Replaced PSU cabling OK Fans on/off won't boot
SOURCE: No beeps on boot up with asrock mobo? help plz
well i have done all barbones tests and the mobo is now on its way back as its a dud :( even with just cpu in and mem it doest beep to say theres no graphics.
SOURCE: Motherboard shorted ? help please
Unless you have about a $3000 soldering machine and lots of skills soldering, i would say just get a new mobo. the cost to fix it would be lots more than its worth
SOURCE: motherboard shorted
SOURCE: No Audio on ECS 6100SM-M2 mobo d
Go to the Startup Bios Configuration Utility By Presing Specific hotkey. Probanly you having Audio Device as Following
Realtek ALC660/ALC662 6-channel audio Enable or Reinstall Driver As link given here >>> http://www.esoft.web.id/go/WDM_R210.exe
Hope you will have good result
Regards
SOURCE: Tyan S5396 and Thermaltake 1500W
tyan i5400xt.. to test for ground.. pull the board from the chassis and test with a different known good power supply
if the boot works... then you have a power supply issue...
does the board have a post code lighted signal ???
if so.. a bad power supply should goto FF error code
verify you have enough power on the cpu rail with your power supply specifications also
be sure you have all cables 4 pin 8 pin and 20/24 pin connections done correctly.. lastestly check if the board is touching the chassis edge anywhere... could cause a ground
also take and loosen all the MB screws from the chassis.. just let it hang there this will test the grounds needs the screw connections
[email protected]
tyan specialist
