Question about LG KU990 Viewty
LG toploader washing machine alarm signal Lid Open.
Please tell us what is wrong with my brand new washing machine, when the alarm keeps coming on to say Lid Not Closed, when it is closed.
Thank you.
    President:
  • 2,692 Answers
The lid switch is bad, not making contact.Replace switch or see where it is not being contacted by the lid or hindges when the lid is closed.
Posted on Jan 04, 2009
Lg topload washing machine model wf-t7050tp lid magnet broke off how can I repair
maybe super glue use another piece of plastic to build a bridge across the break eric
Dec 27, 2017 | LG Washing Machines
My toploader machine is not rinsing or spinning the model is a LG Fuzzy logic WF-T7014pp
if it does not rinse its a different case,,,,,nd if it does not spin is another ,,,check on the door lid,its a magnet,,,,,,,,,,,,,,,,,attached the washer pic ,,,so i can tell u what to do............
if u have a magnet tryputting it between the door and its main program board,,,centre nd try
Jan 23, 2015 | LG Washing Machines
F&P MW512 TopLoader washing Machine has no power
I would be having the capacitor for the motor checked as they do fry and not work
Jun 27, 2013 | Fisher and Paykel Washing Machines
I have a Kenmore toploader washer, model 110.27032602 about five years old. When I choose cycle and shut the lid, I press start. The lid locks, but then nothing happends. No error codes but I can tell its...
Time to call service. I suspect something has happened on the motherboard. We just purchased a NEW washer from Sears, and within two months, they had to come out and replace the motherboard. They ain't makin' them like they used to, that's for sure. And if you purchase a new one, be sure to take out a three-year extended warranty.
Sep 14, 2017 | Washing Machines
I have a washing machine MODEL:WFT650A01DCT\r\nThe problem isthat when i start the machine the machine take the water normaly ,then the machine start for 3 second right clockwise an counterclockwise,after...
Check the lid cover. At the edge, there is a plastic housing some sort of a magnet. This is the magnetic sensor for lid cover open protection.
If the magnet is not there, place a magnet at the position on the washer where the housing will come in contact with the washer when lid is close.
Nov 30, 2010 | LG WFT1071TP Top Load Washer
Same problem: Lid Open Alarm
You will need to replace the part on the lid. This piece pushes on the lid switch letting the machine know the lid is closed. You can by pass this until you are able to get the piece by pushing a screw driver into the hole where the part from the lid went. Be sure not to push it in to hard, if you do you will have to replace the switch also. Be sure to replace the part from lid because this is a safety switch to keep hands and arms out of the machine while it's running.
Please rate solution
Sep 07, 2009 | LG WFT1071TP Top Load Washer
Maytag Neptune keeps giving us the OP signal
Hello Kristi,
If its FAV6800A/FAV9800A try placing couple 1” dia magnets or similar magnet on the left bumper of the machine and see if that will clear the the “OP” lid open alarm, see pic attached. If that clears the alarm the lid magnet may have moved out of position in the inner lid. See page 33 of the FAV6800A/9800A Service Manual for its location. If that doesn’t clear the “OP” alarm remove 120VAC to the machine and try reseating the left lid lock plug into the left lid lock a few times to possible clear corrosion causing loss of signaling from the left lid lock to the control board Lid Is Closed input. See page 33 and 34 of the SM for pics if the left lid lock and lid magnet. I recommend surge protection on the120VAC outlet powering the machine to help protect the washer control board. Good luck Rich.
Place some external magnets on left bumper and see if that will clear the "OP" alarm.
Try reseating the left lid lock plug into the left lid lock. Be careful, it may be difficult to remove for the 1st time.
Mar 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Will not start up and show code 0d
Hello kc59mail ,
For the FAV6800A the od alarm means the Control Board has not seen a lid open condition for three complete wash cycles. I suspect the left lid lock.
I think you have a problem with the magnetic reed relay in the left lid lock. If you could try this? I want to make sure you signal an “OP” alarm to the display. Can you select Spin Only cycle with the lid open press start. Do you signal the “OP” alarm lid open to the display? If it does close the lid and the “OP” alarm should clear does it? I’m checking that the lid magnet is in place and the signaling connections are working thru the left lid lock back to the control board.
Let us know what you fin and we will go from there. You could try powering down the machine by removing the 120VAC power cord from you wall receptacle. That may give you three more wash cycles before the od alarm is triggered again.
Mar 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
I have a brand new LG 8KG top loader washing machine
Thank you for coming back to me, yes I have had the problem solved today. A technician came around to my home and made a slight adjustment to the Lid and said it should never give me trouble again. It was a free service as my washing machine was brand new and it started up perfectly and went through it's full cycle with no hicups!
Many thanks,
Billie. South Africa. ( Durban)
Jan 04, 2009 | LG WFT1071TP Top Load Washer
LG KU990 Viewty Logo
145 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
