Question about Camping, Backpacking & Hiking
Pen mnhggg
    Sergeant:
  • 270 Answers
Send it to a survice center.
Posted on Mar 03, 2009
Tip
How to recover data from Pen Drive
Pen Drive gives ussignificant convenience in today's business life. However, due to human errorsor other reasons, we often meet embarrassed phenomena of losing Pen Drive data. The following are sometypically cases in our daily business life.b>
Practical cases:
1. Pen drive still contain all data, and the space shows the same likebefore, but all files and folders in the pen drive are changed to shortcut.
Cause:
Your pen drive was attackedby virus
Resolution one:
If you oftenuse Pen Drive to transfer data from one computer to another, make sure thecomputer is well protected. If any computer is not protected against virusattacks, the files and folders in Pen Drive may be gone or just change intoshortcut. If that happens, don't panic, you can still get back lost data, Firstly, remove the virus, connect your Pen Drive to one PC that is protectedwith a good antivirus and then scan it, fix all the virus threats that aredetected by the antivirus, After completing scanning, some of the useful filesor folders may deleted. Secondly, use pen drive data recovery program torecover deleted infected files.
Resolution two:
If you can'tdelete virus in Pen Drive, just format Pen Drive and then use data recoveryprogram to retrieve data.b>
2. When transfer files from Pen Drive to PC, mistakenly removed the PenDrive from USB port and some data lost, or press "format" command during theprocess of using Pen Drive. Sometimes, delete data in Pen Drive in one day andfind it is useful in another day and want to recover them.
Cause:
Human error
Resolution:
The data youonce have saved in your pen drive is real hard to remove completely. Firstthing to do is stop using the Pen Drive as the chances of your data beingoverwritten increase as time goes on. Then choose a perfect data recoveryprogram. There are many Pen Drive data recoveryprogram in the internet. Although Ihaven't tested them one by one, Card Data Recovery is the most popular one inthese days.
Steps to recover data fromPen Drive using Card Data Recovery
1.
Plug the Pen Drive into yourcomputer using USB port;
2.
Download Card Data Recoveryand install it on your computer;
3.
Check whether your Pen Drivedisk display in your computer;
4.
Select your Pen Drive;5. Run Card Data Recovery andcontinue the operation under the interface instruction.b>
on Jul 20, 2011 | Computers & Internet
S Pen for my Samsung Note 3 stopped working how can I fix it
Samsung Galaxy Note 3: S Pen stopped working on screen:
Hello. The S Pen is not powered by a battery per se. The screen on your phone generates a magnetic field. There's a coil inside the S Pen that captures energy from the field to power the pen.
1. Question are your S Pen options turned off?
Settings>Controls>S Pen>
turn on Direct Pen Input
turn on Air Command
turn on Air View
etc..
2. it could be the pen tip that is worn out and needs to be changed. Check the tip by pressing it into the pen with your finger.. if you feel the tip going into the pen too far, it's probably the tip that is broken or worn out. Some customers say buying new tips is too much trouble, and getting a new OEM Samsung S Pen made for your Note 3 is a safer option.
3. it could be the wacom digitizer screen that is having problems on your phone and needs to be fixed. If you had fixed the screen prior, it could mean the person who installed the replacement screen could have did a bad job.
4. if you are using a magnet closure case, try taking it off and then using your S Pen. Because the external case magnet can interrupt the magnetic field the S Pen uses for power rendering it useless, until you remove the magnetic closing case.. and then all should be well again.
5. You can do tests on Note 3's that are not carrier locked by dialing *#0*# (this is not a solution but it can help eliminate possibilities)
DIAGNOSTIC TEST your Pen for Samsung Galaxy Note 3
6. If you bought an Aftermarket knockoff S Pen, that's probably the problem right there. A lot of non OEM Samsung S Pen's have their own issues and work for only some things.
7. You can try fixing the sensitivity of the S Pen
8. Buy an original Samsung Galaxy S Pen. A Note 1, 2, 4, or Note 5 S Pen will work for your Note 3, but it may not fit inside the Note 3's internal compartment/holder. You can try buying a used one to save money, but be aware that you might have to change the tip
Feb 08, 2016 | Samsung Galaxy Note 3
I cant sand my data to pen drive frm my pc
If you are not able to send data to your pen drive from your PC that means your pen drive does not have space to carry more data. Please check the space in your pen drive that how much space left in your pen drive or do you have any space left in your pen drive.
to check space in your pen drive follow this:-
open computer or my computer>right click on pen drive icon>left click on properties>now you check the used space and unused pace.
If there is a space left in your pen drive then how much space left because you can download or transferred your data to pen drive up to that limit that space you have left in your pen drive.
