Question about Linksys WRT300N Wireless Router
LOST MY CD SET UP TO MY WIRELESS ROUTER WRT300N
  • 2,878 Answers
Not really required. Connect the ISP modem to main uplink port. Then connect pc to any other port. Done!
Posted on Nov 06, 2012
SOURCE: WRT300N is no longer visible in View Available Wireless Networks
I just got done chatting with LinkSys support, and this setting ended up solving the problem...no router reboot even needed:
Under router confi settings Wireless - Basic Wireless Settings
radio band - standard
wide channel - 9
standard channel - 11 - 2.46
Posted on Aug 15, 2008
SOURCE: Linksys WRT300N router issue
I have the wrt300n router it was a little tough working with but it works great. I have 2 linksys cameras hooked up to it. when 1st hooking up have to up plug modem & router plower up router then modem lites should start flashing using wep or not should see routers name from other wireless computer in router.
Posted on Apr 20, 2009
Joed911
  • 4338 Answers
SOURCE: WRT300N wont connect wireless
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 01, 2009
govinda123
  • 2260 Answers
SOURCE: I have a linksys wrt300n router. It works fine
WRT300N router has issues with firmware. Upgrade the firmware of the router.
Download the new firmware from the web site www.linksys.com/download . save it on your computer. open the set up page of the router.
Upgrade the firmware of the router. Once you upgrade the firmware , reset the router for 30 seconds. Release the reset after 30 seconds. wait for 1 minute. unplug the power and plug it back in. wait for 1 minute.
Now you will need to reconfigure the router.
Click here for more information
Posted on Apr 01, 2010
router-user
  • 550 Answers
SOURCE: My Linksys wrt300n wireless N router is slow
You have WRT300N router. If it is very old model then upgrade the firmware of the router. and try changing the wireless channel on the router.
Firmware is the software of the router.
Download the latest firmware of the router. Go to the manufacturer's web site and download the firmware of the router.
Open the set up page of the router and upgrade the firmware of the router. Once you upgrade the firmware of the router, reset the router.
On the router you will find a small reset button, hold it down for 30 seconds. release it. wait for 1 minute. Now unplug the power to the router and plug it back in.
Now you will need to reconfigure the router according to the Internet service provider.
Posted on Apr 27, 2010
How do i set up my wireless wrt300n wireless router ? where can i find the Quick Start Manual?
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
Manual:
http://homedownloads.cisco.com/downloads/userguide/1224638363654/WRT300N_ug.pdf
Dec 28, 2010 | Linksys WRT300N Wireless Router
I lost the cd to install my wireless router. I also do not know how to hook it up to my modem
You can get the install program from Linksys http://www.linksysbycisco.com/APAC/en/support/WRT300N/download
There are a bunch of settings so I have included the highlights of what you want to address:
Wireless Router
It is usually easiest to run the install wizard, but be sure to be ready to set the items listed below.
Things to set:
Note: Routers are intended to be set by geeks. You have to SAVE EVERY page, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes.
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping to bottom of the router. Physical access is not the security issue.
4. Check that your router is set to broadcast its' presence.
Dec 05, 2010 | Linksys WRT300N Wireless Router
How to set up password to my lynksis wrt300n
You can follow the step by step procedure in securing your wireless router, here is my TIPS for that.
http://www.fixya.com/support/r3791457-enabling_wireless_security_linksys
May 30, 2010 | Linksys WRT300N Wireless Router
I have a linksys wrt300n router. It works fine when set to b/g only. But when set to mixed or n-only I can't get to the internet. I have an Inspiron 1721 with dell wireless-n and another inspiron with...
Mar 29, 2010 | Linksys WRT300N Wireless Router
I DO NOT HAVE THE CD THAT CAME WITH MY WRT300N V1. DO I NEED DRIVERS. OR WILL IT WORK WITHOUT THE DISC. i BOUGHT IT AT A SECONDHAND STORE. IT WORKS.
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Jan 03, 2010 | Linksys WRT300N Wireless Router
I just rewired all my network connections, my wrt300n wireless indicator is not lit. The network is set up on a linksys broadband router on a cable modem and wrt300n was functioning properly when it was...
Try first resetting the router by pressing the reset button of the router fro 10 seconds while power is ON and then after that reconfigure the router.....
Dec 07, 2009 | Linksys WRT300N Wireless Router
Linksys WRT300n will only allow local access wirelessly
go into the router interface and see if it is set for DHCP and reboot systems it should be fine
Jul 17, 2009 | Linksys WRT300N Wireless Router
Wrt300n password
Try using "admin" as username & password.
-mrsolution
Jun 11, 2008 | Linksys WRT300N Wireless Router
Need the driver for Linksys WRT300N V1 ... can't find the CD
The LINKSYS WRT300N is a standalone device, there are no software/driver needed on your PC for the router to work. However, there is an easy Setup Wizard that is in the CD that normally comes with the unit.
Unfortunately, Linksys did not make the specific Setup Wizard (Version 1.3) for the WRT300N available online. However, if you care to try the Setup Wizard for a WRT54GC, it may downloaded from the LINKSYS ftp site here. I used to have a WRT54G and I did make use of the Setup Wizard for that model. I upgraded to WRT300N. The setup wizard for the old WRT54G worked likewise on the new WRT300N.
Alternately, the WRT300N can still be configured without the CD or the Setup Wizard by logging into the Configuration Page (192.168.1.1). Remember to use LAN interface when setting the router (as shown in the connection diagram) and set your PC to an IP Address of 192.168.1.2, Subnet Mask of 255.255.255.0; Follow on screen instructions and enter settings/configurations manually.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information. Additionally, if you still prefer to have a copy of the original WRT300N Setup Wizard, pls include your email address that I may send it to you as an attachment.
Good luck and kind regards.
Nov 24, 2007 | Linksys WRT300N Wireless Router
WRT300N Wireless Router change to DHCP
I would set the new wireless router to have a static ip address on the same subnet as the first router.  Then set the DNS and Default Gateway the same as the first router.  When computers connect they should pick up an ip from the first router.
Oct 24, 2007 | Linksys WRT300N Wireless Router
Linksys WRT300N Wireless Router Logo
24 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
