Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I have a whirlpool cabrio washer and after a power outage it will not light up or start
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
If you have power to the outlet and the machine does not power up then the control board is fried. All the newer appliances with the electronics need to be on a surge suppressor to prevent this from happening. I repair these machines all the time and it is always the same. Happens after a power outage.
Here is the control board to order.
Here is the complete service manual for that unit also. Keep a copy of it. It will come in handy and will show you how to replace the control board. Look at page 4-5 for the control board replacement.
Keep me posted!
Posted on Nov 03, 2012
57 varieties
  • 1653 Answers
SOURCE: washer whirlpool cabrio message code f50,washer
F50 - This is a motor stalled failure. If this persists you will eventually need to call in a service engineer to repair it as the machine will eventually stop working altogether.
Posted on Oct 02, 2009
SOURCE: whirlpool wtw6200 cabrio washer error message f 51
I work for an appliance repair company and I had a recent service call for the same exact situation on this washer. I also know that Rotary Position Sensor is linked to the F-51 error code. I have found that this is not always the case. On this paticular call the F-51 error code was caused by a piece of clothing (sock, wash cloth, etc.) being stuck or jammed between the internal basket and the outer tub. I removed the cloth and the washer ran fine, so give that a check first before you spend the money.
Posted on Jan 01, 2009
  • 82 Answers
SOURCE: Cabrio washer want start.
leave the door open and try it again if it does the same thing as before the door lock has gone
Posted on Jun 27, 2009
  • 39 Answers
SOURCE: Whirlpool washer grinding noise when draining
there could be something in your pump.....remove the pump and see if there is not something inside...
Posted on Jul 04, 2009
  • 180 Answers
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Posted on Nov 27, 2009
Whirlpool cabrio propane dryer won't heat. We did have a power outage today
If it has a standing pilot light, that might be out. If electronic ignition, try unplugging from power for a while and see if that resets control board.
Jul 22, 2017 | Whirlpool Dryers
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
    Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
    check these one by one.
    Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
    Whirlpool Cabrio wtw6600 stops at rinse and flshing light and sound, then afert pressing pause resum washing
    Press STOP/CANCEL to clear the display and completely cancel the cycle
    flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
    Press START to continue the cycle from the moment that power was lost
    Mar 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Jun 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Push start button on control panel - machine does not start
    only 2 things can cause this.
    1 the control is set to lock out mode. just hold the lock button for 5 seconds and it should go back to normal mode.
    or 2 the controls user interface has an internal failure. its the part that has the switches and tells the computer what to do. either way call whirlpool and see if its still covered by their warranty.
    of yeah and the 3rd thing is you have no power to unit. make sure the outlet is good by trying something else in the same outlet, like a light or hairdryer.
    Jan 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    383 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
