Question about Refrigerators
The bottom of freezer fills with water freezes,then run out door seal,
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 03, 2012
  • 1462 Answers
SOURCE: Defrost Problem
there is a drain in the middle of the defrost water collector and it is probably blocked - usually with ice. dry ot the tray and put very hot water in to melt the ice. you may have to do several times. do this until water flows away freely
Posted on Jul 25, 2007
SOURCE: water pooling and freezing inside bottom freezer
I had the same problem with my LRFC25750 and have finally figured out what's happening! The water that is pooling and freezing on the bottom of the freezer is definitely coming from the defrost cycle. It is pooling inside the freezer compartment because the drain inside the back of the freezer intended to carry the defrost water down to the external evaporator tray underneath is blocked with ice. As a result, the defrost water from the coils overflows the collector under the coils and runs down the inside back of the freezer, pools on the bottom, and re-freezes when the cycle is over. this continues until there's so much ice on the bottom that the water from next defrost cycle runs out on the floor. The "easy" solution is to unplug the unit and let it completely melt out (this could take 24-36 hours). I couldn't wait, so I removed the freezer drawers and their tracks and pulled out the back panel inside the freezer -- saw the ice in the collector and blocking the drain and I melted it away with hot water and verified that water could now flow down to the external evaporator tray. Unless you want to do this, I'd say give it a good 24-36 hours for all the ice to melt away. I think it all started when we left the freezer door ajar for a whole day and probably had a lot of frost build-up on the coils. The next defrost cycle was not enough to clear all the frost and things began to build up from there. Once the drain is frozen, though, you're finished -- the defrost heater doesn;t reach down that far and you have to melt it down completely or it will continue to leak forever. I've heard that you can get a drain heater to ensure that the drain never freezes over or at least so that it is sure to clear with each defrost cycle. I'll post an update if I locate one.
Posted on Sep 03, 2007
  • 1073 Answers
SOURCE: frigidaire frs26zthb3
icemaker is iver filling and running down through the freezer, some of the water runs out into the floor since the door gasket does not provide an water proof seal just an air tight seal
the ice maker can be adjusted, remove the cover off the frount of the icemaker and back the screw on the right side so that the indicator in the middle is twards the minus sign and you need to clear the frozen water out of the freezer drain pan so it can go to the drain pan down at the compressor
it might take a few adjustments on the ice maker to get it right
Posted on Apr 30, 2008
  • 29 Answers
SOURCE: Water Freezing in bottom of Freezer and dripping out front of freezer door
this could either be a blocked drain from the freezer not allowing defrost water to escape or the defrost heater failing to turn on due to a faulty defrost heater or defrost timer not enabling the water to escape
Posted on Aug 13, 2008
dykaar
  • 4 Answers
SOURCE: Sub Zero model 550 bottom
My Subzero 550 did this: The right side of the freezer has a drain that was plugged with ice. When the freezer defrosts the water runs down the inside of the box and onto the drawer rails, where it then freezes. The drain tube is normally kept ice free by an aluminum strap wrapped around the copper defrost tube in the freezer heat exchanger, which runs down into the drain tube. Over time the copper defrost tube gets some surface corrosion and the aluminum strap doesn't get warm enough during the defrost cycle to melt ice in the tube. If you can get it apart, you can clean up the tub surface with steel wool, or buy the electric defroster for the drain tube to replace the aluminum strap.
Posted on Oct 21, 2008
How do I repair water leaking in the bottom of the freezer on Maytag model MBF2258XEW
Check your door seals. The air gets in, the moisture freezes then the defrost cycle turns it into water.
Sep 14, 2014 | Maytag Refrigerators
Viking professional defrost cycles
Check the rubber seal inside/around the door. I bet you have a tear or piece of seal that isn't making a solid fit and it's allowing (warm) room air into you freezer. This moist room air will either turn to water droplets and builds up to enough droplets to form puddles in the bottom of the freezer, or it freezes into a blob of ice around the door seal and this allows warm room air into the freezer. Otherwise you need an Appliance Tech to check the Freon refrigerant level. Most times its the door seal causing this problem.
Jun 08, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Water in bottom of freezer it becomes a inch thick freezer door will not open model RFABWP
Check you ice maker. If the cubes aren't freezing the water will continue to fill the I e maker running down to the bottom and then freeze.
Nov 04, 2013 | Samsung Refrigerators
My bottom freezer has a sheet of ice on the bottom
Check your rubber seal around the freezer door...has the door become easier to open?....is the seal in good condition all the way around, meaning that you are getting a good seal all the way around the door? If not, you will need to replace it.
Nov 04, 2012 | Whirlpool GB2SHDXP Bottom Freezer...
I have a samsung rfg297aars refrig. I believe the water is leaking from the ice maker into the cube tray and running out and freezing in the cube dispenser and it is freezing the cubes together and...
you need to check the flapper in the door where the ice comes out,, if you take the ice bin out look down in the hole where the ice comes out,, if it is not sealing good it will let warm air come up the chute and melt the ice,, if it is sealing good,, then you need to check and see if the water fill tube( the one that goes into the icemake) is not froze up or has asomething blocking it
Jan 19, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
I have the freezer on the bottom. Love it. It's
possibly need to clean out vents/drains.make sure door seals all round.no air gaps. blocked vents/air leaks will cause fridges/freezers to work overtime..
Feb 17, 2010 | Amana 21.9 cu. ft. Bottom Freezer...
All water underneath.ice in the bottom.freezer working.not making
If I understand you correctly your water line that comes through the back wall of the freezer and into the icemaker is frozen. If so you have a bad water valve. When the valve goes bad it will not seal off the water. It will seep causing a slow drip where the water comes out at you icemaker. It'd slow enough to freez causing a ice blockage. This will not allow water to come through and fill your icemaker when it calls for water.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire frs26zthb3
Apr 30, 2008 | Refrigerators
GE frig just starting leaking water at the bottom of the freezer side door
more than likely you have a frozen defrost drain look in the bottom of your freezer section there should be a depression there see if its just a big block of ice let me know if this is the case or not and ill tell you how to clear the drain if not then we will look at something else please dont rate me till were done
Jan 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Defrost Problem
Jul 25, 2007 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
