Printer problem My brother 5 in one - MFC-3220C has an error 9 message on the screen, and it stop printing. How do I remove it with out taking it to the shop?
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
~Brother MFC 3220c printing problem-o!~
clean the print head with water on a rag. it could need new cartridges also.
Sep 26, 2012 | Brother MFC 3220C All-In-One InkJet...
My printer has an error #41 on the screen what
THE ERROR 41 INDICATES AN INCORRECT VOLTAGE COMMING FROM THE PRINTHEAD, THE PRINTHEAD WILL NEED TO BE REPLACED AND THE HEAD I.D. WILL NEED TO BE RESET, ALSO, BROTHER RECOMENDS THAT YOU CHANGE ALL OF THE INKS TO NEW INKS. THE RESETING OF THE HEAD I.D. CAN ONLY BE PREFORMED BY AN ATHORIZED BROTHER SERVICE CENTER. THIS REPAIR CAN NOT BE PREFORMED BY THE END USER. I HOPE THIS HELPS.
Apr 11, 2010 | Brother MFC 3220C All-In-One InkJet...
What type of usb cord is needed for this printer
Hello there:
here is the information that you requested ok
I hope that this is very helpful for you
Best regards Michael
Cables for the Brother MFC-3220C 5-in-1 Color Multi-Function Center: corner1.gif Part# Price Status Qty. Belkin PRO USB 6' Cable
USB cable, 4 pin USB Type A (M) - 4 pin USB Type B (M), 6 ft F3U133-06 $8.99 In Stock Belkin 10' USB Cable
A/B Type, Hi-Speed USB 2.0, 10 ft F3U133-10 $14.99 In Stock Top
Nov 24, 2009 | Brother MFC 3220C All-In-One InkJet...
Error Message
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement. My advice is to take it to a
Brother service centre while it is under warranty. If it's out of
warranty then it is cheaper to purchase a new, non Brother model. If you have been using non-Brother cartridges or refills, they can have too much water in them and it erodes the print head after a while. Usuall y just after warranty has expired!
Oct 23, 2009 | Brother MFC 3220C All-In-One InkJet...
Brother MFC-3220C, the black ink cartridge is jammed in the print carriage. It's not printing and I wanted to take it out to clean and I cant get the release to let go so I can take the black cartridge...
Try releasing the two metal clips by the side that hold the print head. Take out print head partly and try removing the black cartridge again. Hope this help
Mar 27, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
Error 41 MFC 3220C
WELCOME TO THE ERROR 41 DELIMA. YOU WILL NEED A NEW PRINT HEAD, MAY BE U CAN BUY ONE FROM A BROTHER DDEALER AND INSTALL IT GOOD LUCK
Jan 27, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
Print head for brother mfc-3220c
how do you remove the ink cartridge from mfc-3220c when the lever is stucki
May 18, 2008 | Brother MFC-3220C Plain Paper Inkjet Fax
Brother MFC 3220c machine error 41
I had the same problem with a Brother MFC3420C after replacing the print head with a new one the same error 41 occured 4 weeks later.
I finally fixed the problem (see photo's) and sent the parts back to Brother :-)
Don't buy Brother Inkjet technology its all ****!.
Their laser technology seems to be much more robust and reliable, have had a Brother HL-1440 since 2004 and its still running well.
http://www.flickr.com/photos/48446421@N05/sets/72157623635891898/
Jan 12, 2008 | Brother MFC-3220C Plain Paper Inkjet Fax
Brother MFC-3220C
Error 41 is Print head needs to be replaced, on this model it is not a big job, Heads can be purchased from Brother dealers, ring brother to locate if you wish to repair this machine rather than replace it.
Head sells for about $80 for the part from a brother dealer 1-800-284-4329 and it will need a new set of inks too, not really worth it just replace with new machine with ink and a warranty.
Very common issue, brother extended warranty for this fault for two years but yours would be past it by now, the s/n tells of build date, the first two digits of the LAST NINE of the serial number indicate build date, so a K6J702822 ending serial no. means it was built K6 = Nov 06.
I beleive that this is a result a lot of the time by the use of refills and remanufactured ink cartridges being used.
There is heaps of info on net regarding "error 41".
Nov 15, 2007 | Brother MFC 3220C All-In-One InkJet...
k24674
jasbo
jasbo
