Question about Kelty Ridgeline Framed Baby Carrier
Back length adjustment on baby carrier
I'm having trouble adjusting the back length on this baby carrier. I know that the back pad above the hip pad should be able to move up or down to suit the back of the wearer, and I've pushed the yellow button to try to slide the pad down the steel bar to which it is attached. The pad is now in the central position, so it should be able to move up (to accommodate a longer back) or down (to accommodate my shorter back). Please tell me how to move the pad. Thanks!
Take a look on Kelty's website by clicking the link below: http://www.kelty.com/kelty/instructions.php Good luck Ian
Posted on Jul 28, 2007
Manual for playtex hip hammock
Hey have you tried going thru google, searching for that specific manual? Or maybe even going to the Playtex web site and asking them for the manual?
May 02, 2012 | Playtex Deluxe Hip Hammock Baby Carrier...
Adjusting quinny buzz harness for a newborn
Hi
This is not feedback we've heard before! Remember there are two places to adjust the harness - underneath the shoulder harness pads and at the waist position. To adjust underneath shoulder harness pads you need to undo the popper from the harness, slide the pad down the length of the harness and adjustment point revealed to make harness smaller.
Jan 03, 2012 | Quinny Buzz Jogger
How do you move the straps for a bigger child
Hi
Undo the popper on the shoulder harness pad. Slide the pad down the length of the shoulder harness strap.
Unhook the metal D ring.
Feed the short length, low down anchor point back in behind the seat fabric. Bring the longer length, higher up anchor point out at the desired height.
Re-attach the D ring. Adjust the harness straps accordingly.
Slide harness pad back up shoulder harness and re-attach popper.
Sep 11, 2011 | Quinny Buzz Three Wheel Stroller
Can't make Baby Bjorn Active Comfortble
Use the size adjustment buckle to produce a comfortable fit for you and your baby. (The Baby Bjorn Active Baby Carrier is adjustable both for the baby and the parent). Make sure you are using BOTH adjustments, rather than merely adjusting for one or the other of you. Think of it as putting on (and tying) two separate shoes. Both should be nice and snug. Every review that i have said says these are never as comfortable as a wrap, but seem to be more convenient.
  • Step 3 use-bjorn-active-baby-carrier-1.3-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep3 span.image a:first').attr('href','http://i.ehow.com/images/a04/ur/dd/use-bjorn-active-baby-carrier-1.3-800X800.jpg'); }); Unbuckle one or both of the side straps when taking the baby in and out of the baby carrier. This makes the job much quicker and smoother and everyone will be much more content.
  • Read more: How to Use a Baby Bjorn Active Baby Carrier | eHow.com http://www.ehow.com/how_5205421_use-bjorn-active-baby-carrier.html#ixzz0wKrU4VJb
    Mar 13, 2010 | Baby Bjorn Active Baby Carrier
    My infantino slingrider baby carrier did not come with a manual
    Your sling is on RECALL. Go to www.infantino.com or call the number inside the sling for a free replacement.
    Aug 03, 2009 | Infantino 151-210 Baby Sling/Wrap
    The hip belt rides up
    You need to adjust the torso length. The adjustment is directly behind the part that goes against your back.
    Jun 13, 2009 | Kelty Kangaroo Baby Carrier
    Adjusting straps on baby carrier
    hi. here is the website that may be helpful to you..
    https://plweb.evenflo.com/replacement_parts.aspx
    Feb 14, 2009 | Evenflo Baby Gear
    I don t know how to use
    hi mhead. What is the specific model of the said front carrier? However, you may check out the link I'm sending you.The said link might have a user's manual for your carrier.
    http://www.tomy.co.uk/careline/product-instructions/nursery-product-instructions/
    hope this helps..
    -mox
    Dec 30, 2008 | Tomy Roma Baby Carrier
    Directions
    This will be hard to explain, but please bear with me. The 1994 unit I have is on ebay right now...I would imagine newer models are similar. http://cgi.ebay.com/Fisher-Price-Perfect-Support-Baby-Carrier-Gently-Used_W0QQitemZ290040314299QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116 The baby seat portion has one color clips, while the adult portion has a different color clips. Mine are white, and turquoise. The baby part has two 'buttons' near the **** area. Depending which one is snapped into the V shape notch on the adult part, the baby either faces toward the adult, or outward. The adult harness makes an X on your back, with a U shape in the front. The wider band part goes around the adults waist. On the baby seat part,the white clips go around the baby's tummy, similar to putting on a diaper. The turquoise clips on the baby part clip to the turqouise clips on the adults front shoulder area. Each strap is then adjustable for correct length. Hope this helps. I got mine at a garage sale, too, and it took awhile to figure out.
    Nov 30, 2008 | Fisher Price Deluxe Perfect Support Baby...
    Need help with putting straps back on
    I know this is months later, but here you are in case you (or anyone else) needs the info again. First, though, I feel that it wouldn't be responsible to neglect to tell you that if you got the seat in 2000, it is expired and no longer safe to use. Car seats generally expire after 6 years because the plastic degrades over time - in a 10 year old seat, it can look fine but actually be brittle enough that the entire harness can rip out of the seat if it's an accident. For the manual, visit Cosco's website and fill in the product number and date of manufacture. It will bring up a PDF file of the manual that you can download. To rethread the straps, first replace the **** strap. Slide the metal plate down through the slot in the seat, with the buckle facing out. Slide the metal clip under the tab and push it down to lock it in place. Facing the seat, start by threading the end of the harness strap down through the slot of the left side of the bottom (where the child's right hip would be). Under the pad/cover, thread it across the bottom of the seat and up through the matching slot on the right side. Pull it until you have equal lengths on both sides. Thread the buckles onto the the strap (one one each end) and buckle them. Thread the chest buckle onto both ends, making sure that the harness doesn't twist. Buckle it, too. Push the ends through the harness slots. Pull the harness through to the back, making sure that it goes OVER the metal bar, but UNDER the plastic adjuster handle. There is a loop sewn into each end of the harness. The adjuster strap has a splitter plate, kind of shaped like a Y. Slide each loop over the ends of the plate and all of the way into the slot, so that the curved ends of the splitter plate are exposed and the strap is secure in it's slot. Adjust the harness height by squeezing the metal bar on the back of the seat (the one behind the harness) forward and moving it and the plastic adjuster bar up or down to the correct position (at or below the shoulders for rear-facing, at or above the shoulders for forward facing). Do note that the very top slot is NOT for use with the harness - it's only to adjust the headrest when the seat is being used as a seat belt positioning booster and is not reinforced to support the harness in an accident! Adjust the tightness of the straps with the button/extra length on the front of the seat. Properly tightened straps should lay in a straight line without sagging and you should not be able to pinch up any slack (lengthwise going down the harness, not across the width of it) at the shoulders or hips. Adjust the chest buckle to lie in line with your child's armpits, never his neck or belly.
    Oct 15, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
    Kelty Ridgeline Framed Baby Carrier Logo
    320 people viewed this question
    Top Kelty Baby Gear Experts
    Andrew Taylor
    Andrew Taylor
    richie46
    Tom Chichester
    Are you a Kelty Baby Gear Expert? Answer questions, earn points and help others
