Question about Jenn-Air JCD2389G Side by Side Refrigerator
Area between the doors on the side by side are really hot.
The food in the freezer is thawing and the ice in the ice maker tray is clinging together. I notice ice has formed on the door on the inside of the freezer and is now melting. Is there a problem with my fridge or did the door not seal properly? Kenmore Side by Side.
  • 163 Answers
Hi!!! the door was left open some forgot to close the door..if you have more problems let us know..Good luck..
Posted on Jan 04, 2009
Frigidaire FGHN2844LP ice freezing together. Replaced filter. Twenty hours later, ice maker not working, freezer warm, refrigerator temp. steady 40.
Hello Pat Havard,
I was pulling your owners manual to TRY to determine what could be done to block your freezer door or ice chute open during the filter changing process...
Today the ambient air temperature was at least 90 - 100°F
(degrees Fahrenheit)... To maintain 40°F your refrigerator
has to be working...
You need to look at your FREEZER side...
Your food, a pizza box... ice tray...
SOMETHING... in your immediate WORK area
is blocking vents... or proper closure...
Look at the door switch... make sure your light is OFF
My best guess... FILTER FIASCO induced.
http://www.appliancepartspros.com/frigidaire-ice-maker-243297606-ap5809314.html
The icemaker won't run unless you can freeze cubes...
Carnac the Magnificent
Jul 16, 2017 | Frigidaire Refrigerators
Water dripping from freezer into refrigerator area and frozen water in freezer
The defrost cycle is melting ice that will not go down the drain tube in the rear of the freezer. This can be a clogged tube due to debris, organic growths or ice blocking flow. What doesn't end up dripping into the fridge ends up freezing in the freezer compartment. Make sure the fridge is level or tilted back slightly.
Unplug the fridge from power. Remove the contents of the freezer and remove the ice maker, back wall plate and floor plate in the freezer section. Remove ice build up on the floor and tray in the freezer by thawing and soaking up water. Flush hot water (use a turkey baster to get at it) at the opening of the drain hose that is connected to the tray to thaw any ice.. once flowing to the evapraor tray under the fridge, mix up 1/2 oz of bleach and 4 oz of water and pour down the tube to kill any bacteria.
Reassemble and restock the freezer. Monitor the temperature of the fresh food (34 deg) and freezer (0 deg) compartments. If you notice the temperatures start to climb, there may be a problem with the defrost timer, terminator, etc. and may require a pro's help.
Mar 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Turned ice maker off prior to a ten day vacation. Upon return, it would make thin shelled ice cubes and finally stopped altogether. Could the water line be frozen How does one de-ice?
Fastest way is to remove the ice maker tray so that you have an open area where the ice maker filling tube is, then cover your food with a towel or something to help prevent it from thawing while you let refrigerator defrost for about 20 to 30 minutes with a hair drier on warm or a small fan blowing directly on ice maker where the water fill tube or opening is. I does not need to be right next to the ice maker just an unrestricted open area to let it warm sufficiently to thaw it out without thawing out your food in the freezer. A small piece of ice can stop the valve from opening and this can happen if it is not used regularly.
Oct 08, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
GSH22SXA & several problems
For some reason my post has disappeared. I left you with a lot of information and now All I have is a clarification request. Something is going on with the server here today.Sea Breeze
Oct 03, 2009 | GE GSS25JFM Side by Side Refrigerator
Smelly Ice and water leaking into top shelf
Does water in door dispenser taste bad? If not, Try arm and hammer fridge deoderizer. It will help to absorb fridge odors which may be clinging to water molecules in ice maker tray. Ice maker tray is open to freezer area.Water is very medium to infiltrate with odors. Try this first
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool Gold Refrigerator (GS5SHAXNLOO) Ice maker not running, some ice in maker melted together
I have the same model. This has happened to me several times (usually when the door was kept ajar without notice).
Simply open the door, take a common hairdryer and blow at high speed (hottest also) all around the area of where you can feel the ice in the tray, but hasn't dumped yet. It will usually take about 5-8 minutes of consistently moving back and forth around that area. What has happened is the lines bringing water to the trays have frozen over. When you "thaw" them out, the ice made will dump in about 45 minutes. When you hear the ice fall, you will know it's in working order again. I have NOT heard this is a "flawed" icemaker, only that it is hypersensitive to freezing lines when a door is left ajar. In your case, to prevent this from happening again. If you shut the icemaker off again, make SURE you turn off the source of the water feed BEFORE you turn off the ice maker. By doing this, the lines will empty as it makes it's last tray of water. Try that - very confident it will fix your problem!
May 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My GE side-by-side refrigerator is making a fairly loud ticking sound--about once every second-sounds like a big clock.
Water line to ice maker is frozen. Thaw out freezer. Put food in dry ice cooler and open freezer door, reset to OFF, and thaw freezer for four hours. It'll work after that.
May 23, 2009 | GE GSH22JFR Side by Side Refrigerator
Ice maker hasn't worked in years. A couple of days ago food below the ice maker was thawed. Today I felt that the ice maker was hot to the touch. Is there anyway to disengage the power to the ice make
Yes you will need to take the screws that mount the Ice maker to the side of the freezer and unplug the cable plug that is hidden behind the back of ice maker. The only time that element is needed to become hot is the moments before the ice maker drops ice. Thanks, Sea Breeze
May 15, 2009 | Kenmore Refrigerators
Frigidare ice maker making slabs of ice, not cubes
Today, I removed ice maker and auger motor. Found out this morning that water was running down the back of frig. inside, everything in freezer was frozen together. Found this out after removing all food from freezer. When i looked into the ice maker where water enters, that was frozen solid. After thawing and checking everthing. I put it back together in freezer. It is nine oclock now, and I do have cubes. I really can't tell you what I did, except thaw it all out. It's been running for four hours now and it seems to be all right.
Nov 16, 2008 | Frigidaire Dryers
Freezer compartment leaking water and icing up inside
Solution #3 fixed it.
Pulled everything out of the freezer, found where the drain was, it was blocked with ice, hot water and then a flexible straw, the kind that comes from an ammusment park kids container, shoved it down the opening after the hot water and it cleared whatever was blocking the drain.
Thank you very much - Mark
sdsu1985@yahoo.com
Sep 25, 2007 | Admiral 26 cu. ft. Side-By-Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
104 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
