Samsung Comeback  Cell Phone Logo
Posted on Nov 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frozen sim card samsung comeback
The sim card is frozen
Anonymous
Level 3:
Master:
  • Master 444 Answers
  • Posted on Nov 03, 2012
Anonymous
Master
Level 3:
Master:
Answers
444
Questions
0
Helped
101466
Points
1275
Put it in the micro wave
Sgh t559 qsc6270 downloader
May be static electricity. My daughter's phone had occasional issues which I resolved like this: Turn off the phone and pull the battery out. The SIM card is under the battery. Pull the SIM card the re-install it, making sure it seats properly. If that doesn't work, take the SIM card to your phone vendor for a new one, which is generally free.
Stuck on starter screen
covergirl what is your model reference.comeback are many types.
How do i go to my sim card and delete numbers?
go to ur service provider. he can only help you out
3helpful
Samsung mobile gt c3200 memory card not incerted solution
first check your card.if it works on other mobile,Then immediately clean the memory card pins on phone(located at sim card) with one drop of petrol.
2answers
How to unlock samung comeback sght-559 353086/03/015144/5
You can Unlock the samsung Comback SGH-T559 Model Phone using the Unlock code,You can get the Unlock code and instructions at here
moz-screenshot-50.pngMobile-unlocker.com and Unlock it,then use with any GSM Network sim card....
Unlocking instructions:
Warning : Do not enter any wrong unlock codes on your Samsung SGH-T559 Comeback mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung SGH-T559 Comeback mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1 - Switch ON your Samsung SGH-T559 Comeback with a NOT ACCEPTED SIM Card.
2 - Samsung SGH-T559 Comeback will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-T559 Comeback shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-T559 Comeback.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-T559 Comeback is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-T559 Comeback.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung SGH-T559 Comeback.
2answers
Can you please send me the unlocked code samsung comback from t-mobile the imei# 355574031990265
1. Turn off your phone, put in a SIM of a different provider.
2. At the wrong card message, type *#9998*3323#. A message will pop up telling you to press exit, so hit the right soft key. Choose number 7 (or 8 or 9 will work too,) Your phone will reboot and your SIM will work.
3. Type *0141# and then hit call. This will give you a message saying your phone is personalized.
4. Power down your phone and insert your SIM. Then power back up your phone.
5. At the SIM pass code prompt type 00000000, that is 8 zeroes. So that will totally UNLOCK your phone." Do not try this more than twice.
Another alternative is, you can take the phone to any authorize phone service center to help unlock the phone, this is not what you can do yourself, because to unlock your phone, you will need some kind of software, USB cable etc to unlock the phone, so you can also go a nearby phone service center to unlock the phone, but calling your network service provider is the best because they have the records of your phone and can easily help to unlock it. This are the two reliable means you can unlock your phone.
My samsung comeback will not let me send Picture messages!
My wifes Comeback had the same problem, for roughly 6 mos. in 2009. The problem was addressed but not resolved by T-Mobile tech support at 611 customer service. They tried master reset on the phone itself, then a different (new) SIM card, and then tried to re-provision the phone to no avail. I finally took the SIM card out of my phone and tried it in hers and it worked fine when I tried to send or receive pictures from her phone. It was finally handed over to engineers to work on and after a month or two, with no notice from them, and several calls from us as to when we could expect a resolution, it finally began working. F.Y.I. - Others have posted here, unresolved problems with their Comebacks being plugged up but not charging, and not being able to make calls. My wife's phone is having this issue now. The contract does not run out 'till Oct. and we didn't take out the replacement insurance. It may be a battery issue, we don't know at this point. Bottom line, if you can get out from under this phone, Do it immediately. It's not worth the hassle we've endured.
9helpful
2answers
It has a messege that says T559, QSC6270 downloader what does this mean?
my Samsung SGH T559 Comeback has a sims card but says searching and doesnt read the sims at all can i fix it?
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
