig is running at right temperature. now gradually turn on water and observe where leak is. My guess is it is overflowing the ice-maker. there is an adjustment for this. pop off the cover over the end of the ice-maker. look for a screw adjustment. turn it counterclockwise.
Jun 04, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Coffee Makers & Espresso Machines Logo
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
