Question about Sharper Image SR277 Speaker
Sharper image sr277 transmitter blue light not lit up
ginko
  • 19396 Answers
SOURCE: blinking blue lights
Here is the Ionic Breeze GP SI730 Air Purifier service manual:
http://www.fixya.com/support/p94230-sharper_image_ionic_breeze_gp_si730_air/manual-17755
hope it can help you
cheers
Posted on Feb 16, 2008
  • 121 Answers
SOURCE: sharper image quadra professional series
I am a purifier dealer and this may be as simple as cleaning the unit. The ionzer plate should be soaked in a cleaning solution. Make sure all contact points are tight. The vpower boost it's self or a pc board maybe malfunctioning.
Posted on Sep 28, 2008
What is happening is this: the main electrical component is overheating and forcing the machine to turn off. When it cools, the machine turns back on. Yes, that is actually what is causing the blinking.
There is no solution for this as the main electrical component (a high voltage capacitor in this case) has failed due to stress. In my case, the machine worked for 2 months before failing. The only real solution is to have the unit serviced. However, as there is no service centers, we are all out of luck.
I believe this could be a class action law suit against sharper image for selling units built with components it knew would fail after a short period of time. They had hundreds of reports with this same failure and they knew the cause. Pressing the "boost" button too much causes extreme stress on the capacitor and shortens its life drastically. This capacitor is what provides the power to the ionizing wires.
Posted on Oct 11, 2008
  • 94 Answers
SOURCE: I have a sharper image
If the warranty you are counting on is a Sharper Image Warranty I need to advise you that it was voided in the buyout on 30 May, 2008 when everything at Sharper Image was liquidated by Hilco Consumer Capital, Gordon Brothers, and Bluestar Alliance. If however it was a warranty company outside of Sharper Image you need to contact them.
You can purchase a bulb for the GP on ebay for under $11, which is really a good price considering what you would have paid from Sharper Image. Installation is easy, you just pull up on the tab on the bottom of the filter and pull up. When you are looking at the bulb, turn it 1/4 turn, (2 clicks) and pull it out. That is all there is to it. Hope this helps you.
Posted on Jul 04, 2009
  • 28 Answers
SOURCE: Sharper Image Midi S1853 / NO BREEZE
I have the same problem and haven't been able to fix it. However, others have had the same problem and have posted their solutions. The sizzling sound is caused by electrical arching between the plates and one or both of the two tungsten wires that are run parallel to the plates (if you turn off all the lights and wait for your eyes to adjust to the dark before turning on the Ionic Breeze, it's a pretty cool light show!) Here are things found by others to cause the arching and what they did to fix the problem:
  • --dirt, lint, or tiny hairs stuck somewhere (usually towards the top or bottom of the plates or wire, and maybe in the grid contact points). Clean it better. Using canned air can help blow out the problem.
  • --water droplets. Make certain there is no moisture anywhere when you put the grid (plates) back in. Using canned air can help dry hard to reach areas.
  • --burn marks or melted plastic. These indicates a short circuit. Says dnewcombe1: "There is a feeler bracket that guides the two rear thin wires while the cartridge is being inserted. This "feeler" can melt and become disarranged." You can't fix this issue.
  • --build up on the ionizing wires. Clean them. It's hard. I took mine apart and used steel wool.
Posted on Mar 09, 2010
Sharper image indoor/outdoor wireless speakers and transmitter has no audio.
First, determine if the TV device is putting out sound by plugging in a headphone into the audio out of the TV. If audio is there then the
transmitter and wireless speakers system may be at fault.
You can also plug in a CD player playing a disc into the transmitter to see if that source then transmits the audio.
Aug 21, 2012 | Audio Players & Recorders
Sharper image wireless speakers, model CT 413, were working fine. today, the blue transmitter light isn't on and nothing can seem to make it transmit. suggestions?
My speakers were working fine on my TV, I disconntect them, then when I re-connected the transmitter no signal is received and nothing is heard via the spearkers either.
Nov 25, 2009 | Audio Players & Recorders
Cylinder Like Sharper Image Indoor/Outdoor Wireless Speakers
ask google or you tube or go to car toys they can help. good luck
May 18, 2017 | Sharper Image SR277 Speaker
Sharper Image Wireless transmitter deal
Do not restart them with the button, that won't reset settings, unplug everything from power for 5 minutes and plug them back.
Jul 19, 2008 | Audio Players & Recorders
Light
You need the remote to turn that light off.
Jun 09, 2008 | Sharper Image Slim One-CD Stereo with...
Blinking blue light on ionic breeze s1871
Wher can you return it? Does anyone have and address? My Dads unit has a blinking blue light and the folks at sharper image say to bad so sad only after 2 months out of warrenty. Is there any one out there that can help? I am done buying things from Sharper Image with their attitude! hlaytos@aol.com
Mar 22, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
50 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
woodzowl307
Tom Chichester
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