If you have no space left in your pen drive or very less space then you can increase the space by moving some files from your pen drive and saving it up in another place in your computer
Mar 03, 2011 | Computers & Internet
Replacement Pen for G-Pen F610 isn't working very well.
nomally happens the 1st time you use.
log off and back on again.
otherwise reset ... it should work next time you boot up.
Jul 21, 2010 | Genius G-Pen F610 (31100050100)
Its for bamboo, but my pen automatically clicks.
you may have a faulty pen. contact technical support here:
http://www.wacom.com/support/contact-support/technical-contact
if they can't help you, maybe you can get a new pen
May 11, 2010 | Wacom Stylus Pen for Graphire4
1. PEN NOT LIFTING. HOW DO I ADJUST PEN LIFT 2.PAPER SKEWS TO LEFT 3. NEED SERVICE MANUAL ON SUMMAGRAPHICS PLOTTER HI7200
Installing Pens
Most types of disposable pens must be activated before using the for the first time. If you are installing a new disposable pen:
  1. Press down on the pen cap to break the internal link seal.
  2. Holding the pen with its tip pointing down, shake the pen to start the ink flow.
  3. Remove the cap and test the pen for ink flow on a scrap of paper or media before installing it in the plotter.
    Some types of pens require adaptor sleeves to fit the pen holders in the pen changer and pen carriage. Insert each pen into its adaptor sleeve, if required, before installing it.
Using the Pen Changer
You may find it easier to temporarily raise the pen changer arm to install pens. Press the widest part of each pen into the jaws of each stall in the pen changer. After installing all the pens that you plan to use, lower the pen changer arm until it latches into place.
Notice that the pen changer stalls are numbered 1 through 8 from right to left (viewed from the front of the plotter).
Note: Make sure that the pen changer arm is in its lowered position and latched into place each time you power on or reset the plotter so that the plotter will correctly change pens.
Operating Without the Pen Changer
For operation without the pen changer, position the pen changer arm in the raised position and install a pen directly into the pen carriage by pressing the widest part of the pen body into the jaws of the pen holder on the pen carriage. You can still produce multi-pen plots, if desired, by enabling the PEN PAUSE parameter--------------Online KeyThe Online key toggles the plotter between on-line and off-line operation. The mode is displayed with each key press.
The plotter is initally in the on-line mode at power-on. In the on-line mode, plotting operations are enabled. When media is loaded in the plotter and the plotter has been selected (see below), an on-line plotter begins executing plotting commands from the input buffer as soon as they are received from the host computer.
In the off-line mode, the plotter can still receive data into its input buffer if it has been selected, but plotting operations do not begin until the plotter is switched on-line. The plotter can be operated manually in the off-line mode using the following control panel keys:
  • Pressing the left or right arrow key moves the pen left or right.
  • Pressing the up or down arrow key moves the media in or out of the plotter.
  • Pressing the PEN SELECT key accesses a menu to select a given pen from the pen changer.
  • Pressing the PEN UP/DN key raises or lowers the pen.
Pressing the Online key during plotting switches the plotter off-line and suspends plotting.
Pressing the Online key again will cause plotting to resume at the point of suspension. ------------------Pen Up/Dn Key
The Pen Up/Dn key raises and lowers the pen when the plotter is off-line. If there is no pen in the carriage, pressing the Pen Up/Dn key causes the plotter to retreive the currently selected pen from the pen changer (if the pen changer is installed and is in the lowered position).
Note: After approximately two seconds of no pen movement, the plotter will automatically raise a lowered pen to prevent ink from bleeding on the media, until the pen is moved again. If the pen is not moved for the period set for the AUTO-CAPPING parameter , the plotter will return the pen to its pen changer stall. To restore the currently selected pen to its previous position on the media, press the Pen Up/Dn key or an arrow key. Pen Select Key
When the plotter is off-line, pressing the Pen Select key allows you to select a pen from the pen changer. After pressingPen Select, press the <-- --> keys until the desired pen number is displayed on the lower line of the LCD, then press the Enter key. The plotter will retreive the selected pen from the pen changer.
The Pen Select key is also used in the Configuration Menu,
Oct 16, 2009 | Computers & Internet
My Cross pen fell on the floor and won't work
was it a ball-point or ink pen tip???
if it is ball-pint. then all you have to do is get a refill cartridge from any of the office supply store or specialty shop.
if it is a fountain pen tip, then you have to send it back to cross for repair.
Feb 09, 2009 | Cross Pen Computers & Internet
"Oversensitive" digital pen
replace the pen the transmitter in the pin has malfunctioned usally caused by the spring loosing its strength
Jul 25, 2008 | Wacom Graphire Graphic Tablet
Camping, Backpacking & Hiking Logo
60 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
