Problem happened suddenly. ****** fluid is full, nice & red. No leaks. When problem first happened reverse went out without warning. Pushed car out of parking stall and drove it home (approx. 15 miles). Car would shift late and hard and then was somewhat 'jerky' for entire drive. Is ****** shot? Possibly a sensor, vaccum hose or something less than full ****** rebuild or replacement?
Check vehicle speed sensor operation.
Suspect fluid flywheel.
Are you talking about the torque convertor?
There is no such thing as a fluid flywheel.
Jamie, a fluid flywheel IS a torque convertor. with an extra rotor.
When the extra rotor fails that is when you lose the increased torque, you still get drive but with over heating and sluggish performance.
SOURCE: transmission problem
Sounds like linkage all right, especially if the shifter is limp. You got lucky. My old '83 Chevy Chevette got stuck in 1st gear this way. Usually an easy fix, just look for where the rods are supposed to connect, and a new cotter pin will usually take care of this problem.
SOURCE: transmission slipping,dies in drive
Hi there.Hope this can help.On the top of the transmission there's a black electrical plug that the shift linkage goes in..It sounds like the range sensor is out of adjustment..If you try going from reverse to like first or second does it still stall.You may have to get it adjusted.Does the selector in the car where it say P R N D 2 1 Line up with its indicator.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
SOURCE: 2001 chevy impala transmission will not stay in gear
a chevy mechanic suspected shift cable was worn or damaged...mine will sometimes engage..and then wont engage at all even tho shifter moves freely....
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Automatic transmission shift lever
issues?-------
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
AUTOMATIC TRANSMISSION FLUID LEVEL? --
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-automatic-transmission.html
AUTOMATIC TRANSMISSION FLUID AND
FILTER?
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-automatic-transmission.html
Transmission fault light on
car dash?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
Transmission shifting
problem?
http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
OD light flashing and transmission fluid
leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
****** wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Automatic transmission will not go into
reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
This
will help.
Thanks.
issues?-------
FILTER?
car dash?
problem?
leaking?
reverse?
This
will help.
Thanks.
