Question about Qca Spas Majestic Series Aruba Xl Hot Tub
Will not start error code 5 n 1 - Qca Spas Majestic Series Aruba Xl Hot Tub
    Scholar:
  • 111 Answers
SN1 is Hi Limit Sensor failure.
Your spa will not allow you to operate use it as this is a safety feature. You must replace the Hi Limit Sensor. They are usually plugged into the circuit board with connector similar to a telephone plug. The sensor usually runs from the board to a position on or near the heater. There is a small metal bulb on the end of the sensor, when purchasing a replacement Hi Limit be sure the diameter is the same.
I hope that helps.
Posted on Nov 05, 2012
Zanussi washing machine fs1255w green end light flashes 5 times what is this error code
Press START/PAUSE and any one of the option buttons
simultaneously for at least two seconds: the LEDs first switch off,
and then display the flashing sequence corresponding to the
alarm condition.
Examples:
Alarm E43 (problems with the door safety interlock triac) will be displayed as follows:
• four flashes of the END OF CYCLE LED indicate the first digit E43;
• three flashes of the START/PAUSE LED indicate the second digit E43;
So, error code E55 as you specified does not exist. Any how, family error code 5 (first digit) means problem with motor. Error code could be E51,E52,E53 and E54.
Possible causes:
- faulty motor
- motor brushes (very often)
- faulty tachometer (integrated in the motor but is replaceable)
- faulty electronic (Motor power triac short-circuited or motor relay contacts sticking).
Dado
Jan 18, 2015 | Zanussi Washing Machines
What is the code p0473 for a dodge sprinter van 2008
Error Code: P0404
Fault Location:
Exhaust Gas Recirculation (EGR) System - Range/Performance Problem
Causes:
-Hose leak/blockage.
-Wiring harness.
-Exhaust gas recirculation (EGR) valve/solenoid.
Error Code: P0473
Discription:
Exhaust Gas Pressure Sensor - High Input
Causes:
- Wiring short to positive.
- Exhaust gas pressure sensor (G450).
- Engine control module (ECM).
Error Code: P0674
Description:
Glow Plug Cylinder 4 Circuit - Circuit Malfunction
Causes:
-No Pre-Glow Period.
-Poor Cold Starting.
-Glow Plug Wiring faulty.
-Poor connection.
-Relay.
-Glow plug control module.
-Glow Plug faulty.
-Engine control module (ECM).
Solutions:
Check Glow Plug Wiring.
Check Glow Plug.
Error Code: P0675
Description:
Glow Plug Cylinder 5 Circuit - Circuit Malfunction
Causes:
-Poor connection.
-Relay.
-Glow Plug faulty.
Solutions:
-Check Glow Plug Wiring.
-Check Glow Plug.
Sep 20, 2014 | 2008 Dodge Sprinter
5 error code
could be anything from a fuel issue to an igniton relay issue..
Dec 23, 2013 | 1999 Volkswagen Golf
ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Mar 10, 2010 | Carrier Heating & Cooling
Problem with entering anti-theft radio code for Honda Fit: The radio screen says: "Enter Code:" I enter the confirmed correct code, but when doing so when the actual code (all numbers) turn into letters or...
when you use the "preset keys" (the keys on the radio with numbers on them) to enter the code, each time you press a code number, a letter appears [c, o, d, e]. once the word is spelled out, from entering the correct 5 digits, the radio is reset, ready to go.
BUT if you miss a number, enter a wrong number, whatever, each number pressed, still makes a letter appear from the word "code". once the word is spelled out, by entering ANY 5 numbers, if ANY of the 5 is wrong, the radio displays a message "Error" and then a number 1 thru 10.
When you see the word "Error..."
the next preset button you push, starts the whole thing over again. The radio says "Enter code". That is when you enter the 1st of the 5 digits, the letter C appears, enter the next digit, the letter O appears, enter the next digit, the letter D appears, enter the last digit, the letter E apperas, the radio is reset, ready to go, if you got the 5 correct numbers entered.
you have 10 chances to enter the right 5 digit code. Each wrong try of 5 digits yeilds a display of "Error 1", "Error 2", "Error 3", etc 'till you get to 10 incorrect tries of 5 digits each.
If you dont get it right in 10 tries, you have to leave the radio "on" for an hour, then it will let you start the 10 tries over again.
Apr 26, 2009 | 2007 Honda Fit Sport Hatchback
Error code e-1 for Ricoh FT 4522
we don't have e-1 code but we do have e101,if my one is correct,there have few steps to follow;
1,press "clear modes"
2, press 107
3, press and hold down'clear/stop" key
4, enter 5 press start
5,enter810 press start
6, turn power off and on
Dec 11, 2008 | Office Equipment & Supplies
Konica 1112 Error code 35
The procedure is as follows:
1. Turn machine off.
2. Turn machine on while holding the 2 & 5 keys.
3. Enter 47 on the keypad.
4. Press the Stop/Clear.
5. Enter 0 on the keypad.
5. Press the START PRINT button.
Power the machine off and on to exit the service mode.
You're done!
Mar 26, 2008 | Office Equipment & Supplies
Error 5
http://www.ok.is/vefmynd/HP%20Color%20LaserJet%202820%20user%20guide.pdf
Here is the user manual.
See page 225 for error codes and corrective action.
Note: Most error codes start at 50.....
Feb 08, 2008 | Office Equipment & Supplies
Program don't start, flashing ligths (start and "delay start" button) for 5 times.
What does the error code mean do you have any idea Is it mentioned in the Hand book. At any rate logic suggests a watewr supply problem that the first thing a washing machine needs - water. So a tap not turned on a Kinked hose An inlet valve solenoid failure- Three things for you to check
Jul 31, 2007 | Hoover Nextra HNWL 3136 Front Load Washer...
Qca Spas Majestic Series Aruba Xl Hot Tub Logo
264 people viewed this question
Top Qca Spas Pool & Spa Experts
john h
Ian Summerfield
Ian Summerfield
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
