My Samsung lns3251dx won't turn on. It just kind of hisses. It sounds like something is spinning but I don't hear noise or see a picture. Help
SOURCE: LG 42INCH PLASMA TV BLANK SCREEN
Open the back cover and check the fuses on Y Sus Board and X Sus Board. If you can find a blown fuse, just replace that board and your problem will be fixed.
SOURCE: TURN ON TV, SHOWS PICTURE FOR A SECOND, THEN THE
there is a bad capacitor in the power board
The Can shaped little device will have a domed or puffed up top on it the value is printed on the side you can , or have someone replace the cap and you should be all set
SOURCE: Can somebody pls. help...our tv Samsung LN40A550
This is a very common problem. The power supply board has failed and needs to be replaced. You can call 1-800-samsung to find out if this problem will be covered under a warranty and the nearest service center. I replaced at least 150 power supplies last year.
SOURCE: I have a Phillips FLATTV model ... Problem with
Try with that...
http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom:
Sound but no picture.
Cure:
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
SOURCE: I have a Samsung DLP TV (model HLT5076S). When
this is because the CRT that is the cathode tube ray oscillator is taking time to warm up
