Starts and then stops within 5 second - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 03, 2012
2011 Honda crv starts up then stalls out within 3-5 seconds.
When it stops check if any spark at the plug ,check fuel pump relay.
Sep 25, 2016 | Honda 2011 CR-V
Hobart dishwasher LXIH starts filling and stops after 5 seconds or so
Hobart is probably the most user friendly manufacturer out there. Their service manuals are great. Try this.... Good luck Manuals Support
Feb 17, 2014 | Hobart Dishwashers
Dishwasher does not function properly
Best way to troubleshoot would be to use a multimeter and measure the electrical voltage at the pump just before the pump is to activate, watch the multimeter display for a drop in electrical voltage, if it does drop to zero the electronic control board located within the door has failed.
Dec 22, 2013 | KitchenAid Dishwashers
I have a 97 jeep grand Cherokee, when it has sat for over an hour it takes 8-10 seconds of the starter running before it starts. If turned off after running, and started within a few minutes no problem,...
Fuel pump. The valve in the pump that stops the fuel from draining back into the tank is not working so you crank and crank until the fuel gets up front. Turn the key on but not to start for 5 seconds then off do it five times and then try to start it should start right up
Nov 27, 2011 | 1997 Jeep Grand Cherokee
We don't know how to retrieve out messages from outside the house.
To play back messages remotely, first you'll need to have set up your two-digit security code (PIN). You can download a copy of the manual here which gives all the details. Once you've done that, here's how to use the system:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off), press 0 and enter your PIN code within 2 seconds. The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
3) Enter a command within 15 seconds. Each command thereafter must be entered within 2 seconds. These are the available commands:
  • 0 then 1 Repeat a Message*
  • 0 then 2 Playing incoming Messages
  • 0 then 3 Skipping a Message
  • 0 then 4 Deleting a Message
  • 0 then 5 Stop Operation
  • 0 then 6 Answering System On
  • 0 then 7 Memo Record/Stop**
  • 0 then 8 Greeting Message Record/Stop**
  • 0 then 9 Answer System Off
  • 1 then 0 Help
* For the Repeat a Message function, press 0 then 1 within about four seconds to repeat the previous message, or press 0 then 1 after about four seconds to repeat the current message.
**For the Memo Record and Greeting Message Record function, the first time you enter the corresponding command, it starts the Recording function. If you want to stop the recording, press 0 then 7, 8 or 5.
4) After the command has finished, you hear intermittent beeps indicating that the system is in the command waiting mode. You may enter another command at this time from the chart above.
5) Hang up when you're done.
Jul 05, 2011 | Uniden TRU8885 Digital Answering Machine
Whirlpool awm 6145/3 washing machine. Door shuts cycle starts but within about 5 seconds it stops and door open light comes on.
your door safety switch may be to blame,, if its faulty the machine gets a notice that something is wrong and stops,, to check that try this link http://www.partselect.com/Virtual-Repairman.htm
May 31, 2011 | Washing Machines
It starts but stops right away.
Bad speed sensor. When display recognizes no belt movement it stops within 5 seconds.
May 10, 2010 | Proform Exercise & Fitness
I have a code for my Uniden cordless to get voice mail while away from home. Not sure what else I need beside the code.
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a
remote location (when you are away from home, or from another room using a
handset). Additionally, you can turn on or off your answering system remotely.
Remote access away from home
You can operate your answering system from a remote location using any touchtone
telephone.
off), press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code"
on page 25).
3) The answering system announces the current time and the number of messages
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
**For the Memo Record and Greeting Message Record functions, the first time you
enter the corresponding command, the phone starts recording. If you want to
5) After the command has finished, you hear intermittent beeps indicating that the
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help
Jul 09, 2009 | Uniden Cordless Telephone
Hi!
SC458 PTR pressure
mechanism H.P.
detection error
• When the PTR pressure
mechanism does not
stop its H.P. after 15
seconds from the PTR
lift motor starts to return
to its H.P.
• H.P. detection sensor
does not on within 7
seconds after the PTR
pressure movement
starts.
does not off within 7
pressure release starts.
• Defective PTR lift motor
• Defective H.P. sensor
• Dirty H.P. sensor
feeler
• Defective main control
board
1. Make sure that sensor harness is properly
connected.
2. Clean the sensor, replace it if necessary.
3. If the sensor feeler is broken, replace it.
4. Replace the PTR lift motor.
5. Replace main control board.
Hope this is what your looking for
Thanks J
Jan 05, 2008 | Office Equipment & Supplies
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
