Question about Canon PIXMA iP1200 Photo Printer
What is the cause of error 5202 from canon ip 1980
Joed911
  • 4338 Answers
SOURCE: i want to know how to solve the 5202 error please
Try resetting the printer:
Go into the Service Mode
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The
indicator will blink in green and remain lit in green.
3) Select one of the following service mode functions by pressing the resume button the specified number of times.
Press Resume Indicator Functions
Zero times Green Power off the printer
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter setting
5 times Orange Destination settings
6 times Green Print head deep cleaning
7 times Green CD-R test print
8 times Orange CD-R print position correction (horizontal)
9 times Green CD-R print position correction (vertical)
4) Execute the function you have selected (except for model setting) by pressing the power button. The printer will switch itself off after performing the function
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on May 10, 2009
sikhan83
SOURCE: Canon Pixma iP1600- Service Error 5202
waste ink absorber is almost full.
pls solve this problem.
Posted on Oct 12, 2008
  • 3741 Answers
SOURCE: error code 5202
its a service error.that printer needs servicing or any of the internal part of the printer is got loose or moved from its actual position.try this instruction if this does not helps then printer needs to be serviced by a locaL Printer servicing /reparing store 1: Remove the Cartridge
2: Unplug the AC Power Cord
3: Close Front access panel, Hold down the RESUME / RESET button and plug in the AC power cord
4: Release RESUME / RESET after plugging in the AC Power cord.
5: Press the RESUME / RESET once within 5 seconds and release the RESUME / RESET.
6: Press and HOLD RESUME / RESET for two seconds or more and release it.
7: Press and HOLD RESUME / RESET for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
Posted on Sep 11, 2009
Testimonial: "It's work for me. Thank's for your advice"
SOURCE: how to fix canon 1980
just follow the others solution..
Posted on Jan 19, 2010
SOURCE: canon ip 1980 offline problem
I want program driver priter PIXMA ip 1980
Posted on Jun 01, 2010
Error 5202 whaT SHOULD I D0
Error 5202 means: UNRECOVERABLE ERROR. You need to return your printer to where you bought it and replace a new one if it is still under warranty.
Jul 20, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip 1980 offline problem
Saya Punya Printer Canon IP 1980, printer sudah terkonek ke PC driver sudah ok tapi ketika saya print tidak ada respon sama sekali saya cek kabelnya bagus tidak ada masalah . kepada para sahabat saya minta bantuannya dan solusinya ? ...
May 31, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Driver Canon Pixma iP1980 for Win98
Hi, You can download the driver from following address:- http://www.prst.pl/download/canon-pixma-ip-1980/canon-printer-canon-pixma-ip-1980.zip
Regards, polysandy
Apr 23, 2010 | Computers & Internet
Service error 5100
5100 means the carriage is not moving properly, or there is grease or ink on the encoder strip The encoder strip is the clear strip with black lines behind the carriage that runs all the way across the printer. You can clean the strip with a Q-tip just damp with water.
Jul 28, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
How to reset pixma ip1980
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Jul 11, 2009 | Canon PIXMA iP1800 InkJet Printer
I have my canon pixma 1980 series... error says ink absorber is full and need to reset... please give me a resetter software.... thanks
Manual reset for canon pixma iP 1980 it easy and like resetting canon ip 1880.If found problem in your printer canon iP 1980 maybe this methode can be use. This reset manual be used to reset waste ink counter in canon pixma iP 1980.
Here how :
  • Turn on your printer Canon Pixma iP1980
  • now Press and hold Resume button for two (2) minutes and then release Resume button.
  • Turn off the printer and turn on again, the Printer will back to normal again.
May 02, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Download driver PIXMA iP 1980?
how to install the canon pixma ip1980 printer without cd
Apr 22, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip1880 printer service error 5202
Sep 30, 2008 | Office Equipment & Supplies
Canon PIXMA iP1200 Photo Printer Logo
616 people viewed this question
old marine
old marine
