Question about Qca Spas Majestic Series Aruba Xl Hot Tub
Hot tub won't start
    Problem Solver:
  • 6 Answers
More info needed.
I have had many hot tubs and had to fix them all.
First check:Plugged in, right?Is the GFI tripped?
Is there power on the HT control panel? little red or green lights, lcd display info, anything? Look up any codes you find.
After that little inspection, a number of things can go wrong. First Unplug the unit, then Open her up and look for any sort of anomaly. Photograph and post what you find.
GL,
John
Posted on Nov 25, 2012
Yamaha kodiak 450
Your float adjustment is incorrect, asis your fast idle
Jul 02, 2013 | Motorcycles
Hot tub won't come on
Start at the spa.
  • Do you have voltage coming to the terminal strip in the control box?
  • Is it the correct voltage?
  • Do you have voltage at any point after that?
  • Is there power coming out of the transformer?
these are the starting points to determine if you have a bad circuit board or a bad transformer.
Rod
US Parts Center
888-521-6182
Mar 27, 2013 | Jacuzzi Home
Aqua Flo Flo Master won't start on low speed
Water flow error on hot tub means low water flow. This is not enough water flow to turn the system on.
Some motors do have a start capacitor on them. you can certainly check that or take it to your local motor repair shop and they can check that for you.
Rod
US Parts Center
Jan 13, 2013 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
Hot tub won't get hot enough
Low Heat -
This problem is not usually associated with the heater element but more often a result of water flow issues. Specifically blockages such as dirty filters, partially closed valves etc... But... excessive scale/mineral build up on the element is on uncommon and can result in reduced heating. The fix is easy, use chemical treatments to reduce scale build up.
No Heat
No heat or water is only heating to 60F- 80F? If you are getting a low reading this is because the water is only being heated by the friction caused by running through the plumbing system and pump. Assuming there has not been a dry fire (visual signs of burn/overheat marks/ damage to the heater tube) and your temperature sensor and hi limit are in working order.
A bad element. Like a light bulb, spa heater elements will burn out over time & there are many factors which affect their longevity.
Nov 25, 2012 | Home
Check your filters and make sure they are clean.
Check to see if the heat indicator light is on when the tub is running.
Make sure the gate valves are open on either side of the pump and control box.
Are there any error codes in the little window on the topside?
Rod Kidman
www.uspartscenter.com
Nov 25, 2012 | Home
Fridgidare washer front load won't spin & there's water in the tub. It's about 10 years old
If it's that old, you're better off buying a new unit. You'll spend about half the cost of a new one fixing it.
Jun 11, 2012 | Washing Machines
Flo code is on and pump won't start up
Flo = Improper flow or pressure switch malfunction or Flow switch malfunction (system specific).
Before you purchase a new pressure switch:
- Clean or replace your filter cartridge (if its older than 1 yr).
- Check that all slice/gate valves are up/open.
- Check water lines for blockages incl. suction cover & ensure sufficient water level in spa.
Jan 29, 2012 | Qca Spas Majestic Series Aruba Xl Hot Tub
Qca Spas Majestic Series Aruba Xl Hot Tub Logo
244 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
